RTEMS 5.2
cfg_static.h
1/* Static PCI Auto Configuration Library
2 *
3 * COPYRIGHT (c) 2010 Cobham Gaisler AB.
4 *
5 * The license and distribution terms for this file may be
6 * found in the file LICENSE in this distribution or at
7 * http://www.rtems.org/license/LICENSE.
8 */
9
10#ifndef __PCI_CFG_STATIC_H__
11#define __PCI_CFG_STATIC_H__
12
13/* This function initializes all buses and device accorind to a user defined
14 * "static" configuration. The configuration can manually created with C
15 * data structures. Or it can be automatically created on a running target
16 * using the pci_cfg_print() routine after the AUTO or READ Configuration
17 * Library has setup the PCI bus
18 */
19extern int pci_config_static(void);
20
21#endif
