RTEMS
5.2
bsps
include
grlib
gr_701.h
1
/* GR-701 PCI Target driver.
2
3
* COPYRIGHT (c) 2008.
4
* Cobham Gaisler AB.
5
6
* Configures the GR-701 interface PCI board.
7
* This driver provides a AMBA PnP bus by using the general part
8
* of the AMBA PnP bus driver (ambapp_bus.c).
9
10
* Driver resources for the AMBA PnP bus provided can be set using
11
* gr701_set_resources().
12
13
* The license and distribution terms for this file may be
14
* found in found in the file LICENSE in this distribution or at
15
* http://www.rtems.org/license/LICENSE.
16
17
18
#ifndef __GR_701_H__
19
#define __GR_701_H__
20
21
#include <drvmgr/drvmgr.h>
22
23
#ifdef __cplusplus
24
extern
"C"
25
#endif
26
27
/* An array of pointers to GR-701 resources. The resources will be
28
* used by the drivers controlling the cores on the GR-701 target AMBA bus.
29
30
* The gr701_resources is declared weak so that the user can override the
31
* default configuration. The array must be terminated with a NULL resource.
32
33
extern
struct
drvmgr_bus_res
*gr701_resources[];
34
35
#define GR701_OPTIONS_AMBA 0x01
36
#define GR701_OPTIONS_IRQ 0x02
37
38
/* Print information about all GR-701 PCI boards */
39
void
gr701_print(
int
options);
40
41
/* Print information about one GR-701 PCI board */
42
void
gr701_print_dev(
struct
drvmgr_dev
*dev,
int
options);
43
44
/* Register GR-701 driver */
45
void
gr701_register_drv(
void
46
47
#ifdef __cplusplus
48
49
#endif
50
51
#endif
drvmgr_bus_res
Definition:
drvmgr.h:214
drvmgr_dev
Definition:
drvmgr.h:273
