RTEMS 5.2
gr1553bc_list.h
1/*
2 * GR1553B BC driver, Descriptor LIST handling
3 *
4 * COPYRIGHT (c) 2010.
5 * Cobham Gaisler AB.
6 *
7 * The license and distribution terms for this file may be
8 * found in the file LICENSE in this distribution or at
9 * http://www.rtems.org/license/LICENSE.
10 */
11
12#ifndef __GR1553BC_LIST_H__
13#define __GR1553BC_LIST_H__
14
195#include <stdint.h>
196#include "gr1553bc.h"
197
198/**** CONFIGURATION OPTIONS ****/
199
200/* Define GR1553BC_TIMESLOT to make driver take care of time
201 * management of minor frames.
202 */
203#define GR1553BC_TIMESLOT
204
205#define GR1553BC_MINOR_MAX 256
206#define GR1553BC_SLOT_MAX 32
207
208#ifdef __cplusplus
209extern "C" {
210#endif
211
212struct gr1553bc_list;
213struct gr1553bc_major;
214struct gr1553bc_minor;
215struct gr1553bc_minor_cfg;
216struct gr1553bc_major_cfg;
217
219 int slot_cnt;
220 int timeslot; /* Total time of minor frame in us */
221};
222
224 int minor_cnt; /* Number of Minor Frames */
225 struct gr1553bc_minor_cfg minor_cfgs[1];
226};
227
229 unsigned char rt_timeout[31]; /* Number of us timeout tolerance per RT */
230 unsigned char bc_timeout; /* Number of us timeout tolerance of
231 * broadcast transfers */
232 int tropt_irq_on_err; /* Generate IRQ on transfer error */
233 int tropt_pause_on_err; /* Pause list on transfer error */
234 int async_list; /* Set to non-zero if asyncronous list*/
235};
236
237/* Default Configuration */
238extern struct gr1553bc_list_cfg gr1553bc_def_cfg;
239
240/* Complete list of all major frames */
242 void *_table_custom; /* Config option given by user */
243 void *_table; /* address of allocated bd-table */
244 unsigned int table_hw; /* Descriptor table base HW-ADR */
245 unsigned int table_cpu; /* Descriptor table base CPU-ADR */
246 int table_size; /* Descriptor Table Size */
247 void *bc; /* BC HW, needed for adr translation */
248 unsigned char rt_timeout[32]; /* Tolerance per RT, default 20us
249 * Note: 31 is for Broadcast */
250 uint32_t tropts; /* Transfer descriptor options:
251 * On transfer error the following bits
252 * do affect:
253 * - bit28 1=Generate IRQ
254 * - bit26 1=Pause transfer list
255 *
256 */
257 int async_list; /* async list or not */
258 int major_cnt; /* Number of Major frames */
259 struct gr1553bc_major *majors[1]; /* Var-Array of Major Pointers*/
260};
261
262/* Alloc a List with a maximum number of Major frames supported */
263extern int gr1553bc_list_alloc(struct gr1553bc_list **list, int max_major);
264
265/* Free List if allocated with gr1553bc_list_alloc() */
266extern void gr1553bc_list_free(struct gr1553bc_list *list);
267
268/* Configure Global List parameters
269 *
270 * \param list List to be configured and initialized.
271 * \param cfg List Configuration
272 * \param bc The BC hardware device description
273 * (only needed for address translation)
274 */
275extern int gr1553bc_list_config
276 (
277 struct gr1553bc_list *list,
278 struct gr1553bc_list_cfg *cfg,
279 void *bc
280 );
281
282/* Link a 'major' Major frame with next major frame
283 * The links affected:
284 * - major->next
285 * - major->minor[LAST]->next
286 */
287extern void gr1553bc_list_link_major(
288 struct gr1553bc_major *major,
289 struct gr1553bc_major *next
290 );
291
292/* Link in a Major frame into a BC list.
293 * Calls gr1553bc_list_link_major() to link major frame with major-1 and
294 * major+1. If ending or starting major frame the frame is wrapped around.
295 */
296extern int gr1553bc_list_set_major(
297 struct gr1553bc_list *list,
298 struct gr1553bc_major *major,
299 int no);
300
301/* Calculate the size required in the descriptor table by one minor frame. */
302extern int gr1553bc_minor_table_size(struct gr1553bc_minor *minor);
303
304/* Calculate the size required for the descriptor table.
