RTEMS
5.2
bsps
include
grlib
gr1553rt.h
1
/* GR1553B RT driver
2
3
* COPYRIGHT (c) 2010.
4
* Cobham Gaisler AB.
5
6
* The license and distribution terms for this file may be
7
* found in the file LICENSE in this distribution or at
8
* http://www.rtems.org/license/LICENSE.
9
10
11
#ifndef __GR1553RT_H__
12
#define __GR1553RT_H__
13
14
/* CONFIG OPTION: Maximum number of LIST IDs supported.
15
* There are two lists per RT subaddress, one for RX one
16
* for TX.
17
18
#define RTLISTID_MAX 64
19
20
/* CONFIG OPTION: Maximum number of Interrupt handlers per device supported
21
* max is 256 supported, and minimum is 1.
22
23
#define RTISR_MAX 64
24
25
/* CONFIG OPTION: Maximum number of transfer (RX/TX) descriptors supported.
26
27
* Set this option to zero to allow flexible number of descriptors,
28
* requires dynamically allocation of driver structures.
29
30
/*#define RTBD_MAX 4096*/
31
#define RTBD_MAX 0
32
33
#ifdef __cplusplus
34
extern
"C"
35
#endif
36
37
/* Register GR1553B driver needed by RT driver */
38
extern
void
gr1553rt_register(
void
39
40
struct
gr1553rt_list
41
42
/* Descriptor read/written by hardware.
43
44
* Must be aligned to 16 byte boundary
45
46
struct
gr1553rt_bd
47
volatile
unsigned
int
ctrl;
/* 0x00 Control/Status word */
48
volatile
unsigned
int
dptr;
/* 0x04 Data Pointer */
49
volatile
unsigned
int
next;
/* 0x08 Next Descriptor in list */
50
volatile
unsigned
int
unused;
/* 0x0C UNUSED BY HARDWARE */
51
52
53
/* Sub address table entry, the hardware access */
54
struct
gr1553rt_sa
55
volatile
unsigned
int
ctrl;
/* 0x00 SUBADDRESS CONTROL WORD */
56
volatile
unsigned
int
txptr;
/* 0x04 TRANSMIT BD POINTER */
57
volatile
unsigned
int
rxptr;
/* 0x08 RECEIVE BD POINTER */
58
volatile
unsigned
int
unused;
59
60
61
/* Configuration of a RT-SubAddress-List */
62
struct
gr1553rt_list_cfg
63
unsigned
int
bd_cnt;
/* Number of hw-descriptors in list */
64
65
66
/* A TX or RX subaddress descriptor list */
67
struct
gr1553rt_list
68
short
listid;
/* ID/NUMBER of List. -1 unassigned */
69
short
subadr;
/* SubAddress. -1 when not scheduled */
70
void
*rt;
/* Scheduled on Device */
71
struct
gr1553rt_list_cfg
*cfg;
/* List configuration */
72
int
bd_cnt;
/* Number of Descriptors */
73
74
/* !!Must be last in data structure!!
75
* !!Array must at least be of length bd_cnt!!
76
77
unsigned
short
bds[0];
/* Array of BDIDs */
78
79
80
/* GR1553B-RT Driver configuration options used when calling gr1553rt_config().
81
82
* Note that if not custom addresses are given the driver will dynamically
83
* allocate memory for buffers.
84
* Note that if custom addresses with the LSB set, the address will be
85
* interpreted as a address accessible by hardware, and translated
86
* into an address used by CPU.
87
88
struct
gr1553rt_cfg
89
unsigned
char
rtaddress;
/* RT Address 0..30 */
90
91
/*** MODE CODE CONFIG ***/
92
unsigned
int
modecode;
/* Mode codes enable/disable/IRQ/EV-Log.
93
* Each modecode has a 2-bit cfg field.
94
* See Mode Code Control Register in
95
* hardware manual.
96
97
98
/*** TIME CONFIG ***/
99
unsigned
short
time_res;
/* Time tag resolution in us */
100
101
/*** SUBADDRESS TABLE CONFIG ***/
102
void
*satab_buffer;
/* Optional Custom buffer. Must be
103
* At least 16*32 bytes, and be aligned
104
* to 10-bit (1KB) boundary. Set to NULL
105
* to make driver allocate buffer.
