RTEMS 5.2
mpci.h
2
11/*
12 * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
13 *
16 * are met:
22 *
34 */
35
36#ifndef _RTEMS_CONFDEFS_MPCI_H
37#define _RTEMS_CONFDEFS_MPCI_H
38
39#ifndef __CONFIGURATION_TEMPLATE_h
40#error "Do not include this file directly, use <rtems/confdefs.h> instead"
41#endif
42
43#ifdef CONFIGURE_INIT
44
45#ifdef RTEMS_MULTIPROCESSING
46
47#ifdef CONFIGURE_MP_APPLICATION
48
50
51#ifndef CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
52 #define CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK 0
53#endif
54
55#ifndef CONFIGURE_MP_NODE_NUMBER
56 #define CONFIGURE_MP_NODE_NUMBER NODE_NUMBER
57#endif
58
59#ifndef CONFIGURE_MP_MAXIMUM_NODES
60 #define CONFIGURE_MP_MAXIMUM_NODES 2
61#endif
62
63#ifndef CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
64 #define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS 32
65#endif
66
67#ifndef CONFIGURE_MP_MAXIMUM_PROXIES
68 #define CONFIGURE_MP_MAXIMUM_PROXIES 32
69#endif
70
71#ifndef CONFIGURE_MP_MPCI_TABLE_POINTER
72 #include <mpci.h>
73
74 #define CONFIGURE_MP_MPCI_TABLE_POINTER &MPCI_table
75#endif
76
77#if CONFIGURE_MP_NODE_NUMBER < 1
78 #error "CONFIGURE_MP_NODE_NUMBER must be greater than or equal to one"
79#endif
80
81#if CONFIGURE_MP_NODE_NUMBER > CONFIGURE_MP_MAXIMUM_NODES
82 #error "CONFIGURE_MP_NODE_NUMBER must be less than or equal to CONFIGURE_MP_MAXIMUM_NODES"
83#endif
84
85#ifdef __cplusplus
86extern "C" {
87#endif
88
89Objects_MP_Control _Objects_MP_Controls[
90 CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
91];
92
93struct Thread_Configured_proxy_control {
96};
97
98static Thread_Configured_proxy_control _Thread_MP_Configured_proxies[
99 CONFIGURE_MP_MAXIMUM_PROXIES
100];
101
102Thread_Configured_proxy_control * const _Thread_MP_Proxies =
103 &_Thread_MP_Configured_proxies[ 0 ];
104
106 CONFIGURE_MP_NODE_NUMBER,
107 CONFIGURE_MP_MAXIMUM_NODES,
108 CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS,
109 CONFIGURE_MP_MAXIMUM_PROXIES,
110 CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK,
111 CONFIGURE_MP_MPCI_TABLE_POINTER
112};
113
115 CONFIGURE_MINIMUM_TASK_STACK_SIZE
116 + CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
117 + CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK
118 + CPU_ALL_TASKS_ARE_FP * CONTEXT_FP_SIZE
120RTEMS_SECTION( ".rtemsstack.mpci" );
121
122#ifdef __cplusplus
123}
124#endif
125
126#endif /* CONFIGURE_MP_APPLICATION */
127
128#else /* RTEMS_MULTIPROCESSING */
129
130#ifdef CONFIGURE_MP_APPLICATION
131 #error "CONFIGURE_MP_APPLICATION must not be defined if multiprocessing is disabled"
132#endif
133
134#endif /* RTEMS_MULTIPROCESSING */
135
136#endif /* CONFIGURE_INIT */
137
138#endif /* _RTEMS_CONFDEFS_MPCI_H */
#define RTEMS_SECTION(_section)
Instructs the compiler to place a specific variable or function in the specified section.
Definition: basedefs.h:154
#define RTEMS_ALIGNED(_alignment)
Instructs the compiler to enforce the specified alignment.
Definition: basedefs.h:216
#define CONTEXT_FP_SIZE
Size of floating point context area.
Definition: context.h:52
char _MPCI_Receive_server_stack[]
The MPCI receive server stack.
const MPCI_Configuration _MPCI_Configuration
The MPCI configuration.
Definition: mpcidefault.c:32
#define CPU_INTERRUPT_STACK_ALIGNMENT
Definition: cpu.h:605
Definition: mpci.h:137
Definition: thread.h:519
Thread queue heads.
Definition: threadq.h:360
Evaluate Thread Configuration Options.
