RTEMS 5.2
gr1553b.h
1/* GR1553B driver, used by BC, RT and/or BM driver
2 *
3 * COPYRIGHT (c) 2010.
4 * Cobham Gaisler AB.
5 *
6 * The license and distribution terms for this file may be
7 * found in the file LICENSE in this distribution or at
8 * http://www.rtems.org/license/LICENSE.
9 *
10 * OVERVIEW
11 * ========
12 * This driver controls the GR1553B device regardless of interfaces supported
13 * (BC, RT and/or BM). The device can be located at an on-chip AMBA or an
14 * AMBA-over-PCI bus. This driver provides an interface for the BC, RT and BM
15 * drivers to use. Since the different interfaces are accessed over the same
16 * register interface on the same core, the other drivers must share a GR1553B
17 * device. Any combination of interface functionality is supported, but the RT
18 * and BC functionality can nnot be used simultaneously due to hardware
19 * limitation.
20 *
21 */
22
23#ifndef __GR1553B_H__
24#define __GR1553B_H__
25
26#include <stdint.h>
27
28#ifdef __cplusplus
29extern "C" {
30#endif
31
32/* The GR1553B registers */
34 /* Common Registers */
35 volatile uint32_t irq; /* 0x00 IRQ register */
36 volatile uint32_t imask; /* 0x04 IRQ enable mask */
37 int unused0[(0x10-0x08)/4];
38 volatile uint32_t hwcfg; /* 0x10 HW config register */
39
40 int unused1[(0x40-0x14)/4]; /* Padding */
41
42 /* BC Registers */
43 volatile uint32_t bc_stat; /* 0x40 BC status */
44 volatile uint32_t bc_ctrl; /* 0x44 BC Action register */
45 volatile uint32_t bc_bd; /* 0x48 BC transfer list pointer */
46 volatile uint32_t bc_abd; /* 0x4c BC async list pointer */
47 volatile uint32_t bc_timer; /* 0x50 BC timer register */
48 volatile uint32_t bc_wake; /* 0x54 BC wakeup control register */
49 volatile uint32_t bc_irqptr; /* 0x58 BC transfer IRQ pointer */
50 volatile uint32_t bc_busmsk; /* 0x5C BC per-RT bus mask register */
51
52 int unused2[(0x68-0x60)/4]; /* Padding */
53
54 volatile uint32_t bc_slot; /* 0x68 BC Current BD pointer */
55 volatile uint32_t bc_aslot; /* 0x6c BC Current async BD pointer */
56
57 int unused3[(0x80-0x70)/4]; /* Padding */
58
59 /* RT Registers */
60 volatile uint32_t rt_stat; /* 0x80 RT status */
61 volatile uint32_t rt_cfg; /* 0x84 RT config register */
62 volatile uint32_t rt_stat2; /* 0x88 RT bus status bits */
63 volatile uint32_t rt_statw; /* 0x8c RT status words */
64 volatile uint32_t rt_sync; /* 0x90 RT bus synchronize */
65 volatile uint32_t rt_tab; /* 0x94 RT subaddress table base */
