RTEMS 5.2
TMS570 Board Support Package. More...
Modules | |
System Clocks | |
System clocks. | |
Files | |
file | clock.c |
clock functions definitions. | |
file | printk-support.c |
definitions of serial line for debugging. | |
file | tms570-sci.c |
Serial communication interface (SCI) functions definitions. | |
file | bsp.h |
Global BSP definitions. | |
file | irq.h |
TMS570 interrupt definitions. | |
file | system-clocks.h |
System clocks. | |
file | tms570-pinmux.h |
I/O Multiplexing Module (IOMM) basic support. | |
file | tms570-pins.h |
Select pin mapping according to selected chip. Defaults to TMS570LS3137ZWT for now. | |
file | tms570-pom.h |
Parameter Overlay Module (POM) header file. | |
file | tms570-rti.h |
Real Time Interrupt module (RTI) header file. | |
file | tms570-sci-driver.h |
Declaration of serial's driver inner structure. | |
file | tms570-sci.h |
Serial Communication Interface (SCI) header file. | |
file | tms570-vim.h |
Vectored Interrupt Module (VIM) header file. | |
file | tms570_selftest.h |
Definition of TMS570 selftest error codes, addresses and functions. | |
file | tms570_selftest_parity.h |
Check of module parity based protection logic to work. | |
file | tms570lc4357-pins.h |
Specification of individual pins mapping to the package. | |
file | tms570ls3137zwt-pins.h |
file | irq.c |
TMS570 interrupt support functions definitions. | |
file | bspreset.c |
Reset code. | |
file | bspstart.c |
Startup code. | |
file | bspstarthooks.c |
First configurations and initializations to the correct functionality of the board. | |
file | init_emif_sdram.c |
Initialization of external memory/SDRAM interface. | |
file | init_esm.c |
Error signaling module initialization. | |
file | init_pinmux.c |
Initialize pin multiplexers. | |
file | pinmux.c |
file | tms570-pom.c |
TMS570 Parameter Overlay Module functions definitions. | |
file | tms570_selftest.c |
TMS570 selftest support functions implementation. | |
file | tms570_selftest_par_can.c |
Test CAN module parity based protection logic to work. | |
file | tms570_selftest_par_mibspi.c |
Test MibSPI module parity based protection logic to work. | |
file | tms570_selftest_par_std.c |
Generic parity based protection logic check applicable to HETx, HTUx, ADC, DMA and VIM. | |
file | tms570_selftest_parity.c |
file | tms570_tcram_tests.c |
TCRAM selftest function. | |
#define | BSP_FEATURE_IRQ_EXTENSION |
#define | BSP_OSCILATOR_CLOCK 8000000 |
#define | BSP_PLL_OUT_CLOCK 160000000 |
