RTEMS 5.2
console.h
2
11/*
12 * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
13 *
16 * are met:
22 *
34 */
35
36#ifndef _RTEMS_CONFDEFS_SIMPLECONSOLE_H
37#define _RTEMS_CONFDEFS_SIMPLECONSOLE_H
38
39#ifndef __CONFIGURATION_TEMPLATE_h
40#error "Do not include this file directly, use <rtems/confdefs.h> instead"
41#endif
42
43#ifdef CONFIGURE_INIT
44
45#if defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER) \
46 && defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER)
47 #error "CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER and CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER are mutually exclusive"
48#endif
49
50#if defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER) \
51 || defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER)
52
53#include <rtems/console.h>
54#include <rtems/sysinit.h>
55
56#ifdef __cplusplus
57extern "C" {
58#endif
59
60#ifdef CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
61 RTEMS_SYSINIT_ITEM(
63 RTEMS_SYSINIT_DEVICE_DRIVERS,
64 RTEMS_SYSINIT_ORDER_SECOND
65 );
66#endif
67
68#ifdef CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
69 RTEMS_SYSINIT_ITEM(
71 RTEMS_SYSINIT_DEVICE_DRIVERS,
72 RTEMS_SYSINIT_ORDER_SECOND
73 );
74#endif
75
76#ifdef __cplusplus
77}
78#endif
79
80#endif /* CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
81 || CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER */
82
83#endif /* CONFIGURE_INIT */
84
85#endif /* _RTEMS_CONFDEFS_SIMPLECONSOLE_H */
Console Driver for all Boards.
void _Console_simple_task_Initialize(void)
Initializes a simple task console device.
Definition: consolesimpletask.c:217
void _Console_simple_Initialize(void)
Initializes a simple console device.
Definition: consolesimple.c:91