66 volatile uint32_t rt_mcctrl; /* 0x98 RT valid mode code mask */
67 int unused4[(0xa4-0x9c)/4];
68 volatile uint32_t rt_ttag; /* 0xa4 RT time tag register */
69 int unused5; /* 0xa8 RESERVED */
70 volatile uint32_t rt_evsz; /* 0xac RT event log end pointer */
71 volatile uint32_t rt_evlog; /* 0xb0 RT event log position */
72 volatile uint32_t rt_evirq; /* 0xb4 RT event log IRQ position */
73
74 int unused6[(0xc0-0xb8)/4]; /* Padding */
75
76 /* BM Registers */
77 volatile uint32_t bm_stat; /* 0xc0 BM status */
78 volatile uint32_t bm_ctrl; /* 0xc4 BM control register */
79 volatile uint32_t bm_adr; /* 0xc8 BM address filter */
80 volatile uint32_t bm_subadr; /* 0xcc BM subaddress filter */
81 volatile uint32_t bm_mc; /* 0xd0 BM mode code filter */
82 volatile uint32_t bm_start; /* 0xd4 BM log start address */
83 volatile uint32_t bm_end; /* 0xd8 BM log size/alignment mask */
84 volatile uint32_t bm_pos; /* 0xdc BM log position */
85 volatile uint32_t bm_ttag; /* 0xe0 BM time tag register */
86};
87
88#define GR1553BC_KEY 0x15520000
89#define GR1553RT_KEY 0x15530000
90
91/* IRQ Definitions */
92#define GR1553BC_IRQLOG_SIZE 64
93#define GR1553BC_IRQLOG_CNT (GR1553BC_IRQLOG_SIZE/sizeof(uint32_t))
94
95/*** IRQ Flag Register ***/
96#define GR1553B_IRQ_BCEV_BIT 0
97#define GR1553B_IRQ_BCD_BIT 1
98#define GR1553B_IRQ_BCWK_BIT 2
99#define GR1553B_IRQ_RTEV_BIT 8
100#define GR1553B_IRQ_RTD_BIT 9
101#define GR1553B_IRQ_RTTE_BIT 10
102#define GR1553B_IRQ_BMD_BIT 16
103#define GR1553B_IRQ_BMTOF_BIT 17
104
105#define GR1553B_IRQ_BCEV (1<<GR1553B_IRQ_BCEV_BIT)
106#define GR1553B_IRQ_BCD (1<<GR1553B_IRQ_BCD_BIT)
107#define GR1553B_IRQ_BCWK (1<<GR1553B_IRQ_BCWK_BIT)
108#define GR1553B_IRQ_RTEV (1<<GR1553B_IRQ_RTEV_BIT)
109#define GR1553B_IRQ_RTD (1<<GR1553B_IRQ_RTD_BIT)
110#define GR1553B_IRQ_RTTE (1<<GR1553B_IRQ_RTTE_BIT)
111#define GR1553B_IRQ_BMD (1<<GR1553B_IRQ_BMD_BIT)
112#define GR1553B_IRQ_BMTOF (1<<GR1553B_IRQ_BMTOF_BIT)
113
114/*** IRQ Enable Register ***/
115#define GR1553B_IRQEN_BCEVE_BIT 0
116#define GR1553B_IRQEN_BCDE_BIT 1
117#define GR1553B_IRQEN_BCWKE_BIT 2
118#define GR1553B_IRQEN_RTEVE_BIT 8
119#define GR1553B_IRQEN_RTDE_BIT 9
120#define GR1553B_IRQEN_RTTEE_BIT 10
121#define GR1553B_IRQEN_BMDE_BIT 16
122#define GR1553B_IRQEN_BMTOE_BIT 17
123
124#define GR1553B_IRQEN_BCEVE (1<<GR1553B_IRQEN_BCEVE_BIT)
125#define GR1553B_IRQEN_BCDE (1<<GR1553B_IRQEN_BCDE_BIT)
126#define GR1553B_IRQEN_BCWKE (1<<GR1553B_IRQEN_BCWKE_BIT)
127#define GR1553B_IRQEN_RTEVE (1<<GR1553B_IRQEN_RTEVE_BIT)
