RTEMS 5.2
malloc.h
2
11/*
12 * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
13 *
16 * are met:
22 *
34 */
35
36#ifndef _RTEMS_CONFDEFS_MALLOC_H
37#define _RTEMS_CONFDEFS_MALLOC_H
38
39#ifndef __CONFIGURATION_TEMPLATE_h
40#error "Do not include this file directly, use <rtems/confdefs.h> instead"
41#endif
42
43#ifdef CONFIGURE_INIT
44
45#include <rtems/confdefs/bsp.h>
46
47#if defined(CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK) \
48 || defined(CONFIGURE_MALLOC_DIRTY)
49#include <rtems/malloc.h>
50#endif
51
52#ifdef __cplusplus
53extern "C" {
54#endif
55
56#ifdef CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
57const rtems_heap_extend_handler rtems_malloc_extend_handler =
59#endif
60
61#ifdef CONFIGURE_MALLOC_DIRTY
62rtems_malloc_dirtier_t rtems_malloc_dirty_helper =
64#endif
65
66#ifdef __cplusplus
67}
68#endif
69
70#endif /* CONFIGURE_INIT */
71
72#endif /* _RTEMS_CONFDEFS_MALLOC_H */
Evaluate BSP Related Configuration Options.
void rtems_malloc_dirty_memory(void *start, size_t size)
Dirty Memory Function.
Definition: malloc_dirtier.c:28
void * rtems_heap_extend_via_sbrk(Heap_Control *heap, size_t alloc_size)
RTEMS Extend Heap via Sbrk.
Definition: rtems_heap_extend_via_sbrk.c:34
