RTEMS 5.2
framebuffer.h
1
9/*
10 * COPYRIGHT (c) 1989-2011.
11 * On-Line Applications Research Corporation (OAR).
12 *
13 * The license and distribution terms for this file may be
14 * found in the file LICENSE in this distribution or at
15 * http://www.rtems.org/license/LICENSE.
16 */
17
18#ifndef __RTEMS_FRAMEBUFFER_h__
19#define __RTEMS_FRAMEBUFFER_h__
20
21#include <rtems/io.h>
22
23#ifdef __cplusplus
24extern "C" {
25#endif
26
31#define FRAMEBUFFER_DEVICE_NAME "/dev/fb"
32
39#define FRAMEBUFFER_DEVICE_0_NAME "/dev/fb0"
40
45#define FRAME_BUFFER_DRIVER_TABLE_ENTRY \
46 { frame_buffer_initialize, frame_buffer_open, frame_buffer_close, \
47 frame_buffer_read, frame_buffer_write, frame_buffer_control }
48
62 rtems_device_major_number major,
63 rtems_device_minor_number minor,
64 void *arg
65);
66
81 rtems_device_major_number major,
82 rtems_device_minor_number minor,
83 void *arg
84);
85
100 rtems_device_major_number major,
101 rtems_device_minor_number minor,
102 void *arg
103);
104
119 rtems_device_major_number major,
120 rtems_device_minor_number minor,
121 void *arg
122);
123
138 rtems_device_major_number major,
139 rtems_device_minor_number minor,
140 void *arg
141);
142
158 rtems_device_major_number major,
159 rtems_device_minor_number minor,
160 void *arg
161);
162
163#ifdef __cplusplus
164}
165#endif
166
167#endif
168/* end of include file */
Classic Input/Output Manager API.
rtems_device_driver frame_buffer_write(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Frame Buffer Write Entry Point.
Definition: fb.c:163
rtems_device_driver frame_buffer_read(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Frame Buffer Read Entry Point.
Definition: fb.c:152
rtems_device_driver frame_buffer_control(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Frame Buffer IO Control Entry Point.
Definition: fb.c:205
rtems_device_driver frame_buffer_open(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Frame Buffer Open Entry Point.
Definition: fb.c:116
rtems_device_driver frame_buffer_close(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Frame Buffer Close Entry Point.
Definition: fb.c:135
rtems_device_driver frame_buffer_initialize(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
Frame Buffer Initialization Entry Point.
Definition: fb.c:95
rtems_status_code
Classic API Status.
Definition: status.h:43
