RTEMS
5.2
bsps
arm
include
core_cmFunc.h
1
7
/* Copyright (c) 2009 - 2015 ARM LIMITED
8
9
All rights reserved.
10
Redistribution and use in source and binary forms, with or without
11
modification, are permitted provided that the following conditions are met:
12
- Redistributions of source code must retain the above copyright
13
notice, this list of conditions and the following disclaimer.
14
- Redistributions in binary form must reproduce the above copyright
15
notice, this list of conditions and the following disclaimer in the
16
documentation and/or other materials provided with the distribution.
17
- Neither the name of ARM nor the names of its contributors may be used
18
to endorse or promote products derived from this software without
19
specific prior written permission.
20
21
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
ARE DISCLAIMED. IN NO EVENT SHALL COPYRIGHT HOLDERS AND CONTRIBUTORS BE
25
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
POSSIBILITY OF SUCH DAMAGE.
32
33
34
35
#if defined ( __ICCARM__ )
36
#pragma system_include
/* treat file as system include file for MISRA check */
37
#elif defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050)
38
#pragma clang system_header
/* treat file as system include file */
39
#endif
40
41
#ifndef __CORE_CMFUNC_H
42
#define __CORE_CMFUNC_H
43
44
45
/* ########################### Core Function Access ########################### */
51
/*------------------ RealView Compiler -----------------*/
52
#if defined ( __CC_ARM )
53
#include "cmsis_armcc.h"
54
55
/*------------------ ARM Compiler V6 -------------------*/
56
57
#include "cmsis_armcc_V6.h"
58
59
/*------------------ GNU Compiler ----------------------*/
60
#elif defined ( __GNUC__ )
61
#include "
cmsis_gcc.h
62
63
/*------------------ ICC Compiler ----------------------*/
64
#elif defined ( __ICCARM__ )
65
#include <cmsis_iar.h>
66
67
/*------------------ TI CCS Compiler -------------------*/
68
#elif defined ( __TMS470__ )
69
#include <cmsis_ccs.h>
70
71
/*------------------ TASKING Compiler ------------------*/
72
#elif defined ( __TASKING__ )
73
74
* The CMSIS functions have been implemented as intrinsics in the compiler.
75
* Please use "carm -?i" to get an up to date list of all intrinsics,
76
* Including the CMSIS ones.
77
78
79
/*------------------ COSMIC Compiler -------------------*/
80
#elif defined ( __CSMC__ )
81
#include <cmsis_csm.h>
82
83
#endif
84
87
#endif
/* __CORE_CMFUNC_H */
cmsis_gcc.h
CMSIS Cortex-M Core Function/Instruction Header File.
