RTEMS 5.2
flashd.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
37#ifndef _FLASHD_
38#define _FLASHD_
39
40#include <stdint.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif
45
46#define GPNVBit_SecurityBit 0
47#define GPNVBit_BootMode 1
48#define GPNVBit_TCMBit1 6
49#define GPNVBit_TCMBit2 7
50
51/*----------------------------------------------------------------------------
52 * Exported functions
53 *----------------------------------------------------------------------------*/
54
55extern void FLASHD_Initialize(uint32_t dwMCk, uint32_t dwUseIAP);
56
57extern uint32_t FLASHD_Erase(uint32_t dwAddress);
58
59extern uint32_t FLASHD_EraseSector(uint32_t dwAddress);
60
61extern uint32_t FLASHD_ErasePages(uint32_t dwAddress, uint32_t dwPageNum);
62
63extern uint32_t FLASHD_Write(uint32_t dwAddress, const void *pvBuffer,
64 uint32_t dwSize);
65
66extern uint32_t FLASHD_Lock(uint32_t dwStart, uint32_t dwEnd,
67 uint32_t *pdwActualStart, uint32_t *pdwActualEnd);
68
69extern uint32_t FLASHD_Unlock(uint32_t dwStart, uint32_t dwEnd,
70 uint32_t *pdwActualStart, uint32_t *pdwActualEnd);
71
72extern uint32_t FLASHD_IsLocked(uint32_t dwStart, uint32_t dwEnd);
73
74extern uint32_t FLASHD_SetGPNVM(uint8_t gpnvm);
75
76extern uint32_t FLASHD_ClearGPNVM(uint8_t gpnvm);
77
78extern uint32_t FLASHD_IsGPNVMSet(uint8_t gpnvm);
79
80#define FLASHD_IsSecurityBitSet() FLASHD_IsGPNVMSet(0)
81
82#define FLASHD_SetSecurityBit() FLASHD_SetGPNVM(0)
83
84extern uint32_t FLASHD_ReadUniqueID(uint32_t *pdwUniqueID);
85
86#ifdef __cplusplus
87}
88#endif
89
90#endif /* #ifndef _FLASHD_ */
91
Erases the entire flash.
Definition: flashd.c:173
uint32_t FLASHD_Lock(uint32_t dwStart, uint32_t dwEnd, uint32_t *pdwActualStart, uint32_t *pdwActualEnd)
Locks all the regions in the given address range. The actual lock range is reported through two outpu...
Definition: flashd.c:356
uint32_t FLASHD_Unlock(uint32_t dwStart, uint32_t dwEnd, uint32_t *pdwActualStart, uint32_t *pdwActualEnd)
Unlocks all the regions in the given address range. The actual unlock range is reported through two o...
Definition: flashd.c:400
uint32_t FLASHD_Write(uint32_t dwAddress, const void *pvBuffer, uint32_t dwSize)
Writes a data buffer in the internal flash.
Definition: flashd.c:274
Erases flash by pages.
Definition: flashd.c:222
Check if the given GPNVM bit is set or not.
Definition: flashd.c:492
Returns the number of locked regions inside the given address range.
Definition: flashd.c:441
Erases flash by sector.
Definition: flashd.c:197
Initializes the flash driver.
Definition: flashd.c:159
Clears the selected GPNVM bit.
Definition: flashd.c:531
Sets the selected GPNVM bit.
Definition: flashd.c:515