128#define GR1553B_IRQEN_RTDE (1<<GR1553B_IRQEN_RTDE_BIT)
129#define GR1553B_IRQEN_RTTEE (1<<GR1553B_IRQEN_RTTEE_BIT)
130#define GR1553B_IRQEN_BMDE (1<<GR1553B_IRQEN_BMDE_BIT)
131#define GR1553B_IRQEN_BMTOE (1<<GR1553B_IRQEN_BMTOE_BIT)
132
133/*** BC Status Register ***/
134#define GR1553B_BC_STAT_SCST_BIT 0
135#define GR1553B_BC_STAT_SCADL_BIT 3
136#define GR1553B_BC_STAT_ASST_BIT 8
137#define GR1553B_BC_STAT_ASADL_BIT 11
138#define GR1553B_BC_STAT_BCSUP_BIT 31
139
140#define GR1553B_BC_STAT_SCST (0x3<<GR1553B_BC_STAT_SCST_BIT)
141#define GR1553B_BC_STAT_SCADL (0x1f<<GR1553B_BC_STAT_SCADL_BIT)
142#define GR1553B_BC_STAT_ASST (0x3<<GR1553B_BC_STAT_ASST_BIT)
143#define GR1553B_BC_STAT_ASADL (0x1f<<GR1553B_BC_STAT_ASADL_BIT)
144#define GR1553B_BC_STAT_BCSUP (1<<GR1553B_BC_STAT_BCSUP_BIT)
145
146/*** BC Action Register ***/
147#define GR1553B_BC_ACT_SCSRT_BIT 0
148#define GR1553B_BC_ACT_SCSUS_BIT 1
149#define GR1553B_BC_ACT_SCSTP_BIT 2
150#define GR1553B_BC_ACT_SETT_BIT 3
151#define GR1553B_BC_ACT_CLRT_BIT 4
152#define GR1553B_BC_ACT_ASSRT_BIT 8
153#define GR1553B_BC_ACT_ASSTP_BIT 9
154#define GR1553B_BC_ACT_BCKEY_BIT 16
155
156#define GR1553B_BC_ACT_SCSRT (1<<GR1553B_BC_ACT_SCSRT_BIT)
157#define GR1553B_BC_ACT_SCSUS (1<<GR1553B_BC_ACT_SCSUS_BIT)
158#define GR1553B_BC_ACT_SCSTP (1<<GR1553B_BC_ACT_SCSTP_BIT)
159#define GR1553B_BC_ACT_SETT (1<<GR1553B_BC_ACT_SETT_BIT)
160#define GR1553B_BC_ACT_CLRT (1<<GR1553B_BC_ACT_CLRT_BIT)
161#define GR1553B_BC_ACT_ASSRT (1<<GR1553B_BC_ACT_ASSRT_BIT)
162#define GR1553B_BC_ACT_ASSTP (1<<GR1553B_BC_ACT_ASSTP_BIT)
163#define GR1553B_BC_ACT_BCKEY (0xffff<<GR1553B_BC_ACT_BCKEY_BIT)
164
165/*** BC Timer Register ***/
166#define GR1553B_BC_TIMER_SCTM_BIT 0
167
168#define GR1553B_BC_TIMER_SCTM (0xffffff<<GR1553B_BC_TIMER_SCTM_BIT)
169
170/*** BC Wake-up control Register ***/
171#define GR1553B_BC_WAKE_TIME_BIT 0
172#define GR1553B_BC_WAKE_WKEN_BIT 31
173
174#define GR1553B_BC_WAKE_TIME (0xffffff<<GR1553B_BC_WAKE_TIME_BIT)
175#define GR1553B_BC_WAKE_WKEN (1<GR1553B_BC_WAKE_WKEN_BIT)
176
177/*** RT status Register ***/
178#define GR1553B_RT_STAT_RUN_BIT 0
179#define GR1553B_RT_STAT_SHDB_BIT 1
180#define GR1553B_RT_STAT_SHDA_BIT 2
181#define GR1553B_RT_STAT_ACT_BIT 3
182#define GR1553B_RT_STAT_RTSUP_BIT 31
183
184#define GR1553B_RT_STAT_RUN (1<<GR1553B_RT_STAT_RUN_BIT)
185#define GR1553B_RT_STAT_SHDB (1<<GR1553B_RT_STAT_SHDB_BIT)
186#define GR1553B_RT_STAT_SHDA (1<<GR1553B_RT_STAT_SHDA_BIT)
