RTEMS 5.2
drvmgr_confdefs.h
1/* Driver Manager Configuration file.
2 *
3 * COPYRIGHT (c) 2009 Cobham Gaisler AB.
4 *
5 * The license and distribution terms for this file may be
6 * found in the file LICENSE in this distribution or at
7 * http://www.rtems.org/license/LICENSE.
8 */
9
10/*
11 * The configuration consist of an array with function pointers that
12 * register one or more drivers that will be used by the Driver Manger.
13 *
14 * The Functions are called in the order they are declared.
15 *
16 */
17
18#ifndef _DRIVER_MANAGER_CONFDEFS_H_
19#define _DRIVER_MANAGER_CONFDEFS_H_
20
21#include "drvmgr.h"
22
23#ifdef __cplusplus
24extern "C" {
25#endif
26
27extern drvmgr_drv_reg_func drvmgr_drivers[];
28
29#ifdef CONFIGURE_INIT
30
31/*** AMBA Plug & Play Drivers ***/
32extern void gptimer_register_drv(void);
33extern void apbuart_cons_register_drv(void);
34extern void greth_register_drv(void);
35extern void grspw_register_drv(void);
36extern void grspw2_register_drv(void);
37extern void grcan_register_drv(void);
38extern void occan_register_drv(void);
39extern void gr1553_register(void);
40extern void gr1553bc_register(void);
41extern void gr1553bm_register(void);
42extern void gr1553rt_register(void);
43extern void b1553brm_register_drv(void);
44extern void b1553rt_register_drv(void);
45extern void grtm_register_drv(void);
46extern void grtc_register_drv(void);
47extern void pcif_register_drv(void);
48extern void grpci_register_drv(void);
49extern void mctrl_register_drv(void);
50extern void l2cache_register_drv(void);
51extern void griommu_register_drv(void);
52extern void grpci2_register_drv(void);
53extern void spictrl_register_drv(void);
54extern void i2cmst_register_drv(void);
55extern void grgpio_register_drv(void);
56extern void grpwm_register_drv(void);
57extern void gradcdac_register_drv(void);
58extern void spwcuc_register(void);
59extern void grctm_register(void);
60extern void router_register_drv(void);
61extern void ahbstat_register_drv(void);
62extern void memscrub_register_drv(void);
63extern void l4stat_register_drv(void);
64extern void spwtdp_register_drv(void);
65
66
67/*** LEON2 AMBA Hard coded bus Drivers ***/
68extern void at697pci_register_drv(void);
69extern void ambapp_leon2_register(void);
70
71
72/*** PCI Bus Drivers (PCI Target drivers) ***/
73extern void gr_rasta_adcdac_register_drv(void);
74extern void gr_rasta_io_register_drv(void);
75extern void gr_rasta_tmtc_register_drv(void);
76extern void gr701_register_drv(void);
77extern void gr_tmtc_1553_register_drv(void);
78extern void gr_rasta_spw_router_register_drv(void);
79extern void gr_cpci_leon4_n2x_register_drv(void);
80extern void gr_cpci_gr740_register_drv(void);
81
82
83/* CONFIGURE DRIVER MANAGER */
84drvmgr_drv_reg_func drvmgr_drivers[] = {
85 /*** AMBA Plug & Play Drivers ***/
86#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GPTIMER
87 gptimer_register_drv,
88#endif
89#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_APBUART
90 apbuart_cons_register_drv,
91#endif
92#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRETH
93 greth_register_drv,
94#endif
95#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRSPW
96 grspw_register_drv,
97#endif
98#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRSPW2
99 grspw2_register_drv,
100#endif
101#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRCAN
102 grcan_register_drv,
103#endif
104#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_OCCAN
105 occan_register_drv,
106#endif
107#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GR1553B
108 gr1553_register,
109#endif
110#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GR1553BC
111 gr1553bc_register,
112#endif
113#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GR1553BM
114 gr1553bm_register,
115#endif
116#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GR1553RT
117 gr1553rt_register,
118#endif
119#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_B1553BRM
