RTEMS 5.2
extension.h
1
9/*
10 * COPYRIGHT (c) 1989-2008.
11 * On-Line Applications Research Corporation (OAR).
12 *
13 * The license and distribution terms for this file may be
14 * found in the file LICENSE in this distribution or at
15 * http://www.rtems.org/license/LICENSE.
16 */
17
18#ifndef _RTEMS_EXTENSION_H
19#define _RTEMS_EXTENSION_H
20
21#include <rtems/rtems/status.h>
22#include <rtems/rtems/types.h>
23#include <rtems/score/userext.h>
24
25#ifdef __cplusplus
26extern "C" {
27#endif
28
29typedef User_extensions_routine
30 rtems_extension RTEMS_DEPRECATED;
31
157typedef User_extensions_thread_create_extension rtems_task_create_extension;
158typedef User_extensions_thread_delete_extension rtems_task_delete_extension;
159typedef User_extensions_thread_start_extension rtems_task_start_extension;
160typedef User_extensions_thread_restart_extension rtems_task_restart_extension;
161typedef User_extensions_thread_switch_extension rtems_task_switch_extension;
162typedef User_extensions_thread_begin_extension rtems_task_begin_extension;
163typedef User_extensions_thread_exitted_extension rtems_task_exitted_extension;
164typedef User_extensions_fatal_extension rtems_fatal_extension;
165typedef User_extensions_thread_terminate_extension rtems_task_terminate_extension;
166
168
170
171typedef Internal_errors_t rtems_fatal_code;
172
193 rtems_name name,
194 const rtems_extensions_table *extension_table,
195 rtems_id *id
196);
197
215 rtems_name name,
216 rtems_id *id
217);
218
231 rtems_id id
232);
233
236#ifdef __cplusplus
237}
238#endif
239
240#endif
241/* end of include file */
rtems_status_code
Classic API Status.
Definition: status.h:43
uint32_t rtems_name
Classic API object name type.
Definition: types.h:77
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
rtems_status_code rtems_extension_delete(rtems_id id)
Deletes an extension set object specified by the identifier id.
Definition: extensiondelete.c:25
rtems_status_code rtems_extension_ident(rtems_name name, rtems_id *id)
Identifies an extension set object by a name.
Definition: extensionident.c:27
rtems_status_code rtems_extension_create(rtems_name name, const rtems_extensions_table *extension_table, rtems_id *id)
Creates an extension set object.
Definition: extensioncreate.c:27
Internal_errors_Source
This type lists the possible sources from which an error can be reported.
Definition: interr.h:47
void(* User_extensions_thread_begin_extension)(struct _Thread_Control *executing)
Task begin extension.
Definition: userext.h:171
bool(* User_extensions_thread_create_extension)(struct _Thread_Control *executing, struct _Thread_Control *created)
Task create extension.
Definition: userext.h:71
void(* User_extensions_thread_start_extension)(struct _Thread_Control *executing, struct _Thread_Control *started)
Task start extension.
Definition: userext.h:111
void(* User_extensions_thread_restart_extension)(struct _Thread_Control *executing, struct _Thread_Control *restarted)
Task restart extension.
Definition: userext.h:133
void(* User_extensions_thread_delete_extension)(struct _Thread_Control *executing, struct _Thread_Control *deleted)
Task delete extension.
Definition: userext.h:91
void(* User_extensions_thread_switch_extension)(struct _Thread_Control *executing, struct _Thread_Control *heir)
Task switch extension.
Definition: userext.h:156
void(* User_extensions_thread_terminate_extension)(struct _Thread_Control *terminated)
Task termination extension.
Definition: userext.h:225
void(* User_extensions_fatal_extension)(Internal_errors_Source source, bool always_set_to_false, Internal_errors_t code)
Fatal error extension.
Definition: userext.h:203
void(* User_extensions_thread_exitted_extension)(struct _Thread_Control *executing)
Task exitted extension.
Definition: userext.h:185
User extension table.
Definition: userext.h:232
User Extension Handler API.
