RTEMS 5.2
extern-dd.h
1/*-
2 * Copyright (c) 1991, 1993, 1994
3 * The Regents of the University of California. All rights reserved.
4 *
5 * This code is derived from software contributed to Berkeley by
6 * Keith Muller of the University of California, San Diego and Lance
7 * Visser of Convex Computer Corporation.
8 *
9 * Redistribution and use in source and binary forms, with or without
10 * modification, are permitted provided that the following conditions
11 * are met:
12 * 1. Redistributions of source code must retain the above copyright
13 * notice, this list of conditions and the following disclaimer.
14 * 2. Redistributions in binary form must reproduce the above copyright
15 * notice, this list of conditions and the following disclaimer in the
16 * documentation and/or other materials provided with the distribution.
17 * 4. Neither the name of the University nor the names of its contributors
18 * may be used to endorse or promote products derived from this software
19 * without specific prior written permission.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
22 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
25 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
26 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
27 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
28 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
29 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
30 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
31 * SUCH DAMAGE.
32 *
33 * @(#)extern.h 8.3 (Berkeley) 4/2/94
34 * $FreeBSD: src/bin/dd/extern.h,v 1.15 2004/08/15 19:10:05 rwatson Exp $
35 */
36
37#ifndef _EXTERN_DD_H_
38#define _EXTERN_DD_H_
39
40#include <setjmp.h>
41
43 IO in, out; /* input/output state */
44 STAT st; /* statistics */
45 void (*cfunc)(struct rtems_shell_dd_globals_t* globals); /* conversion function */
46 uintmax_t cpy_cnt; /* # of blocks to copy */
47 u_int ddflags; /* conversion options */
48 size_t cbsz; /* conversion block size */
49 uintmax_t files_cnt; /* # of files to copy */
50 const u_char *ctab; /* conversion table */
51 char fill_char; /* Character to fill with if defined */
52 u_char casetab[256];
53 int exit_code;
54 jmp_buf exit_jmp;
56
57#define in globals->in
58#define out globals->out
59#define st globals->st
60#define cfunc globals->cfunc
61#define cpy_cnt globals->cpy_cnt
62#define ddflags globals->ddflags
63#define cbsz globals->cbsz
64#define files_cnt globals->files_cnt
65#define casetab globals->casetab
66#define ctab globals->ctab
67#define fill_char globals->fill_char
68#define exit_jump &(globals->exit_jmp)
69
70#define block rtems_shell_dd_block
71#define block_close rtems_shell_dd_block_close
72#define dd_out rtems_shell_dd_dd_out
73#define def rtems_shell_dd_def
74#define def_close rtems_shell_dd_def_close
75#define jcl rtems_shell_dd_jcl
76#define pos_in rtems_shell_dd_pos_in
77#define pos_out rtems_shell_dd_pos_out
78#define summary rtems_shell_dd_summary
79#define summaryx rtems_shell_dd_summaryx
80#define terminate rtems_shell_dd_terminate
81#define unblock rtems_shell_dd_unblock
82#define unblock_close rtems_shell_dd_unblock_close
83
84void block(rtems_shell_dd_globals* );
85void block_close(rtems_shell_dd_globals* );
86void dd_out(rtems_shell_dd_globals* , int);
87void def(rtems_shell_dd_globals* globals);
88void def_close(rtems_shell_dd_globals* );
89void jcl(rtems_shell_dd_globals* , char **);
90void pos_in(rtems_shell_dd_globals* );
91void pos_out(rtems_shell_dd_globals* );
92void summary(rtems_shell_dd_globals* );
93void summaryx(rtems_shell_dd_globals* , int);
94void terminate(int);
95void unblock(rtems_shell_dd_globals* globals);
96void unblock_close(rtems_shell_dd_globals* globals);
97
98extern const u_char a2e_32V[256], a2e_POSIX[256];
99extern const u_char e2a_32V[256], e2a_POSIX[256];
100extern const u_char a2ibm_32V[256], a2ibm_POSIX[256];
101
102void rtems_shell_dd_exit(rtems_shell_dd_globals* globals, int code);
103
104#define exit(ec) rtems_shell_dd_exit(globals, ec)
105
106#endif /* !_EXTERN_H_ */
Definition: dd.h:45
Definition: dd.h:66
Definition: inftrees.h:24
Definition: extern-dd.h:42
