RTEMS 5.2
Macros | Functions
clock.h File Reference
#include <rtems/config.h>
#define rtems_clock_get_ticks_per_second(void)   ( _Watchdog_Ticks_per_second )
 Obtain Ticks Per Seconds. More...
rtems_status_code rtems_clock_get_tod (rtems_time_of_day *time_buffer)
 Obtain Current Time of Day (Classic TOD) More...
rtems_status_code rtems_clock_get_tod_timeval (struct timeval *time)
 Obtain TOD in struct timeval Format. More...
rtems_status_code rtems_clock_get_seconds_since_epoch (rtems_interval *the_interval)
 Obtain Seconds Since Epoch. More...
RTEMS_INLINE_ROUTINE rtems_interval rtems_clock_get_ticks_since_boot (void)
 Gets the current ticks counter value. More...
RTEMS_INLINE_ROUTINE rtems_interval rtems_clock_tick_later (rtems_interval delta)
 Returns the ticks counter value delta ticks in the future. More...
RTEMS_INLINE_ROUTINE rtems_interval rtems_clock_tick_later_usec (rtems_interval delta_in_usec)
 Returns the ticks counter value at least delta microseconds in the future. More...
RTEMS_INLINE_ROUTINE bool rtems_clock_tick_before (rtems_interval tick)
 Returns true if the current ticks counter value indicates a time before the time specified by the tick value and false otherwise. More...
rtems_status_code rtems_clock_set (const rtems_time_of_day *time_buffer)
 Set the Current TOD. More...
rtems_status_code rtems_clock_tick (void)
 Announce a Clock Tick. More...
rtems_status_code rtems_clock_get_uptime (struct timespec *uptime)
 Obtain the System Uptime. More...
void rtems_clock_get_uptime_timeval (struct timeval *uptime)
 Gets the System Uptime in the Struct Timeval Format. More...
time_t rtems_clock_get_uptime_seconds (void)
 Returns the system uptime in seconds. More...
uint64_t rtems_clock_get_uptime_nanoseconds (void)
 Returns the system uptime in nanoseconds. More...
bool _TOD_Validate (const rtems_time_of_day *the_tod)
 TOD Validate. More...
Watchdog_Interval _TOD_To_seconds (const rtems_time_of_day *the_tod)
 TOD to Seconds. More...
This include file contains all the constants and structures associated with the Clock Manager. This manager provides facilities to set, obtain, and continually update the current date and time.
This manager provides directives to:
