RTEMS 5.2
Classic Dual Ported Memory Manager API. More...
| rtems_status_code | rtems_port_create (rtems_name name, void *internal_start, void *external_start, uint32_t length, rtems_id *id) |
| Creates a port into a dual-ported memory area. More... | |
| rtems_status_code | rtems_port_ident (rtems_name name, rtems_id *id) |
| RTEMS Port Name to Id. More... | |
| rtems_status_code | rtems_port_delete (rtems_id id) |
| RTEMS Delete Port. More... | |
| rtems_status_code | rtems_port_external_to_internal (rtems_id id, void *external, void **internal) |
| RTEMS Port External to Internal. More... | |
| rtems_status_code | rtems_port_internal_to_external (rtems_id id, void *internal, void **external) |
| RTEMS Port Internal to External. More... | |
