RTEMS 5.2
gr1553bm.h
1/* GR1553B BM driver
2 *
3 * COPYRIGHT (c) 2010.
4 * Cobham Gaisler AB.
5 *
6 * The license and distribution terms for this file may be
7 * found in the file LICENSE in this distribution or at
8 * http://www.rtems.org/license/LICENSE.
9 */
10
11#ifndef __GR1553BM_H__
12#define __GR1553BM_H__
13
14#ifdef __cplusplus
15extern "C" {
16#endif
17
18/* Register GR1553B driver needed by BM driver */
19extern void gr1553bm_register(void);
20
22 uint32_t time; /* bit31=1, bit 30=0 */
23 uint32_t data; /* bit31=0, bit 30=0 */
24};
25
26#define GR1553BM_ERROPTS_MANL 0x02
27#define GR1553BM_ERROPTS_UDWL 0x04
28#define GR1553BM_ERROPTS_IMCL 0x08
29#define GR1553BM_ERROPTS_ALL 0x0e
30
31/* Function used to implement a custom copy routine.
32 * Returns number of bytes the desctionation address
33 * should be incremented with.
34 *
35 * \param dst Optional Destination address
36 * \param src Source DMA address
37 * \param nentires Number of entries to be processed.
38 * \param data Custom Data (set by config)
39 */
40typedef int (*bmcopy_func_t)(
41 unsigned int dst,
42 struct gr1553bm_entry *src,
43 int nentries,
44 void *data
45 );
46
47/* IRQ function callback, called on BM DMA error */
48typedef void (*bmisr_func_t)(void *bm, void *data);
49
50/* BM driver configuration */
52
53 /*** Time options ***/
54
55 /* 8-bit time resolution, the BM will update the time according
56 * to this setting. 0 will make the time tag be of highest
57 * resolution (no division), 1 will make the BM increment the
58 * time tag once for two time ticks (div with 2), etc.
59 */
60 uint8_t time_resolution;
61
62 /* Enable Time Overflow IRQ handling. Setting this to 1
63 * makes the driver to update the 64-bit time by it self,
64 * it will use time overflow IRQ to detect when the 64-bit
65 * time counter must be incremented.
66 *
67 * If set to zero, the driver expect the user to call
68 * gr1553bm_time() regularly, it must be called more often
69 * than the time overflows to avoid an incorrect time.
70 */
71 int time_ovf_irq;
72
73
74
75 /*** Filtering options ***/
76
77 /* Bus error log options
78 *
79 * bit0,4-31 = reserved, set to zero
80 * Bit1 = Enables logging of Invalid mode code errors
81 * Bit2 = Enables logging of Unexpected Data errors
82 * Bit3 = Enables logging of Manchester/parity errors
83 */
84 unsigned int filt_error_options;
85
86 /* RT Address filtering bit mask. Each bit enables (if set)
87 * logging of a certain RT sub address. Bit 31 enables logging
88 * of broadcast messages.
89 */
90 unsigned int filt_rtadr;
91
92 /* RT Subaddress filtering bit mask, bit definition:
93 * 31: Enables logging of mode commands on subadr 31
94 * 1..30: BitN enables/disables logging of RT subadr N
95 * 0: Enables logging of mode commands on subadr 0
96 */
97 unsigned int filt_subadr;
98
99 /* Mode code Filter, is written into "BM RT Mode code filter"
100 * register, please see hardware manual for bit declarations.
101 */
102 unsigned int filt_mc;
103
104
105
106 /*** Buffer options ***/
107
108 /* Size of buffer in bytes, must be aligned to 8-byte
109 * The size is limited to max 4Mb.
110 */
111 unsigned int buffer_size;
112
113 /* Custom buffer, must be aligned to 8-byte and be of buffer_size
114 * length. If NULL dynamic memory allocation is used.
115 */
116 void *buffer_custom;
117
118 /* Custom Copy function, may be used to implement a more
119 * effective way of copying the DMA buffer. For example
120 * the DMA log may need to be compressed before copied
121 * onto a storage, this function can be used to avoid an
122 * extra copy.
123 */
124 bmcopy_func_t copy_func;
125
126 /* Optional Custom Data passed on to copy_func() */
127 void *copy_func_arg;
128
129
130
131 /*** Interrupt options ***/
132
133 /* Custom DMA error function, note that this function is called
134 * from Interrupt Context. Set to NULL to disable this callback.
135 */
136 bmisr_func_t dma_error_isr;
137
138 /* Optional Custom Data passed on to dma_error_isr() */
139 void *dma_error_arg;
140};
141
142/* Open BM device by instance number (minor)
143 *
144 * The return value is used as input parameter in all other function calls
145 * in the A
146 */
147extern void *gr1553bm_open(int minor);
148
149/* Close previously opened Bm device */
150extern void gr1553bm_close(void *bm);
151
152/* Configure the BM driver before starting */
153extern int gr1553bm_config(void *bm, struct gr1553bm_config *cfg);
154
155/* Start logging */
156extern int gr1553bm_start(void *bm);
157
158/* Get 64-bit 1553 Time. Low 24-bit time is acquired from BM hardware,
159 * the MSB is taken from a software counter internal to the driver. The
160 * counter is incremented every time the Time overflows by:
161 * - using "Time overflow" IRQ if enabled in user configuration
162 * - by checking IRQ flag (IRQ disabled), it is required that user
163 * calls this function before the next time overflow.
164 *
165 * The BM timer is limited to 24-bits, in order to handle overflows
166 * correctly and maintain a valid time an Interrupt handler is used
167 * or this function must be called when IRQ is not used.
168 *
169 * Update software time counters and return the current time.
170 */
171extern void gr1553bm_time(void *bm, uint64_t *time);
172
173/* Return zero when logging has not been started, non-zero when logging
174 * has been started
175 */
176extern int gr1553bm_started(void *bm);
177
178/* Check how many entries are currently stored in the BM Log DMA-area */
179extern int gr1553bm_available(void *bm, int *nentries);
180
181/* Stop logging */
182extern void gr1553bm_stop(void *bm);
183
184/* Read a maximum number of entries from LOG buffer. This function
185 * must be
186 *
187 * Arguments
188 * bm - Private pointer returned by gr1553bm_open()
189 * dst - Address where log data is written
190 * max - (IN/OUT) Maximum number of entires, when successfull
191 * the number of entries actually written is stored
192 * into the address of max.
193 *
194 * Result
195 * 0 = success
196 * -1 = fail. (may be due to BM logging not started)
197 */
198extern int gr1553bm_read(void *bm, struct gr1553bm_entry *dst, int *max);
199
200#ifdef __cplusplus
201}
202#endif
203
204#endif /* __GR1553BM_H__ */
Definition: gr1553bm.h:51
Definition: gr1553bm.h:21