106
107
108
/*** EVENT LOG CONFIG ***/
109
void
*evlog_buffer;
/* Optional Custom buffer */
110
int
evlog_size;
/* Length, must be a multiple of 2.
111
* If set to ZERO event log is disabled
112
113
114
/*** TRANSFER DESCRIPTOR CONFIG ***/
115
int
bd_count;
/* Number of transfer descriptors shared
116
* by all RX/TX sub-addresses */
117
void
*bd_buffer;
/* Optional Custom descriptor area.
118
* Must hold bd_count*32 bytes.
119
* If NULL, descriptors will be
120
* allocated dynamically. */
121
122
123
/* GR1553B-RT status indication, copied from the RT registers and stored
124
* here. Used when calling the gr1553rt_status() function.
125
126
struct
gr1553rt_status
127
unsigned
int
status;
/* RT Status word */
128
unsigned
int
bus_status;
/* BUS Status */
129
unsigned
short
synctime;
/* Time Tag of last sync with data */
130
unsigned
short
syncword;
/* Data of last mode code synchronize
131
* with data. */
132
unsigned
short
time_res;
/* Time resolution (set by config) */
133
unsigned
short
time;
/* Current Time Tag */
134
135
136
/* ISR callback definition for ERRORs detected in the GR1553B-RT interrupt
137
* handler.
138
139
* \param err Inidicate Error type. The IRQ flag register bit mask:
140
* Bit 9 - RT DMA ERROR
141
* Bit 10 - RT Table access error
142
* \param data Custom data assigned by user
143
144
typedef
void (*gr1553rt_irqerr_t)(
int
err,
void
*data);
145
146
/* ISR callback definition for modecodes that are configured to generate
147
* an IRQ. The callback is called from within the GR1553B-RT interrupt
148
* handler.
149
150
* \param mcode Mode code that caused this IRQ
151
* \param entry The raw Eventlog Entry
152
153
154
typedef
void (*gr1553rt_irqmc_t)(
int
mcode,
unsigned
int
entry
void
*data);
155
156
/* Transfer ISR callback definition. Called from GR1553B-RT interrupt handler
157
* when an interrupt has been generated and a event logged due to a 1553
158
* transfer to this RT.
159
160
* \param list List (Subaddress/TransferType) that caused IRQ
161
162
* \param bd_next Next Descriptor-entry index in the list (Subaddress/tr-type)
163
* This can be used to process all descriptors upto entry_next.
164
165
166
typedef
void (*gr1553rt_irq_t)(
167
struct
gr1553rt_list
*list,
168
unsigned
int
entry
169
int
bd_next,
170
void
*data
171
172
173
/* Configure a list according to configuration. Assign the list
174
* to a device, however not to a RT sub address yet. The rt
175
* is stored within list.
176
177
* \param rt RT Device driver identification, stored within list.
178
* \param list The list to configure
179
* \param cfg Configuration for list. Pointer to configuration is
180
* stored within list for later use.
181
182
extern
int
gr1553rt_list_init
183
184
void
*rt,
185
struct
gr1553rt_list
**plist,
186
struct
gr1553rt_list_cfg
*cfg
187
188
189
/* Assign an Error Interrupt handler. Before the handler is called the
190
* RT hardware is stopped/disabled. The handler is optional, if not assigned
191
* the ISR will still stop the RT upon error.
192
193
* Errors detected by the interrupt handler:
194
* - DMA error
195
* - Subaddress table access error
196
197
* \param func ISR called when an error causes an interrupt.
198
* \param data Custom data given as an argument when calling ISR
199
200
extern
int
gr1553rt_irq_err
201
202
void
*rt,
203
gr1553rt_irqerr_t func,
204
void
*data
205
206
207
/* Assign a ModeCode Interrupt handler callback. Called when a 1553 modecode
208
* transfer is logged and cause an IRQ. The modecode IRQ generation is
209
* configured from "struct gr1553rt_cfg" when calling gr1553rt_config().
210
211
* \param func ISR called when a modecode causes an interrupt.