187#define GR1553B_RT_STAT_ACT (1<<GR1553B_RT_STAT_ACT_BIT)
188#define GR1553B_RT_STAT_RTSUP (1<<GR1553B_RT_STAT_RTSUP_BIT)
189
190
191/*** RT Config Register ***/
192#define GR1553B_RT_CFG_RTEN_BIT 0
193#define GR1553B_RT_CFG_RTADDR_BIT 1
194#define GR1553B_RT_CFG_RTKEY_BIT 16
195
196#define GR1553B_RT_CFG_RTEN (1<<GR1553B_RT_CFG_RTEN_BIT)
197#define GR1553B_RT_CFG_RTADDR (1<<GR1553B_RT_CFG_RTADDR_BIT)
198#define GR1553B_RT_CFG_RTKEY (0xffff<<GR1553B_RT_CFG_RTKEY_BIT)
199
200/*** RT Bus Status Register ***/
201#define GR1553B_RT_STAT2_TFLG_BIT 0
202#define GR1553B_RT_STAT2_DBCA_BIT 1
203#define GR1553B_RT_STAT2_SSF_BIT 2
204#define GR1553B_RT_STAT2_BUSY_BIT 3
205#define GR1553B_RT_STAT2_SREQ_BIT 4
206#define GR1553B_RT_STAT2_TFDE_BIT 8
207
208#define GR1553B_RT_STAT2_TFLG (1<<GR1553B_RT_STAT2_TFLG_BIT)
209#define GR1553B_RT_STAT2_DBCA (1<<GR1553B_RT_STAT2_DBCA_BIT)
210#define GR1553B_RT_STAT2_SSF (1<<GR1553B_RT_STAT2_SSF_BIT)
211#define GR1553B_RT_STAT2_BUSY (1<<GR1553B_RT_STAT2_BUSY_BIT)
212#define GR1553B_RT_STAT2_SREQ (1<<GR1553B_RT_STAT2_SREQ_BIT)
213#define GR1553B_RT_STAT2_TFDE (1<<GR1553B_RT_STAT2_TFDE_BIT)
214
215/*** RT Status Words Register ***/
216#define GR1553B_RT_STATW_VECW_BIT 0
217#define GR1553B_RT_STATW_BITW_BIT 16
218
219#define GR1553B_RT_STATW_VECW (0xffff<<GR1553B_RT_STATW_VECW_BIT)
220#define GR1553B_RT_STATW_BITW (0xffff<<GR1553B_RT_STATW_BITW_BIT)
221
222/*** RT Sync Register ***/
223#define GR1553B_RT_SYNC_SYD_BIT 0
224#define GR1553B_RT_SYNC_SYTM_BIT 16
225
226#define GR1553B_RT_SYNC_SYD (0xffff<<GR1553B_RT_SYNC_SYD_BIT)
227#define GR1553B_RT_SYNC_SYTM (0xffff<<GR1553B_RT_SYNC_SYTM_BIT)
228
229/*** RT Sub adress table Register ***/
230#define GR1553B_RT_TAB_SATB_BIT 0
231
232#define GR1553B_RT_TAB_SATB (0xffff<<GR1553B_RT_TAB_SATB_BIT)
233
234/*** RT Mode code control Register ***/
235#define GR1553B_RT_MCCTRL_S_BIT 0
236#define GR1553B_RT_MCCTRL_SB_BIT 2
237#define GR1553B_RT_MCCTRL_SD_BIT 4
238#define GR1553B_RT_MCCTRL_SDB_BIT 6
239#define GR1553B_RT_MCCTRL_TS_BIT 8
240#define GR1553B_RT_MCCTRL_TSB_BIT 10
241#define GR1553B_RT_MCCTRL_TVW_BIT 12
242#define GR1553B_RT_MCCTRL_TBW_BIT 14
243#define GR1553B_RT_MCCTRL_DBC_BIT 16
244#define GR1553B_RT_MCCTRL_IST_BIT 18
245#define GR1553B_RT_MCCTRL_ISTB_BIT 20
246#define GR1553B_RT_MCCTRL_ITF_BIT 22
247#define GR1553B_RT_MCCTRL_ITFB_BIT 24
248#define GR1553B_RT_MCCTRL_RRT_BIT 26
249#define GR1553B_RT_MCCTRL_RRTB_BIT 28
250
251#define GR1553B_RT_MCCTRL_S (1<<GR1553B_RT_MCCTRL_S_BIT)
