RTEMS 5.2
fat_file.h
1
9/*
10 *
11 * Copyright (C) 2001 OKTET Ltd., St.-Petersburg, Russia
12 * Author: Eugeny S. Mints <Eugeny.Mints@oktet.ru>
13 *
14 * The license and distribution terms for this file may be
15 * found in the file LICENSE in this distribution or at
16 * http://www.rtems.org/license/LICENSE.
17 */
18
19#ifndef __DOSFS_FAT_FILE_H__
20#define __DOSFS_FAT_FILE_H__
21
22#include <rtems.h>
23#include <rtems/libio_.h>
24
25#include <time.h>
26
27#include "fat.h"
28
36#ifdef __cplusplus
37extern "C" {
38#endif
39
40typedef enum {
41 FAT_DIRECTORY = 0,
42 FAT_HARD_LINK = 2, /* pseudo type */
43 FAT_FILE = 4
44} fat_file_type_t;
45
61typedef struct fat_file_map_s
62{
63 uint32_t file_cln;
64 uint32_t disk_cln;
65 uint32_t last_cln;
67
73typedef struct fat_file_fd_s
74{
75 rtems_chain_node link; /*
76 * fat-file descriptors organized into hash;
77 * collision lists are handled via link
78 * field
79 */
80 uint32_t links_num; /*
81 * the number of fat_file_open call on
82 * this fat-file
83 */
84 uint32_t ino; /* inode, file serial number :)))) */
85 fat_file_type_t fat_file_type;
86 uint32_t size_limit;
87 uint32_t fat_file_size; /* length */
88 uint32_t cln;
89 fat_dir_pos_t dir_pos;
90 uint8_t flags;
92 time_t ctime;
93 time_t mtime;
94
96
97#define FAT_FILE_REMOVED 0x01
98
99#define FAT_FILE_META_DATA_CHANGED 0x02
100
101static inline bool FAT_FILE_IS_REMOVED(const fat_file_fd_t *fat_fd)
102{
103 return (fat_fd->flags & FAT_FILE_REMOVED) != 0;
104}
105
106static inline bool FAT_FILE_HAS_META_DATA_CHANGED(const fat_file_fd_t *fat_fd)
107{
108 return (fat_fd->flags & FAT_FILE_META_DATA_CHANGED) != 0;
109}
110
111/* ioctl macros */
112#define F_CLU_NUM 0x01
113
114/*
115 * Each file and directory on a MSDOS volume is unique identified by it
116 * location, i.e. location of it 32 Bytes Directory Entry Structure. We can
117 * distinguish them by cluster number it locates on and offset inside this
118 * cluster. But root directory on any volumes (FAT12/16/32) has no 32 Bytes
119 * Directory Entry Structure corresponded to it. So we assume 32 Bytes
120 * Directory Entry Structure of root directory locates at cluster 1 (invalid
121 * cluaster number) and offset 0
122 */
123#define FAT_ROOTDIR_CLUSTER_NUM 0x01
124
125#define FAT_FD_OF_ROOT_DIR(fat_fd) \
126 ((fat_fd->dir_pos.sname.cln == FAT_ROOTDIR_CLUSTER_NUM) && \
127 (fat_fd->dir_pos.sname.ofs == 0))
128
129#define FAT_EOF 0x00
130
131/* @brief Construct key for hash access.
