RTEMS 5.2
bsp.h
2
11/*
12 * Copyright (C) 2013 embedded brains GmbH (http://www.embedded-brains.de)
13 *
16 * are met:
22 *
34 */
35
36#ifndef _RTEMS_CONFDEFS_BSP_H
37#define _RTEMS_CONFDEFS_BSP_H
38
39#ifndef __CONFIGURATION_TEMPLATE_h
40#error "Do not include this file directly, use <rtems/confdefs.h> instead"
41#endif
42
43#ifdef CONFIGURE_INIT
44
45#ifdef CONFIGURE_DISABLE_BSP_SETTINGS
46 #undef BSP_IDLE_TASK_BODY
47 #undef BSP_IDLE_TASK_STACK_SIZE
48 #undef BSP_INITIAL_EXTENSION
49 #undef BSP_INTERRUPT_STACK_SIZE
50 #undef CONFIGURE_BSP_PREREQUISITE_DRIVERS
51 #undef CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
52#else
53 #include <bsp.h>
54#endif
55
56#endif /* CONFIGURE_INIT */
57
58#endif /* _RTEMS_CONFDEFS_BSP_H */