305 */
306extern int gr1553bc_list_table_size(struct gr1553bc_list *list);
307
308/* Allocate an empty descriptor table from list description suitable for
309 * the BC given by 'bc'.
310 *
311 * \param bdtab_custom Custom Descriptor Allocation options:
312 * ZERO: Dynamically allocated by Driver (CPU near RAM)
313 * Non-Zero: Use provided address as BASE of BD-TABLE
314 * Non-Zero with LSB set: Same as Non-Zero but address
315 * is given as HW address (used with AMBA-over-PCI to
316 * to specify RAM location on PCI board).
317 */
318extern int gr1553bc_list_table_alloc
319 (
320 struct gr1553bc_list *list,
321 void *bdtab_custom
322 );
323
324/* Free descriptor table allocated with gr1553bc_list_table_alloc() */
325extern void gr1553bc_list_table_free(struct gr1553bc_list *list);
326
327/* Build an empty descriptor table from list description,
328 * the minor frames will be linked together.
329 */
330extern int gr1553bc_list_table_build(struct gr1553bc_list *list);
331
332/* Major Frame */
334 struct gr1553bc_major *next; /* Next Major Frame */
335 struct gr1553bc_major_cfg *cfg; /* User Config of Major frame */
336 struct gr1553bc_minor *minors[1]; /* Minor frames */
337};
338
339/* Minor Frame */
341 struct gr1553bc_minor *next; /* Next Minor Frame */
342 struct gr1553bc_minor_cfg *cfg; /* User Config of Minor frame */
343 uint32_t alloc; /* Descripts allocated */
344
345 /* Note: THIS POINTER MUST BE ALIGNED ON A 128-bit BOUNDARY */
346 union gr1553bc_bd *bds; /* Descriptors for this minor frame (CPU ADRS)*/
347};
348
349/* Alloc a Major/Minor frame skeleton according to the configuration structure.
350 * The descriptor table is not allocated.
351 */
352extern int gr1553bc_major_alloc_skel
353 (
354 struct gr1553bc_major **major,
355 struct gr1553bc_major_cfg *cfg
356 );
357
358/* Unique Message/Descriptor ID. Can be used to identify a Major or Minor
359 * Frame, or a Slot.
360 *
361 * - If minor_num is 0xff, the ID identifies a Major Frame
362 * - If slot_num is 0xff, the ID identifies a Minor Frame
363 * - If non of the above is true, the ID identifies a specific Slot
364 */
365#define GR1553BC_ID(major_num, minor_num, slot_num) \
366 ((((major_num)<<16)&0xff0000) | (((minor_num)<<8)&0xff00) | \
367 ((slot_num) & 0xff))
368#define GR1553BC_MINOR_ID(major_num, minor_num) \
369 GR1553BC_ID(major_num, minor_num, 0xff)
370#define GR1553BC_MAJOR_ID(major_num) \
371 GR1553BC_ID(major_num, 0xff, 0xff)
372
373#define GR1553BC_MAJID_FROM_ID(mid) (((mid) >> 16) & 0xff)
374#define GR1553BC_MINID_FROM_ID(mid) (((mid) >> 8) & 0xff)
375#define GR1553BC_SLOTID_FROM_ID(mid) ((mid) & 0xff)
376#define GR1553BC_ID_SET_SLOT(mid, slot_num) (((mid) & ~0xff) | ((slot_num) & 0xff))
377
378extern struct gr1553bc_major *gr1553bc_major_from_id
379 (
380 struct gr1553bc_list *list,
381 int mid
382 );
383
384extern struct gr1553bc_minor *gr1553bc_minor_from_id
385 (
386 struct gr1553bc_list *list,
387 int mid
388 );
389
390/* Get free time left of minor frame identified by MID 'mid' */
391extern int gr1553bc_list_freetime(struct gr1553bc_list *list, int mid);
392
393/* Get free time left of minor frame */
394extern int gr1553bc_minor_freetime(struct gr1553bc_minor *minor);
395
396/* Allocate a time slot on a minor frame, major/minor frame is identified
397 * by MID. The 'mid' is a input/ouput parameter, the resulting slot taken
398 * will be placed in 'mid', a pointer to the allocated descriptor is stored
399 * into bd.
400 *
401 * Major/Minor must be specified by MID, if slot is specified that slot will
402 * be allocated, if slot is 0xff, then the first free slot is allocated.
403 *
404 * The function fails (return negative) if timeslot is longer than remaining
405 * time in minor frame, if no more slots are available in minor frame, if
406 * MID points to a bad major/minor or major/minor/slot.
