36#ifndef _RTEMS_CONFDEFS_SCHEDULER_H
37#define _RTEMS_CONFDEFS_SCHEDULER_H
39#ifndef __CONFIGURATION_TEMPLATE_h
40#error "Do not include this file directly, use <rtems/confdefs.h> instead"
47#if !defined(CONFIGURE_SCHEDULER_CBS) \
48 && !defined(CONFIGURE_SCHEDULER_EDF) \
49 && !defined(CONFIGURE_SCHEDULER_EDF_SMP) \
50 && !defined(CONFIGURE_SCHEDULER_PRIORITY) \
51 && !defined(CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP) \
52 && !defined(CONFIGURE_SCHEDULER_PRIORITY_SMP) \
53 && !defined(CONFIGURE_SCHEDULER_SIMPLE) \
54 && !defined(CONFIGURE_SCHEDULER_SIMPLE_SMP) \
55 && !defined(CONFIGURE_SCHEDULER_STRONG_APA) \
56 && !defined(CONFIGURE_SCHEDULER_USER)
57 #if defined(RTEMS_SMP) && _CONFIGURE_MAXIMUM_PROCESSORS > 1
58 #define CONFIGURE_SCHEDULER_EDF_SMP
60 #define CONFIGURE_SCHEDULER_PRIORITY
70#ifndef CONFIGURE_MAXIMUM_PRIORITY
71 #define CONFIGURE_MAXIMUM_PRIORITY PRIORITY_DEFAULT_MAXIMUM
74#if CONFIGURE_MAXIMUM_PRIORITY != 3 \
75 && CONFIGURE_MAXIMUM_PRIORITY != 7 \
76 && CONFIGURE_MAXIMUM_PRIORITY != 15 \
77 && CONFIGURE_MAXIMUM_PRIORITY != 31 \
78 && CONFIGURE_MAXIMUM_PRIORITY != 63 \
79 && CONFIGURE_MAXIMUM_PRIORITY != 127 \
80 && CONFIGURE_MAXIMUM_PRIORITY != 255
81 #error "CONFIGURE_MAXIMUM_PRIORITY must be one of 3, 7, 15, 31, 63, 127, and 255"
84#if CONFIGURE_MAXIMUM_PRIORITY > PRIORITY_DEFAULT_MAXIMUM
85 #error "CONFIGURE_SCHEDULER_PRIORITY must be less than or equal to the architecture defined maximum priority"
88#ifdef CONFIGURE_SCHEDULER_PRIORITY
89 #ifndef CONFIGURE_SCHEDULER_NAME
90 #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'U', 'P', 'D', ' ' )
93 #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
94 #define CONFIGURE_SCHEDULER \
95 RTEMS_SCHEDULER_PRIORITY( \
97 CONFIGURE_MAXIMUM_PRIORITY + 1 \
100 #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
101 RTEMS_SCHEDULER_TABLE_PRIORITY( dflt, CONFIGURE_SCHEDULER_NAME )
105#ifdef CONFIGURE_SCHEDULER_PRIORITY_SMP
106 #ifndef CONFIGURE_SCHEDULER_NAME
107 #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'M', 'P', 'D', ' ' )
110 #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
111 #define CONFIGURE_SCHEDULER \
112 RTEMS_SCHEDULER_PRIORITY_SMP( \
114 CONFIGURE_MAXIMUM_PRIORITY + 1 \
117 #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
118 RTEMS_SCHEDULER_TABLE_PRIORITY_SMP( dflt, CONFIGURE_SCHEDULER_NAME )
122#ifdef CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
123 #ifndef CONFIGURE_SCHEDULER_NAME
124 #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'M', 'P', 'A', ' ' )
127 #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
128 #define CONFIGURE_SCHEDULER \
129 RTEMS_SCHEDULER_PRIORITY_AFFINITY_SMP( \
131 CONFIGURE_MAXIMUM_PRIORITY + 1 \
134 #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
135 RTEMS_SCHEDULER_TABLE_PRIORITY_AFFINITY_SMP( \
137 CONFIGURE_SCHEDULER_NAME \
142#ifdef CONFIGURE_SCHEDULER_STRONG_APA
143 #ifndef CONFIGURE_SCHEDULER_NAME
144 #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'M', 'A', 'P', 'A' )
147 #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
148 #define CONFIGURE_SCHEDULER \
149 RTEMS_SCHEDULER_STRONG_APA( \
151 CONFIGURE_MAXIMUM_PRIORITY + 1 \
154 #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
155 RTEMS_SCHEDULER_TABLE_STRONG_APA( dflt, CONFIGURE_SCHEDULER_NAME )
159#ifdef CONFIGURE_SCHEDULER_SIMPLE
160 #ifndef CONFIGURE_SCHEDULER_NAME
161 #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'U', 'P', 'S', ' ' )
164 #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
165 #define CONFIGURE_SCHEDULER RTEMS_SCHEDULER_SIMPLE( dflt )
167 #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
168 RTEMS_SCHEDULER_TABLE_SIMPLE( dflt, CONFIGURE_SCHEDULER_NAME )
172#ifdef CONFIGURE_SCHEDULER_SIMPLE_SMP
173 #ifndef CONFIGURE_SCHEDULER_NAME
174 #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'M', 'P', 'S', ' ' )
177 #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
178 #define CONFIGURE_SCHEDULER \
179 RTEMS_SCHEDULER_SIMPLE_SMP( dflt )
181 #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
182 RTEMS_SCHEDULER_TABLE_SIMPLE_SMP( dflt, CONFIGURE_SCHEDULER_NAME )
186#ifdef CONFIGURE_SCHEDULER_EDF
187 #ifndef CONFIGURE_SCHEDULER_NAME
188 #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'U', 'E', 'D', 'F' )
191 #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
192 #define CONFIGURE_SCHEDULER RTEMS_SCHEDULER_EDF( dflt )
194 #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
195 RTEMS_SCHEDULER_TABLE_EDF( dflt, CONFIGURE_SCHEDULER_NAME )
199#ifdef CONFIGURE_SCHEDULER_EDF_SMP
200 #ifndef CONFIGURE_SCHEDULER_NAME
201 #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'M', 'E', 'D', 'F' )
