RTEMS 5.2
epiphany-utility.h
1
10/*
11 * Copyright (c) 2015 University of York.
12 * Hesham ALMatary <hmka501@york.ac.uk>
13 *
16 * are met:
22 *
23 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
24 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
27 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
28 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
29 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
30 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
31 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
32 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
33 * SUCH DAMAGE.
34 */
35
36#ifndef _EPIPHANY_UTILITY_H
37#define _EPIPHANY_UTILITY_H
38
39/* eCore IRQs */
40typedef enum
41{
42 START,
43 SW_EXCEPTION,
44 MEM_FAULT,
45 TIMER0,
46 TIMER1,
47 SMP_MESSAGE,
48 DMA0,
49 DMA1,
50 SER,
51} EPIPHANY_IRQ_PER_CORE_T;
52
53/* Per-core IO mapped register addresses
54 * @see Epiphany architecture reference.
55 */
56#define EPIPHANY_PER_CORE_REG_CONFIG 0xF0400
57#define EPIPHANY_PER_CORE_REG_STATUS 0xF0404
58#define EPIPHANY_PER_CORE_REG_PC 0xF0408
59#define EPIPHANY_PER_CORE_REG_DEBUGSTATUS 0xF040C
60#define EPIPHANY_PER_CORE_REG_LC 0xF0414
61#define EPIPHANY_PER_CORE_REG_LS 0xF0418
62#define EPIPHANY_PER_CORE_REG_LE 0xF041C
63#define EPIPHANY_PER_CORE_REG_IRET 0xF0420
64#define EPIPHANY_PER_CORE_REG_IMASK 0xF0424
65#define EPIPHANY_PER_CORE_REG_ILAT 0xF0428
66#define EPIPHANY_PER_CORE_REG_ILATST 0xF042C
67#define EPIPHANY_PER_CORE_REG_ILATCL 0xF0430
68#define EPIPHANY_PER_CORE_REG_IPEND 0xF0434
69#define EPIPHANY_PER_CORE_REG_FSTATUS 0xF0440
70#define EPIPHANY_PER_CORE_REG_DEBUGCMD 0xF0448
71#define EPIPHANY_PER_CORE_REG_RESETCORE 0xF070C
72
73/* Event timer registers */
74#define EPIPHANY_PER_CORE_REG_CTIMER0 0xF0438
75#define EPIPHANY_PER_CORE_REG_CTIMER1 0xF043C
76
77/* Processor control registers */
78#define EPIPHANY_PER_CORE_REG_MEMSTATUS 0xF0604
79#define EPIPHANY_PER_CORE_REG_MEMPROTECT 0xF0608
80
81/* DMA Registers */
82#define EPIPHANY_PER_CORE_REG_DMA0CONFIG 0xF0500
83#define EPIPHANY_PER_CORE_REG_DMA0STRIDE 0xF0504
84#define EPIPHANY_PER_CORE_REG_DMA0COUNT 0xF0508
85#define EPIPHANY_PER_CORE_REG_DMA0SRCADDR 0xF050C
86#define EPIPHANY_PER_CORE_REG_DMA0DSTADDR 0xF0510
87#define EPIPHANY_PER_CORE_REG_DMA0AUTO0 0xF0514
88#define EPIPHANY_PER_CORE_REG_DMA0AUTO1 0xF0518
89#define EPIPHANY_PER_CORE_REG_DMA0STATUS 0xF051C
90#define EPIPHANY_PER_CORE_REG_DMA1CONFIG 0xF0520
91#define EPIPHANY_PER_CORE_REG_DMA1STRIDE 0xF0524
92#define EPIPHANY_PER_CORE_REG_DMA1COUNT 0xF0528
93#define EPIPHANY_PER_CORE_REG_DMA1SRCADDR 0xF052C
94#define EPIPHANY_PER_CORE_REG_DMA1DSTADDR 0xF0530
95#define EPIPHANY_PER_CORE_REG_DMA1AUTO0 0xF0534
96#define EPIPHANY_PER_CORE_REG_DMA1AUTO1 0xF0538
97#define EPIPHANY_PER_CORE_REG_DMA1STATUS 0xF053C
98
99/* Mesh Node Control Registers */
100#define EPIPHANY_PER_CORE_REG_MESHCONFIG 0xF0700
101#define EPIPHANY_PER_CORE_REG_COREID 0xF0704
102#define EPIPHANY_PER_CORE_REG_MULTICAST 0xF0708
103#define EPIPHANY_PER_CORE_REG_CMESHROUTE 0xF0710
104#define EPIPHANY_PER_CORE_REG_XMESHROUTE 0xF0714
105#define EPIPHANY_PER_CORE_REG_RMESHROUTE 0xF0718
106
107/* This macros constructs an address space of epiphany cores
108 * from their IDs.
109 */
110#define EPIPHANY_COREID_TO_MSB_ADDR(id) (id) << 20
111
112/* Construct a complete/absolute IO mapped address register from
113 * core ID and register name
114 */
115#define EPIPHANY_GET_REG_ABSOLUTE_ADDR(coreid, reg) \
116 (EPIPHANY_COREID_TO_MSB_ADDR(coreid) | (reg))
117
118#define EPIPHANY_REG(reg) (uint32_t *) (reg)
119
120/* Read register with its absolute address */
121static inline uint32_t read_epiphany_reg(volatile uint32_t reg_addr)
122{
123 return *(EPIPHANY_REG(reg_addr));
124}
125
126/* Write register with its abolute address */
127static inline void write_epiphany_reg(volatile uint32_t reg_addr, uint32_t val)
128{
129 *(EPIPHANY_REG(reg_addr)) = val;
130}
131
132/* Epiphany uses 12 bits for defining core IDs, while RTEMS uses
133 * linear IDs. The following function converts RTEMS linear IDs to
134 * Epiphany corresponding ones
135 */
136static const uint32_t map[16] =
137{
138 0x808, 0x809, 0x80A, 0x80B,
139 0x848, 0x849, 0x84A, 0x84B,
140 0x888, 0x889, 0x88A, 0x88B,
141 0x8C8, 0x8C9, 0x8CA, 0x8CB
142};
143
144static inline uint32_t rtems_coreid_to_epiphany_map(uint32_t rtems_id)
145{
146 return map[rtems_id];
147}
148
149/* Epiphany uses 12 bits for defining core IDs, while RTEMS uses
150 * linear IDs. The following function is used to map Epiphany IDs to
151 * RTEMS linear IDs.
152 */
153static inline uint32_t epiphany_coreid_to_rtems_map(uint32_t epiphany_id)
154{
155 register uint32_t coreid asm ("r17") = epiphany_id;
156
157 /* Mapping from Epiphany IDs to 0-16 IDs macro */
158 __asm__ __volatile__(" \
159 movfs r17, coreid \
160 mov r19, #0x003 \
161 mov r20, #0x0F0 \
162 and r19, r17, r19 \
163 and r20, r17, r20 \
164 lsr r20, r20, #4 \
165 add r17, r19, r20 \
166 ");
167
168 /* coreid or r17 now holds the rtems core id */
169 return coreid;
170}
171
172static inline uint32_t _Epiphany_Get_current_processor(void)
173{
174 uint32_t coreid;
175
176 asm volatile ("movfs %0, coreid" : "=r" (coreid): );
177
178 return epiphany_coreid_to_rtems_map(coreid);
179}
180#endif /* _EPIPHANY_UTILITY_H */
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
Definition: mm.c:60
