RTEMS 5.2
Modules | Data Structures | Macros | Functions
PowerPC Architecture Support. More...
 PowerPC Assembler Support
 PowerPC Assembler Support.
 PowerPC Paravirtualization Support
 PowerPC Paravirtualization Support.
struct  CPU_Interrupt_frame
 Interrupt stack frame (ISF). More...
#define FRAME_LINK_SPACE   8
#define SRR0_FRAME_OFFSET   FRAME_LINK_SPACE
#define SRR1_FRAME_OFFSET   (SRR0_FRAME_OFFSET + PPC_REG_SIZE)
#define EXCEPTION_NUMBER_OFFSET   (SRR1_FRAME_OFFSET + PPC_REG_SIZE)
#define PPC_EXC_INTERRUPT_ENTRY_INSTANT_OFFSET   (EXCEPTION_NUMBER_OFFSET + 4)
#define EXC_CR_OFFSET   (EXCEPTION_NUMBER_OFFSET + 8)
#define EXC_XER_OFFSET   (EXC_CR_OFFSET + 4)
#define EXC_CTR_OFFSET   (EXC_XER_OFFSET + 4)
#define EXC_LR_OFFSET   (EXC_CTR_OFFSET + PPC_REG_SIZE)
#define PPC_EXC_INTERRUPT_FRAME_OFFSET   (EXC_LR_OFFSET + PPC_REG_SIZE)
#define PPC_EXC_GPR_OFFSET(gpr)    ((gpr) * PPC_GPR_SIZE + PPC_EXC_INTERRUPT_FRAME_OFFSET + PPC_REG_SIZE)
#define PPC_EXC_GPR3_PROLOGUE_OFFSET   PPC_EXC_GPR_OFFSET(3)
#define PPC_EXC_FRAME_SIZE   PPC_EXC_GPR_OFFSET(33)
#define CPU_INTERRUPT_FRAME_SIZE    (PPC_EXC_GPR_OFFSET(13) + PPC_STACK_RED_ZONE_SIZE)
#define GPR0_OFFSET   PPC_EXC_GPR_OFFSET(0)
#define GPR1_OFFSET   PPC_EXC_GPR_OFFSET(1)
#define GPR2_OFFSET   PPC_EXC_GPR_OFFSET(2)
#define GPR3_OFFSET   PPC_EXC_GPR_OFFSET(3)
#define GPR4_OFFSET   PPC_EXC_GPR_OFFSET(4)
#define GPR5_OFFSET   PPC_EXC_GPR_OFFSET(5)
#define GPR6_OFFSET   PPC_EXC_GPR_OFFSET(6)
#define GPR7_OFFSET   PPC_EXC_GPR_OFFSET(7)
#define GPR8_OFFSET   PPC_EXC_GPR_OFFSET(8)
#define GPR9_OFFSET   PPC_EXC_GPR_OFFSET(9)
#define GPR10_OFFSET   PPC_EXC_GPR_OFFSET(10)
#define GPR11_OFFSET   PPC_EXC_GPR_OFFSET(11)
#define GPR12_OFFSET   PPC_EXC_GPR_OFFSET(12)
#define GPR13_OFFSET   PPC_EXC_GPR_OFFSET(13)
#define GPR14_OFFSET   PPC_EXC_GPR_OFFSET(14)
#define GPR15_OFFSET   PPC_EXC_GPR_OFFSET(15)
#define GPR16_OFFSET   PPC_EXC_GPR_OFFSET(16)
#define GPR17_OFFSET   PPC_EXC_GPR_OFFSET(17)
#define GPR18_OFFSET   PPC_EXC_GPR_OFFSET(18)
#define GPR19_OFFSET   PPC_EXC_GPR_OFFSET(19)
#define GPR20_OFFSET   PPC_EXC_GPR_OFFSET(20)
#define GPR21_OFFSET   PPC_EXC_GPR_OFFSET(21)
#define GPR22_OFFSET   PPC_EXC_GPR_OFFSET(22)
#define GPR23_OFFSET   PPC_EXC_GPR_OFFSET(23)
#define GPR24_OFFSET   PPC_EXC_GPR_OFFSET(24)
#define GPR25_OFFSET   PPC_EXC_GPR_OFFSET(25)
#define GPR26_OFFSET   PPC_EXC_GPR_OFFSET(26)
#define GPR27_OFFSET   PPC_EXC_GPR_OFFSET(27)
#define GPR28_OFFSET   PPC_EXC_GPR_OFFSET(28)
#define GPR29_OFFSET   PPC_EXC_GPR_OFFSET(29)
#define GPR30_OFFSET   PPC_EXC_GPR_OFFSET(30)
#define GPR31_OFFSET   PPC_EXC_GPR_OFFSET(31)
#define CPU_PER_CPU_CONTROL_SIZE   0
void _CPU_Context_volatile_clobber (uintptr_t pattern)
void _CPU_Context_validate (uintptr_t pattern)
RTEMS_INLINE_ROUTINE void _CPU_Instruction_illegal (void)
RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation (void)
PowerPC CPU Department Source.
PowerPc MSR and Registers Access Definitions.
This file contains some powerpc MSR and registers access definitions.