212
213
214
extern
int
gr1553rt_irq_mc
215
216
void
*rt,
217
gr1553rt_irqmc_t func,
218
void
*data
219
220
221
/* Assign transfer interrupt handler callback. Called when a RX or TX
222
* transfer is logged and cause an interrupt, the function is called
223
* from the GR1553B-RT driver's ISR, in interrupt context.
224
225
* The callback can be installed per subaddress and transfer type.
226
* Subaddress 0 and 31 are not valid (gr1553rt_irq_mc() for modecodes).
227
228
* \param subadr Select subaddress (1-30)
229
* \param tx 1=TX subaddress, 0=RX subaddress
230
* \param func ISR called when subaddress of spcified transfer type
231
* causes an interrupt.
232
233
234
extern
int
gr1553rt_irq_sa
235
236
void
*rt,
237
int
subadr,
238
int
tx,
239
gr1553rt_irq_t func,
240
void
*data
241
242
243
#define GR1553RT_BD_FLAGS_IRQEN (1<<30)
244
/* Initialize a descriptor entry in a list. This is typically done
245
* prior to scheduling the list.
246
247
* \param entry_no Entry number in list (descriptor index in list)
248
* \param flags Enable IRQ when descriptor is accessed by setting
249
* argument GR1553RT_BD_FLAGS_IRQEN. Enabling IRQ on a
250
* descriptor basis will override SA-table IRQ config.
251
* \param dptr Data Pointer to RX or TX operation. The LSB indicate
252
* if the address must be translated into Hardware address
253
* - this is useful when a buffer close to CPU is used
254
* as a data pointer and the RT core is located over PCI.
255
* \param next Next Entry in list. Set to 0xffff for end of list. Set
256
* 0xfffe for next entry in list, wrap around to entry
257
* zero if entry_no is last descriptor in list (circular).
258
259
extern
int
gr1553rt_bd_init(
260
struct
gr1553rt_list
*list,
261
unsigned
short
entry_no,
262
unsigned
int
flags,
263
uint16_t *dptr,
264
unsigned
short
next
265
266
267
/* Manipulate/Read Control/Status and Data Pointer words of a buffer descriptor.
268
* If status is zero, the control/status word is accessed. If dptr is non-zero
269
* the data pointer word is accessed.
270
271
* \param list The list that the descriptor is located at
272
273
* \param entry_no The descriptor number accessed
274
275
* \param status IN/OUT. If zero no effect. If pointer is non-zero the
276
* value pointed to:
277
* IN: Written to Control/Status
278
* OUT: the value of the Control/Status word before writing.
279
280
* \param dptr IN/OUT. If zero no effect. If pointer is non-zero, the
281
* value pointed to:
282
* IN: non-zero: Descriptor data pointer will be updated with
283
* this value. Note that the LSB indicate if the address
284
* must be translated into hardware-aware address.
285
* OUT: The old data pointer is stored here.
286
287
extern
int
gr1553rt_bd_update(
288
struct
gr1553rt_list
*list,
289
int
entry_no,
290
unsigned
int
*status,
291
uint16_t **dptr
292
293
294
/* Get the next/current descriptor processed of a RT sub-address.
295
296
* \param subadr RT Subaddress
297
* \param txeno Pointer to where TX descriptor number is stored.
298
* \param rxeno Pointer to where RX descriptor number is stored.
299
300
extern
int
gr1553rt_indication(
void
*rt,
int
subadr,
int
*txeno,
int
*rxeno);
301
302
/* Take a GR1553RT hardware device identified by minor.
303
* A pointer is returned that is used internally by the GR1553RT
304
* driver, it is used as an input parameter 'rt' to all other
305
* functions that manipulate the hardware.
306
307
* This function initializes the RT hardware to a stopped/disable level.
308
309
extern
void
*gr1553rt_open(
int
minor);
310
311
/* Close and stop/disable the RT hardware. */
312
extern
void
gr1553rt_close(
void
*rt);
313
314
/* Configure the RT. The RT device must be configured once before
315
* started. A started RT device can not be configured.
316
317
* \param rt The RT to configure
318
* \param cfg Configuration parameters
319
320
extern
int
gr1553rt_config(
void
*rt,
struct
gr1553rt_cfg
*cfg);
321
322
/* Schedule a RX or TX list on a sub address. If a list has already been
323
* schduled on the subaddress and on the same transfer type (RX/TX), the
324
* old list is replaced with the list given here.
