RTEMS 5.2
clock.h
2
11/*
12 * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
13 *
16 * are met:
22 *
34 */
35
36#ifndef _RTEMS_CONFDEFS_CLOCK_H
37#define _RTEMS_CONFDEFS_CLOCK_H
38
39#ifndef __CONFIGURATION_TEMPLATE_h
40#error "Do not include this file directly, use <rtems/confdefs.h> instead"
41#endif
42
43#ifdef CONFIGURE_INIT
44
46
47#if !defined(CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER) \
48 && !defined(CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER) \
49 && !defined(CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER)
50 #error "You must define one of CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER, CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER, and CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER"
51#endif
52
53#if ( defined(CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER) \
54 + defined(CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER) + \
55 + defined(CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER) ) > 1
56 #error "CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER, CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER, and CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER are mutually exclusive"
57#endif
58
59#ifdef CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
60 #include <rtems/clockdrv.h>
61 #include <rtems/sysinit.h>
62#endif
63
64#ifndef CONFIGURE_MICROSECONDS_PER_TICK
65 #define CONFIGURE_MICROSECONDS_PER_TICK 10000
66#endif
67
68#if 1000000 % CONFIGURE_MICROSECONDS_PER_TICK != 0
69 #warning "The clock ticks per second is not an integer"
70#endif
71
72#if CONFIGURE_MICROSECONDS_PER_TICK <= 0
73 #error "CONFIGURE_MICROSECONDS_PER_TICK must be positive"
74#endif
75
76#ifdef __cplusplus
77extern "C" {
78#endif
79
80#ifdef CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
81 RTEMS_SYSINIT_ITEM(
83 RTEMS_SYSINIT_DEVICE_DRIVERS,
84 RTEMS_SYSINIT_ORDER_THIRD
85 );
86#endif
87
89 CONFIGURE_MICROSECONDS_PER_TICK;
90
91const uint32_t _Watchdog_Nanoseconds_per_tick =
92 (uint32_t) 1000 * CONFIGURE_MICROSECONDS_PER_TICK;
93
94const uint32_t _Watchdog_Ticks_per_second =
95 1000000 / CONFIGURE_MICROSECONDS_PER_TICK;
96
97#if defined(CONFIGURE_TICKS_PER_TIMESLICE) \
98 && CONFIGURE_TICKS_PER_TIMESLICE != WATCHDOG_TICKS_PER_TIMESLICE_DEFAULT
99 const uint32_t _Watchdog_Ticks_per_timeslice =
100 CONFIGURE_TICKS_PER_TIMESLICE;
101#endif
102
103#ifdef __cplusplus
104}
105#endif
106
107#endif /* CONFIGURE_INIT */
108
109#endif /* _RTEMS_CONFDEFS_CLOCK_H */
Clock Driver API.
void _Clock_Initialize(void)
Initialize the clock driver.
Definition: clock.c:56
const uint32_t _Watchdog_Microseconds_per_tick
The watchdog microseconds per tick.
The watchdog nanoseconds per tick.
The watchdog ticks per second.
The watchdog ticks per timeslice.
Definition: watchdogtimeslicedefault.c:34
Constants for the watchdog ticks.