120 b1553brm_register_drv,
121#endif
122#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_B1553RT
123 b1553rt_register_drv,
124#endif
125#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRTM
126 grtm_register_drv,
127#endif
128#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRTC
129 grtc_register_drv,
130#endif
131#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_PCIF
132 pcif_register_drv,
133#endif
134#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRPCI
135 grpci_register_drv,
136#endif
137#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRPCI2
138 grpci2_register_drv,
139#endif
140#ifdef CONFIGURE_DRIVER_AMBAPP_MCTRL
141 mctrl_register_drv,
142#endif
143#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_L2CACHE
144 l2cache_register_drv,
145#endif
146#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRIOMMU
147 griommu_register_drv,
148#endif
149#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_SPICTRL
150 spictrl_register_drv,
151#endif
152#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_I2CMST
153 i2cmst_register_drv,
154#endif
155#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRGPIO
156 grgpio_register_drv,
157#endif
158#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRPWM
159 grpwm_register_drv,
160#endif
161#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRADCDAC
162 gradcdac_register_drv,
163#endif
164#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_SPWCUC
165 spwcuc_register,
166#endif
167#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRCTM
168 grctm_register,
169#endif
170#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_SPW_ROUTER
171 router_register_drv,
172#endif
173#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_AHBSTAT
174 ahbstat_register_drv,
175#endif
176#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_MEMSCRUB
177 memscrub_register_drv,
178#endif
179#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_L4STAT
180 l4stat_register_drv,
181#endif
182#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_SPWTDP
183 spwtdp_register_drv,
184#endif
185
186 /*** LEON2 AMBA Drivers ***/
187#ifdef CONFIGURE_DRIVER_LEON2_AT697PCI
188 at697pci_register_drv,
189#endif
190#ifdef CONFIGURE_DRIVER_LEON2_AMBAPP
191 ambapp_leon2_register,
192#endif
193
194 /*** PCI Target Drivers ***/
195#ifdef CONFIGURE_DRIVER_PCI_GR_RASTA_ADCDAC
196 gr_rasta_adcdac_register_drv,
197#endif
198#ifdef CONFIGURE_DRIVER_PCI_GR_RASTA_IO
199 gr_rasta_io_register_drv,
200#endif
201#ifdef CONFIGURE_DRIVER_PCI_GR_RASTA_TMTC
202 gr_rasta_tmtc_register_drv,
203#endif
204#ifdef CONFIGURE_DRIVER_PCI_GR_701
205 gr701_register_drv,
206#endif
207#ifdef CONFIGURE_DRIVER_PCI_GR_TMTC_1553
208 gr_tmtc_1553_register_drv,
209#endif
210#ifdef CONFIGURE_DRIVER_PCI_GR_RASTA_SPW_ROUTER
211 gr_rasta_spw_router_register_drv,
212#endif
213#ifdef CONFIGURE_DRIVER_PCI_GR_LEON4_N2X
214 gr_cpci_leon4_n2x_register_drv,
215#endif
216#ifdef CONFIGURE_DRIVER_PCI_GR_CPCI_GR740
217 gr_cpci_gr740_register_drv,
218#endif
219
220
221/* Macros for adding custom drivers without needing to recompile
222 * kernel.
223 */
224#ifdef CONFIGURE_DRIVER_CUSTOM1
225 DRIVER_CUSTOM1_REG,
226#endif
227#ifdef CONFIGURE_DRIVER_CUSTOM2
228 DRIVER_CUSTOM2_REG,
229#endif
230#ifdef CONFIGURE_DRIVER_CUSTOM3
231 DRIVER_CUSTOM3_REG,
232#endif
233#ifdef CONFIGURE_DRIVER_CUSTOM4
234 DRIVER_CUSTOM4_REG,
235#endif
236#ifdef CONFIGURE_DRIVER_CUSTOM5
237 DRIVER_CUSTOM5_REG,
238#endif
239#ifdef CONFIGURE_DRIVER_CUSTOM6
240 DRIVER_CUSTOM6_REG,
241#endif
242#ifdef CONFIGURE_DRIVER_CUSTOM7
243 DRIVER_CUSTOM7_REG,
244#endif
245#ifdef CONFIGURE_DRIVER_CUSTOM8
246 DRIVER_CUSTOM8_REG,
247#endif
248#ifdef CONFIGURE_DRIVER_CUSTOM9
249 DRIVER_CUSTOM9_REG,
250#endif
251
252 /* End array with NULL */
253 NULL
254};
255
256#endif /* CONFIGURE_INIT */
257
258#ifdef __cplusplus
259}
260#endif
261
262#endif /* _DRIVER_MANAGER_CONFDEFS_H_ */
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