132 *
133 * Construct key for hash access: convert (cluster num, offset) to
134 * (sector512 num, new offset) and than construct key as
135 * key = (sector512 num) << 4 | (new offset)
136 *
137 * @param[in] cl - cluster number
138 * @param[in] ofs - offset inside cluster 'cl'
139 * @param[in] fs_info - FS info
140 *
141 * @retval constructed key
142 */
143static inline uint32_t
144fat_construct_key(
145 const fat_fs_info_t *fs_info,
146 fat_pos_t *pos)
147{
148 return ( ((fat_cluster_num_to_sector512_num(fs_info, pos->cln) +
149 (pos->ofs >> FAT_SECTOR512_BITS)) << 4) +
150 ((pos->ofs >> 5) & (FAT_DIRENTRIES_PER_SEC512 - 1)) );
151}
152
153static inline void
154fat_file_set_first_cluster_num(fat_file_fd_t *fat_fd, uint32_t cln)
155{
156 fat_fd->cln = cln;
157 fat_fd->flags |= FAT_FILE_META_DATA_CHANGED;
158}
159
160static inline void fat_file_set_file_size(fat_file_fd_t *fat_fd, uint32_t s)
161{
162 fat_fd->fat_file_size = s;
163 fat_fd->flags |= FAT_FILE_META_DATA_CHANGED;
164}
165
166static inline void fat_file_set_ctime(fat_file_fd_t *fat_fd, time_t t)
167{
168 fat_fd->ctime = t;
169 fat_fd->flags |= FAT_FILE_META_DATA_CHANGED;
170}
171
172static inline void fat_file_set_mtime(fat_file_fd_t *fat_fd, time_t t)
173{
174 fat_fd->mtime = t;
175 fat_fd->flags |= FAT_FILE_META_DATA_CHANGED;
176}
177
178static inline void fat_file_set_ctime_mtime(fat_file_fd_t *fat_fd, time_t t)
179{
180 fat_fd->ctime = t;
181 fat_fd->mtime = t;
182 fat_fd->flags |= FAT_FILE_META_DATA_CHANGED;
183}
184
185/* Prototypes for "fat-file" operations */
186int
187fat_file_open(fat_fs_info_t *fs_info,
188 fat_dir_pos_t *dir_pos,
189 fat_file_fd_t **fat_fd);
190
191int
192fat_file_reopen(fat_file_fd_t *fat_fd);
193
194int
195fat_file_close(fat_fs_info_t *fs_info,
196 fat_file_fd_t *fat_fd);
197
198ssize_t
199fat_file_read(fat_fs_info_t *fs_info,
200 fat_file_fd_t *fat_fd,
201 uint32_t start,
202 uint32_t count,
203 uint8_t *buf);
204
205ssize_t
206fat_file_write(fat_fs_info_t *fs_info,
207 fat_file_fd_t *fat_fd,
208 uint32_t start,
209 uint32_t count,
210 const uint8_t *buf);
211
212int
213fat_file_extend(fat_fs_info_t *fs_info,
214 fat_file_fd_t *fat_fd,
215 bool zero_fill,
216 uint32_t new_length,
217 uint32_t *a_length);
218
219int
220fat_file_truncate(fat_fs_info_t *fs_info,
221 fat_file_fd_t *fat_fd,
222 uint32_t new_length);
223
224int
225fat_file_ioctl(fat_fs_info_t *fs_info,
226 fat_file_fd_t *fat_fd,
227 int cmd,
228 ...);
229
230int
231fat_file_size(fat_fs_info_t *fs_info,
232 fat_file_fd_t *fat_fd);
233
234void
235fat_file_mark_removed(fat_fs_info_t *fs_info,
236 fat_file_fd_t *fat_fd);
237
238int
239fat_file_size(fat_fs_info_t *fs_info,
240 fat_file_fd_t *fat_fd);
241
242int
243fat_file_write_first_cluster_num(fat_fs_info_t *fs_info,
244 fat_file_fd_t *fat_fd);
245
246int
247fat_file_write_file_size(fat_fs_info_t *fs_info,
248 fat_file_fd_t *fat_fd);
249
250int
251fat_file_write_time_and_date(fat_fs_info_t *fs_info,
252 fat_file_fd_t *fat_fd);
253
254int
255fat_file_update(fat_fs_info_t *fs_info,
256 fat_file_fd_t *fat_fd);
257
258#ifdef __cplusplus
259}
260#endif
262#endif /* __DOSFS_FAT_FILE_H__ */
Constants/Data Structures/Prototypes on a Volume with FAT Filesystem.
struct fat_file_fd_s fat_file_fd_t
Descriptor of a fat-file.
struct fat_file_map_s fat_file_map_t
The "fat-file" representation.
LibIO Internal Interface.
Definition: chain.h:68
Definition: mm.c:60
Definition: fat.h:381
Definition: fat_file.h:74
Definition: fat_file.h:62
Definition: fat.h:352
Definition: fat.h:369