252#define GR1553B_RT_MCCTRL_SB (1<<GR1553B_RT_MCCTRL_SB_BIT)
253#define GR1553B_RT_MCCTRL_SD (1<<GR1553B_RT_MCCTRL_SD_BIT)
254#define GR1553B_RT_MCCTRL_SDB (1<<GR1553B_RT_MCCTRL_SDB_BIT)
255#define GR1553B_RT_MCCTRL_TS (1<<GR1553B_RT_MCCTRL_TS_BIT)
256#define GR1553B_RT_MCCTRL_TSB (1<<GR1553B_RT_MCCTRL_TSB_BIT)
257#define GR1553B_RT_MCCTRL_TVW (1<<GR1553B_RT_MCCTRL_TVW_BIT)
258#define GR1553B_RT_MCCTRL_TBW (1<<GR1553B_RT_MCCTRL_TBW_BIT)
259#define GR1553B_RT_MCCTRL_DBC (1<<GR1553B_RT_MCCTRL_DBC_BIT)
260#define GR1553B_RT_MCCTRL_IST (1<<GR1553B_RT_MCCTRL_IST_BIT)
261#define GR1553B_RT_MCCTRL_ISTB (1<<GR1553B_RT_MCCTRL_ISTB_BIT)
262#define GR1553B_RT_MCCTRL_ITF (1<<GR1553B_RT_MCCTRL_ITF_BIT)
263#define GR1553B_RT_MCCTRL_ITFB (1<<GR1553B_RT_MCCTRL_ITFB_BIT)
264#define GR1553B_RT_MCCTRL_RRT (1<<GR1553B_RT_MCCTRL_RRT_BIT)
265#define GR1553B_RT_MCCTRL_RRTB (1<<GR1553B_RT_MCCTRL_RRTB_BIT)
266
267/*** RT Time Tag control Register ***/
268#define GR1553B_RT_TTAG_TVAL_BIT 0
269#define GR1553B_RT_TTAG_TRES_BIT 16
270
271#define GR1553B_RT_TTAG_TVAL (0xffff<<GR1553B_RT_TTAG_TVAL_BIT)
272#define GR1553B_RT_TTAG_TRES (0xffff<<GR1553B_RT_TTAG_TRES_BIT)
273
274/*** BM Control Register ***/
275#define GR1553B_BM_STAT_BMSUP_BIT 31
276
277#define GR1553B_BM_STAT_BMSUP (1<<GR1553B_BM_STAT_BMSUP_BIT)
278
279/*** BM Control Register ***/
280#define GR1553B_BM_CTRL_BMEN_BIT 0
281#define GR1553B_BM_CTRL_MANL_BIT 1
282#define GR1553B_BM_CTRL_UDWL_BIT 2
283#define GR1553B_BM_CTRL_IMCL_BIT 3
284
285#define GR1553B_BM_CTRL_BMEN (1<<GR1553B_BM_CTRL_BMEN_BIT)
286#define GR1553B_BM_CTRL_MANL (1<<GR1553B_BM_CTRL_MANL_BIT)
287#define GR1553B_BM_CTRL_UDWL (1<<GR1553B_BM_CTRL_UDWL_BIT)
288#define GR1553B_BM_CTRL_IMCL (1<<GR1553B_BM_CTRL_IMCL_BIT)
289
290/*** BM RT Mode code filter Register ***/
291#define GR1553B_BM_MC_S_BIT 0
292#define GR1553B_BM_MC_SB_BIT 1
293#define GR1553B_BM_MC_SD_BIT 2
294#define GR1553B_BM_MC_SDB_BIT 3
295#define GR1553B_BM_MC_TS_BIT 4
296#define GR1553B_BM_MC_TSB_BIT 5
297#define GR1553B_BM_MC_TVW_BIT 6
298#define GR1553B_BM_MC_TBW_BIT 7
299#define GR1553B_BM_MC_DBC_BIT 8
300#define GR1553B_BM_MC_IST_BIT 9
301#define GR1553B_BM_MC_ISTB_BIT 10
302#define GR1553B_BM_MC_ITF_BIT 11
303#define GR1553B_BM_MC_ITFB_BIT 12
304#define GR1553B_BM_MC_RRT_BIT 13
305#define GR1553B_BM_MC_RRTB_BIT 14
306#define GR1553B_BM_MC_TSW_BIT 15
307#define GR1553B_BM_MC_TLC_BIT 16
308#define GR1553B_BM_MC_STS_BIT 17
309#define GR1553B_BM_MC_STSB_BIT 18