407 */
408extern int gr1553bc_slot_alloc(
409 struct gr1553bc_list *list,
410 int *mid,
411 int timeslot,
412 union gr1553bc_bd **bd
413 );
414/* Same as gr1553bc_slot_alloc but identifies a minor instead of list.
415 * The major/minor part of MID is ignored.
416 */
417extern int gr1553bc_slot_alloc2(
418 struct gr1553bc_minor *minor,
419 int *mid,
420 int timeslot,
421 union gr1553bc_bd **bd
422 );
423
424/* Free message slot and the time associated with it. The time taken by the
425 * message slot is added to the END TIME descriptor, if managed by the driver
426 * for this minor frame. The descriptor will be
427 */
428extern int gr1553bc_slot_free(struct gr1553bc_list *list, int mid);
429extern int gr1553bc_slot_free2(struct gr1553bc_minor *minor, int mid);
430
431/* Find MID from Descriptor pointer
432 *
433 * In the end of each minor frame is a unconditional jump
434 * to next minor frame descriptor. The hardware does not
435 * use the last 8 bytes of conditional descriptors, in the
436 * padding area a MID is stored so that we can lookup the
437 * MID of a descriptor. This function finds the jump
438 * descriptor and subtracs the offset from it.
439 *
440 * A faster way of looking up can be implemented if the
441 * list is symertical, however in the current setup we
442 * allow different numbers of slots in minor frames, and
443 * different number of minor frames in a major frame.
444 *
445 * \param bd IN: Descriptor to lookup MID of (CPU address of BD)
446 * \param mid OUT: Pointer to where Message-ID (Slot-ID) will be stored
447 * \param async OUT: Function will store non-zero value if BD belogs to
448 * async list.
449 */
450extern int gr1553bc_mid_from_bd(
451 union gr1553bc_bd *bd,
452 int *mid,
453 int *async
454 );
455
456/********** TRANSFER DESCRIPTOR MANIPULATION **********/
457
458/* Get pointer to descriptor entry from MID. */
459extern union gr1553bc_bd *gr1553bc_slot_bd
460 (
461 struct gr1553bc_list *list,
462 int mid
463 );
464
465/* IRQ function */
466typedef void (*bcirq_func_t)(union gr1553bc_bd *bd, void *data);
467
468/* Create unconditional IRQ customly defined location.
469 * The IRQ is disabled, enable it with gr1553bc_slot_irq_enable().
470 */
471extern int gr1553bc_slot_irq_prepare
472 (
473 struct gr1553bc_list *list,
474 int mid,
475 bcirq_func_t func,
476 void *data
477 );
478
479/* Enable previously prepared unconditional IRQ */
480extern int gr1553bc_slot_irq_enable(struct gr1553bc_list *list, int mid);
481
482/* Disable unconditional IRQ point, changed to unconditional JUMP
483 * to descriptor following.
484 * After disabling it it can be enabled again, or freed.
485 */
486extern int gr1553bc_slot_irq_disable(struct gr1553bc_list *list, int mid);
487
488/* Create custom jump to descriptor, conditional or unconditional, see
489 * hardware manual for conditions.
490 *
491 * set conditional to GR1553BC_UNCOND_JMP for unconditional jump.
492 */
493extern int gr1553bc_slot_jump
494 (
495 struct gr1553bc_list *list,
496 int mid,
497 uint32_t condition,
498 int to_mid
499 );
500
501/* Create a dummy transfer, paused until external trigger is set. The
502 * Slot is will have the dummy bit set, no transfer will take place.
503 */
504extern int gr1553bc_slot_exttrig(struct gr1553bc_list *list, int mid);
505
506/* Create a transfer on a previous allocated descriptor. It is assumed
507 * that the descriptor has been initialized empty before calling this
508 * function, this is to avoid races.
509 *
510 * The settings that are controlled on a global level (and not
511 * by this function):
512 * - IRQ after transfer error
513 * - IRQ after transfer (not supported, insert separate IRQ slot after this)
514 * - Pause schedule after transfer error
515 * - Pause schedule after transfer (not supported)
516 * - slot time optional (set when MID allocated), otherwise 0
517 * - (OPTIONAL) Dummy Bit, set using slot_empty() or ..._TT_DUMMY
518 * - RT timeout tolerance (managed per RT)
519 *
520 * Input Parameters:
521 * - Retry Mode (options)
522 * - Number of retires (options)
523 * - Bus selection (A or B) (options)
524 * - dummy bit (options)
525 * - transfer type (tt)
526 * - rt src/dst address (tt)
527 * - RT subaddress (tt)
528 * - word count (tt)
529 * - mode code (tt)
530 * - data pointer (dptr)
531 *
532 *
533 * See macros defined in this header file for creating transfer types (tt)
534 * and word count etc.