325
326
* \param subadr Subaddress to schedule list on
327
* \param tx Subaddress transfer type: 1=TX, 0=RX
328
* \param list Preconfigued RT list scheduled
329
330
extern
void
gr1553rt_sa_schedule(
331
void
*rt,
332
int
subadr,
333
int
tx,
334
struct
gr1553rt_list
*list
335
336
337
/* Set SubAdress options. One may for example Enable or Disable a sub
338
* address RX and/or TX. See hardware manual for SA-Table configuration
339
* options.
340
341
* \param subadr SubAddress to configure
342
* \param mask Bit mask of option-bits written to subaddress config
343
* \param options The new options written to subaddress config.
344
345
346
extern
void
gr1553rt_sa_setopts(
347
void
*rt,
348
int
subadr,
349
unsigned
int
mask,
350
unsigned
int
options
351
352
353
/* Get The Subaddress and transfer type of a scheduled list. Normally the
354
* application knows which subaddress the list is for.
355
356
* \param list List to lookup information for
357
* \param subadr Pointer to where the subaddress is stored
358
* \param tx Transfer type is stored here. 1=TX, 0=RX.
359
360
extern
void
gr1553rt_list_sa(
361
struct
gr1553rt_list
*list,
362
int
*subadr,
363
int
*tx
364
365
366
/* Start RT Communication
367
368
* Interrupts will be enabled. The RT enabled and the "RT-run-time"
369
* part of the API will be opened for the user and parts that need the
370
* RT to be stopped are no longer available. After the RT has been
371
* started the configuration function can not be called.
372
373
extern
int
gr1553rt_start(
void
*rt);
374
375
/* Get Status of the RT core. See data structure gr1553rt_status for more
376
* information about the result. It can be used to read out:
377
* - time information
378
* - sync information
379
* - bus & RT status
380
381
* \param status Pointer to where the status words will be stored. They
382
* are stored according to the gr1553rt_status data structure.
383
384
extern
void
gr1553rt_status
void
*rt,
struct
gr1553rt_status
*status);
385
386
/* Stop RT communication. Only possible to stop an already started RT device.
387
* Interrupts are disabled and the RT Enable bit cleared.
388
389
extern
void
gr1553rt_stop(
void
*rt);
390
391
/* Set RT vector and/or bit word.
392
393
* - Vector Word is used in response to "Transmit vector word" BC commands
394
* - Bit Word is used in response to "Transmit bit word" BC commands
395
396
397
* \param mask Bit-Mask, bits that are 1 will result in that bit in the
398
* words register being overwritten with the value of words
399
* \param words Bits 31..16: Bit Word. Bits 15..0: Vector Word.
400
401
* Operation:
402
* hw_words = (hw_words & ~mask) | (words & mask)
403
404
extern
void
gr1553rt_set_vecword(
405
void
*rt,
406
unsigned
int
mask,
407
unsigned
int
words
408
409
410
/* Set selectable bits of the "Bus Status Register". The bits written
411
* is determined by the "mask" bit-mask. Operation:
412
413
* bus_status = (bus_status & ~mask) | (sts & mask)
414
415
416
extern
void
gr1553rt_set_bussts(
void
*rt,
unsigned
int
mask,
unsigned
int
sts);
417
418
/* Read up to MAX number of entries in eventlog log.
419
420
* \param dst Destination address for event log entries
421
* \param max Maximal number of event log entries that an be stored into dst
422
423
* Return
424
* negative Failure
425
* zero No entries available at the moment
426
* positive Number of entries copied into dst
427
428
extern
int
gr1553rt_evlog_read(
void
*rt,
unsigned
int
*dst,
int
max);
429
430
#ifdef __cplusplus
431
432
#endif
433
434
#endif
entry
Definition:
mmu-config.c:40
gr1553rt_bd
Definition:
gr1553rt.h:46
gr1553rt_cfg
Definition:
gr1553rt.h:88
gr1553rt_list_cfg
Definition:
gr1553rt.h:62
gr1553rt_list
Definition:
gr1553rt.h:67
gr1553rt_sa
Definition:
gr1553rt.h:54
gr1553rt_status
Definition:
gr1553rt.h:126