310
311#define GR1553B_BM_MC_S (1<<GR1553B_BM_MC_S_BIT)
312#define GR1553B_BM_MC_SB (1<<GR1553B_BM_MC_SB_BIT)
313#define GR1553B_BM_MC_SD (1<<GR1553B_BM_MC_SD_BIT)
314#define GR1553B_BM_MC_SDB (1<<GR1553B_BM_MC_SDB_BIT)
315#define GR1553B_BM_MC_TS (1<<GR1553B_BM_MC_TS_BIT)
316#define GR1553B_BM_MC_TSB (1<<GR1553B_BM_MC_TSB_BIT)
317#define GR1553B_BM_MC_TVW (1<<GR1553B_BM_MC_TVW_BIT)
318#define GR1553B_BM_MC_TBW (1<<GR1553B_BM_MC_TBW_BIT)
319#define GR1553B_BM_MC_DBC (1<<GR1553B_BM_MC_DBC_BIT)
320#define GR1553B_BM_MC_IST (1<<GR1553B_BM_MC_IST_BIT)
321#define GR1553B_BM_MC_ISTB (1<<GR1553B_BM_MC_ISTB_BIT)
322#define GR1553B_BM_MC_ITF (1<<GR1553B_BM_MC_ITF_BIT)
323#define GR1553B_BM_MC_ITFB (1<<GR1553B_BM_MC_ITFB_BIT)
324#define GR1553B_BM_MC_RRT (1<<GR1553B_BM_MC_RRT_BIT)
325#define GR1553B_BM_MC_RRTB (1<<GR1553B_BM_MC_RRTB_BIT)
326#define GR1553B_BM_MC_TSW (1<<GR1553B_BM_MC_TSW_BIT)
327#define GR1553B_BM_MC_TLC (1<<GR1553B_BM_MC_TLC_BIT)
328#define GR1553B_BM_MC_STS (1<<GR1553B_BM_MC_STS_BIT)
329#define GR1553B_BM_MC_STSB (1<<GR1553B_BM_MC_STSB_BIT)
330
331/*** BM RT Mode code filter Register ***/
332#define GR1553B_BM_TTAG_VAL_BIT 0
333#define GR1553B_BM_TTAG_RES_BIT 24
334
335#define GR1553B_BM_TTAG_VAL (0xffffff<<GR1553B_BM_TTAG_VAL_BIT)
336#define GR1553B_BM_TTAG_RES (0xff<<GR1553B_BM_TTAG_RES_BIT)
337
338/* Register GR1553B driver */
339extern void gr1553_register(void);
340
341/*** BC Device allocation ***/
342/* Allocate a BC device. Minor is assigned to a device in the order
343 * they are registered to the driver.
344 */
345extern struct drvmgr_dev **gr1553_bc_open(int minor);
346/* Free a BC device previously allocated */
347extern void gr1553_bc_close(struct drvmgr_dev **dev);
348
349/*** RT Device allocation ***/
350/* Allocate a BC device. Minor is assigned to a device in the order
351 * they are registered to the driver.
352 */
353extern struct drvmgr_dev **gr1553_rt_open(int minor);
354/* Free a BC device previously allocated */
355extern void gr1553_rt_close(struct drvmgr_dev **dev);
356
357/*** BM Device allocation ***/
358/* Allocate a BC device. Minor is assigned to a device in the order
359 * they are registered to the driver.
360 */
361extern struct drvmgr_dev **gr1553_bm_open(int minor);
362/* Free a BC device previously allocated */
363extern void gr1553_bm_close(struct drvmgr_dev **dev);
364
365#ifdef __cplusplus
366}
367#endif
368
369#endif /* __GR1553B_H__ */
Definition: drvmgr.h:273
Definition: gr1553b.h:33