535 *
536 * See macros defined in this header file for creating the mask of options.
537 *
538 * Note that if bit0 (LSB) of dptr is set, then the address is translated into
539 * hardware address, otherwise the dptr is assumed to be accessible from the
540 * 1553 core. This is an option only for AMBA-over-PCI.
541 */
542extern int gr1553bc_slot_transfer(
543 struct gr1553bc_list *list,
544 int mid,
545 int options,
546 int tt,
547 uint16_t *dptr);
548
549/* Remove or set dummy bit of a transfer descriptor
550 * Bit31 of *dummy is written to the dummy bit, the
551 * old descriptor value is stored into *dummy.
552 */
553extern int gr1553bc_slot_dummy(
554 struct gr1553bc_list *list,
555 int mid,
556 unsigned int *dummy);
557
558/* Make a slot empty (BC will not generate bus transfers), time slot
559 * allocated is untouched (if assigned).
560 */
561extern int gr1553bc_slot_empty(struct gr1553bc_list *list, int mid);
562
563/* Transfer descriptor status and/or update Transfer descriptor data pointer.
564 *
565 * Read and/or write Status of a slot. Writing the status word may be
566 * used by software to indicate that result has been handled, or bit 31
567 * may be written 1 telling software that when it reaches 0, then BC
568 * has executed the request.
569 *
570 * Operation:
571 * bd->status = *stat & (bd->status 0xffffff) | (*stat & 0x80000000);
572 * *stat = Value of bd->status before rewrite.
573 *
574 * Note that the status word is not written when *stat is zero.
575 *
576 * Note that if bit0 (LSB) of dptr is set, then the address is translated into
577 * hardware address, otherwise the dptr is assumed to be accessible from the
578 * 1553 core. This is an option only for AMBA-over-PCI.
579 */
580extern int gr1553bc_slot_update(
581 struct gr1553bc_list *list,
582 int mid,
583 uint16_t *dptr,
584 unsigned int *stat);
585
586/* Modify a transfer descriptor in any way,
587 *
588 * flags:
589 * bit[N=0..3]: 1 = set BD wordN according to argument wordN,
590 * 0 = do not modify BD wordN
591 */
592extern int gr1553bc_slot_raw
593 (
594 struct gr1553bc_list *list,
595 int mid,
596 unsigned int flags,
597 uint32_t word0,
598 uint32_t word1,
599 uint32_t word2,
600 uint32_t word3
601 );
602
603
604/***** Macros to create BC Transfer Types (tt) for gr1553bc_slot_transfer() *****/
605
606/* WRITE TO RT (BC-to-RT) */
607#define GR1553BC_BC2RT(rtadr, subadr, word_count) \
608 ((rtadr<<11) | (subadr<<5) | (0x1f<<21) | (0<<10) | \
609 ((word_count>=32) ? 0 : word_count))
610
611/* READ FROM RT (RT-to-BC) */
612#define GR1553BC_RT2BC(rtadr, subadr, word_count) \
613 ((rtadr<<11) | (subadr<<5) | (0x1f<<21) | (1<<10) | \
614 ((word_count>=32) ? 0 : word_count))
615
616/* RT(TX) WRITE TO RT(RX) (RT-to-RT) */
617#define GR1553BC_RT2RT(tx_rtadr, tx_subadr, rx_rtadr, rx_subadr, word_count) \
618 ((rx_rtadr<<11) | (rx_subadr<<5) | \
619 (tx_rtadr<<21) | (tx_subadr<<16) | \
620 (0<<10) | \
621 ((word_count>=32) ? 0 : word_count))
622
623/* Mode command without data. (BC-to-RT)
624 * Mode code: 0,1,2,3,4,5,6,7 or 8.
625 */
626#define GR1553BC_MC_NODATA(rtadr, modecode) \
627 ((rtadr<<11) | (0x1f<<5) | (0x1f<<21) | \
628 (modecode<<0) | (1<<10))
629
630/* Mode command with 4 byte data (RT-to-BC)
631 * Mode code: 16, 18 or 19.
