RTEMS 5.2
core_cmInstr.h
1/**************************************************************************/
7/* Copyright (c) 2009 - 2015 ARM LIMITED
8
9 All rights reserved.
10 Redistribution and use in source and binary forms, with or without
11 modification, are permitted provided that the following conditions are met:
12 - Redistributions of source code must retain the above copyright
13 notice, this list of conditions and the following disclaimer.
14 - Redistributions in binary form must reproduce the above copyright
15 notice, this list of conditions and the following disclaimer in the
16 documentation and/or other materials provided with the distribution.
17 - Neither the name of ARM nor the names of its contributors may be used
18 to endorse or promote products derived from this software without
19 specific prior written permission.
20 *
21 THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 ARE DISCLAIMED. IN NO EVENT SHALL COPYRIGHT HOLDERS AND CONTRIBUTORS BE
25 LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 POSSIBILITY OF SUCH DAMAGE.
32 ---------------------------------------------------------------------------*/
33
34
35#if defined ( __ICCARM__ )
36 #pragma system_include /* treat file as system include file for MISRA check */
37#elif defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050)
38 #pragma clang system_header /* treat file as system include file */
39#endif
40
41#ifndef __CORE_CMINSTR_H
42#define __CORE_CMINSTR_H
43
44
45/* ########################## Core Instruction Access ######################### */
52/*------------------ RealView Compiler -----------------*/
53#if defined ( __CC_ARM )
54 #include "cmsis_armcc.h"
55
56/*------------------ ARM Compiler V6 -------------------*/
57#elif defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050)
58 #include "cmsis_armcc_V6.h"
59
60/*------------------ GNU Compiler ----------------------*/
61#elif defined ( __GNUC__ )
62 #include "cmsis_gcc.h"
63
64/*------------------ ICC Compiler ----------------------*/
65#elif defined ( __ICCARM__ )
66 #include <cmsis_iar.h>
67
68/*------------------ TI CCS Compiler -------------------*/
69#elif defined ( __TMS470__ )
70 #include <cmsis_ccs.h>
71
72/*------------------ TASKING Compiler ------------------*/
73#elif defined ( __TASKING__ )
74 /*
75 * The CMSIS functions have been implemented as intrinsics in the compiler.
76 * Please use "carm -?i" to get an up to date list of all intrinsics,
77 * Including the CMSIS ones.
78 */
79
80/*------------------ COSMIC Compiler -------------------*/
81#elif defined ( __CSMC__ )
82 #include <cmsis_csm.h>
83
84#endif
85 /* end of group CMSIS_Core_InstructionInterface */
87
88#endif /* __CORE_CMINSTR_H */
CMSIS Cortex-M Core Function/Instruction Header File.