204 #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
205 #define CONFIGURE_SCHEDULER RTEMS_SCHEDULER_EDF_SMP( dflt )
207 #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
208 RTEMS_SCHEDULER_TABLE_EDF_SMP( dflt, CONFIGURE_SCHEDULER_NAME )
212#ifdef CONFIGURE_SCHEDULER_CBS
213 #ifndef CONFIGURE_SCHEDULER_NAME
214 #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'U', 'C', 'B', 'S' )
217 #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
218 #define CONFIGURE_SCHEDULER RTEMS_SCHEDULER_CBS( dflt )
220 #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
221 RTEMS_SCHEDULER_TABLE_CBS( dflt, CONFIGURE_SCHEDULER_NAME )
224 #ifndef CONFIGURE_CBS_MAXIMUM_SERVERS
225 #define CONFIGURE_CBS_MAXIMUM_SERVERS CONFIGURE_MAXIMUM_TASKS
229 CONFIGURE_CBS_MAXIMUM_SERVERS;
235#ifdef CONFIGURE_SCHEDULER
240 CONFIGURE_SCHEDULER_TABLE_ENTRIES
243#define _CONFIGURE_SCHEDULER_COUNT RTEMS_ARRAY_SIZE( _Scheduler_Table )
249const Scheduler_Assignment _Scheduler_Initial_assignments[] = {
250 #ifdef CONFIGURE_SCHEDULER_ASSIGNMENTS
251 CONFIGURE_SCHEDULER_ASSIGNMENTS
253 #define _CONFIGURE_SCHEDULER_ASSIGN \
254 RTEMS_SCHEDULER_ASSIGN( \
256 RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL \
258 _CONFIGURE_SCHEDULER_ASSIGN
259 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 2
260 , _CONFIGURE_SCHEDULER_ASSIGN
262 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 3
263 , _CONFIGURE_SCHEDULER_ASSIGN
265 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 4
266 , _CONFIGURE_SCHEDULER_ASSIGN
268 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 5
269 , _CONFIGURE_SCHEDULER_ASSIGN
271 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 6
272 , _CONFIGURE_SCHEDULER_ASSIGN
274 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 7
275 , _CONFIGURE_SCHEDULER_ASSIGN
277 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 8
278 , _CONFIGURE_SCHEDULER_ASSIGN
280 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 9
281 , _CONFIGURE_SCHEDULER_ASSIGN
283 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 10
284 , _CONFIGURE_SCHEDULER_ASSIGN
286 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 11
287 , _CONFIGURE_SCHEDULER_ASSIGN
289 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 12
290 , _CONFIGURE_SCHEDULER_ASSIGN
292 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 13
293 , _CONFIGURE_SCHEDULER_ASSIGN
295 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 14
296 , _CONFIGURE_SCHEDULER_ASSIGN
298 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 15
299 , _CONFIGURE_SCHEDULER_ASSIGN
301 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 16
302 , _CONFIGURE_SCHEDULER_ASSIGN
304 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 17
305 , _CONFIGURE_SCHEDULER_ASSIGN
307 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 18
308 , _CONFIGURE_SCHEDULER_ASSIGN
310 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 19
311 , _CONFIGURE_SCHEDULER_ASSIGN
313 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 20
314 , _CONFIGURE_SCHEDULER_ASSIGN
316 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 21
317 , _CONFIGURE_SCHEDULER_ASSIGN
319 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 22
320 , _CONFIGURE_SCHEDULER_ASSIGN
322 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 23
323 , _CONFIGURE_SCHEDULER_ASSIGN
325 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 24
326 , _CONFIGURE_SCHEDULER_ASSIGN
328 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 25
329 , _CONFIGURE_SCHEDULER_ASSIGN
331 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 26
332 , _CONFIGURE_SCHEDULER_ASSIGN
334 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 27
335 , _CONFIGURE_SCHEDULER_ASSIGN
337 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 28
338 , _CONFIGURE_SCHEDULER_ASSIGN
340 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 29
341 , _CONFIGURE_SCHEDULER_ASSIGN
343 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 30
344 , _CONFIGURE_SCHEDULER_ASSIGN
346 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 31
347 , _CONFIGURE_SCHEDULER_ASSIGN
349 #if _CONFIGURE_MAXIMUM_PROCESSORS >= 32
350 , _CONFIGURE_SCHEDULER_ASSIGN
352 #undef _CONFIGURE_SCHEDULER_ASSIGN
357 _CONFIGURE_MAXIMUM_PROCESSORS
358 == RTEMS_ARRAY_SIZE( _Scheduler_Initial_assignments ),
359 _Scheduler_Initial_assignments
Evaluate Per-CPU Configuration Options.
Scheduler_CBS_Server _Scheduler_CBS_Server_list[]
const uint32_t _Scheduler_CBS_Maximum_servers
#define _Scheduler_Count
Count of registered schedulers.
Definition: scheduler.h:325
const Scheduler_Control _Scheduler_Table[]
Registered schedulers.
Scheduler Configuration API.
Definition: schedulercbs.h:115
Scheduler control.
Definition: scheduler.h:269