632 */
633#define GR1553BC_MC_RT2BC(rtadr, modecode) \
634 ((rtadr<<11) | (0x1f<<5) | (0x1f<<21) | \
635 (modecode<<0) | (1<<10))
636
637/* Mode command with 4 byte data (BC-to-RT)
638 * Mode code: 17, 20 or 21.
639 */
640#define GR1553BC_MC_BC2RT(rtadr, modecode) \
641 ((rtadr<<11) | (0x1f<<5) | (0x1f<<21) | \
642 (modecode<<0) | (0<<10))
643
644/* Broadcast to all RTs, to a specific subaddress (BC-to-RTs) */
645#define GR1553BC_BC_BC2RT(subadr, word_count) \
646 ((0x1f<<11) | (subadr<<5) | (0x1f<<21) | \
647 (0<<10) | \
648 ((word_count>=32) ? 0 : word_count))
649
650/* Request RT to broadcast to all RTs, to a specific subaddress (RT-to-RTs) */
651#define GR1553BC_BC_RT2RT(tx_rtadr, tx_subadr, rx_subadr, word_count) \
652 ((0x1f<<11) | (rx_subadr<<5) | \
653 (tx_rtadr<<21) | (tx_subadr<<16) | \
654 (0<<10) | \
655 ((word_count>=32) ? 0 : word_count))
656
657/* Broadcast mode command without data (BC-to-RTs)
658 * Mode code: 1,3,4,5,6,7 or 8
659 */
660#define GR1553BC_BC_MC_NODATA(modecode) \
661 ((0x1f<<11) | (0x1f<<5) | (0x1f<<21) | \
662 ((modecode)<<0) | (1<<10))
663
664/* Broadcast mode command with 4 byte data (BC-to-RTs)
665 * Mode code: 17, 20 or 21
666 */
667#define GR1553BC_BC_MC_BC2RT(modecode) \
668 ((0x1f<<11) | (0x1f<<5) | (0x1f<<21) | \
669 ((modecode)<<0) | (0<<10))
670
671
672/***** Macros to create BC options (options) for gr1553bc_slot_transfer() *****/
673
674/* Dummy (BC does no bus trasactions) */
675#define GR1553BC_OPT_DUMMY (1<<1)
676
677/* Retry modes */
678#define GR1553BC_RETRY_SAME 0x0 /* Retry on the same bus only */
679#define GR1553BC_RETRY_ALTER 0x1 /* Retry alternating on both busses */
680#define GR1553BC_RETRY_ATTEMPT 0x2 /* Many attepts first on original
681 * bus then on other bus */
682/* Number of retires supported */
683#define GR1553BC_RETRY_CNT_MAX 6
684
685/* Dummy bit: No transfer
686 * Bus bit: 0=A, 1=B
687 * Exttrig bit: Wait for external trigger (used for timesync)
688 * Exclusive bit: 1=Don't allow other messages in this time slot.
689 */
690#define GR1553BC_OPTIONS(dummy, exttrig, exclusive, retrymode, nretry, bus) \
691 ((((exttrig) & 0x1) << 30) | (((exclusive) & 0x1) << 29) | \
692 ((retrymode) << 23) | ((nretry) << 20) | \
693 ((bus) & 1) | (((dummy) & 0x1) << 1))
694
695#define GR1553BC_OPTIONS_BUSA GR1553BC_OPTIONS(0,0,0,GR1553BC_RETRY_SAME,0,0)
696#define GR1553BC_OPTIONS_BUSB GR1553BC_OPTIONS(0,0,0,GR1553BC_RETRY_SAME,0,1)
697#define GR1553BC_OPTIONS_BUSA_DUM GR1553BC_OPTIONS(1,0,0,GR1553BC_RETRY_SAME,0,0)
698#define GR1553BC_OPTIONS_BUSB_DUM GR1553BC_OPTIONS(1,0,0,GR1553BC_RETRY_SAME,0,1)
699
700/* Show parts of a list - this is for debugging only */
701extern void gr1553bc_show_list(struct gr1553bc_list *list, int options);
702
703#ifdef __cplusplus
704}
705#endif
706
707#endif /* __GR1553BC_LIST_H__ */
Definition: gr1553bc_list.h:228
Definition: gr1553bc_list.h:241
Definition: gr1553bc_list.h:223
Definition: gr1553bc_list.h:333
Definition: gr1553bc_list.h:218
Definition: gr1553bc_list.h:340
Definition: gr1553bc.h:72
