RTEMS 5.2
fb.h
1
9/*
10 * Copyright (c) 2000 - Rosimildo da Silva
11 */
12
13#ifndef _MW_FB_H
14#define _MW_FB_H
15
16#include <stdint.h>
17
25#ifdef __cplusplus
26extern "C" {
27#endif
28
29/* ioctls
30 0x46 is 'F' */
31#define FBIOGET_VSCREENINFO 0x4600
32#define FBIOPUT_VSCREENINFO 0x4601
33#define FBIOGET_FSCREENINFO 0x4602
34#define FBIOGETCMAP 0x4604
35#define FBIOPUTCMAP 0x4605
36#define FB_EXEC_FUNCTION 0x4606
37#define FBIOSWAPBUFFERS 0x4607
38#define FBIOSETBUFFERMODE 0x4608
39#define FBIOSETVIDEOMODE 0x4609
40
41#define FB_SINGLE_BUFFERED 0
42#define FB_TRIPLE_BUFFERED 1
43
44#define FB_TYPE_PACKED_PIXELS 0 /* Packed Pixels */
45#define FB_TYPE_PLANES 1 /* Non interleaved planes */
46#define FB_TYPE_INTERLEAVED_PLANES 2 /* Interleaved planes */
47#define FB_TYPE_TEXT 3 /* Text/attributes */
48#define FB_TYPE_VGA_PLANES 4 /* EGA/VGA planes */
49#define FB_TYPE_VIRTUAL_BUFFER 5 /* Virtual Buffer */
50
51
52#define FB_VISUAL_MONO01 0 /* Monochr. 1=Black 0=White */
53#define FB_VISUAL_MONO10 1 /* Monochr. 1=White 0=Black */
54#define FB_VISUAL_TRUECOLOR 2 /* True color */
55#define FB_VISUAL_PSEUDOCOLOR 3 /* Pseudo color (like atari) */
56#define FB_VISUAL_DIRECTCOLOR 4 /* Direct color */
57#define FB_VISUAL_STATIC_PSEUDOCOLOR 5 /* Pseudo color readonly */
58
59#define FB_ACCEL_NONE 0 /* no hardware accelerator */
60
62 uint32_t offset; /* beginning of bitfield */
63 uint32_t length; /* length of bitfield */
64 uint32_t msb_right; /* != 0 : Most significant bit is */
65 /* right */
66};
67
69 uint32_t xres; /* visible resolution */
70 uint32_t yres;
71 uint32_t bits_per_pixel; /* guess what */
72 struct fb_bitfield red; /* bitfield in fb mem if true color, */
73 struct fb_bitfield green; /* else only length is significant */
74 struct fb_bitfield blue;
75 struct fb_bitfield transp; /* transparency */
76};
77
79 volatile char *smem_start; /* Start of frame buffer mem */
80 /* (physical address) */
81 uint32_t smem_len; /* Length of frame buffer mem */
82 uint32_t type; /* see FB_TYPE_* */
83 uint32_t visual; /* see FB_VISUAL_* */
84 uint32_t line_length; /* number of chars per line */
85};
86
87struct fb_cmap {
88 uint32_t start; /* First entry */
89 uint32_t len; /* Number of entries */
90 uint16_t *red; /* Red values */
91 uint16_t *green;
92 uint16_t *blue;
93 uint16_t *transp; /* transparency, can be NULL */
94};
95
96#ifdef __cplusplus
97}
98#endif
101#endif /* _MW_FB_H */
Definition: fb.h:61
Definition: fb.h:87
Definition: fb.h:78
Definition: fb.h:68
