RTEMS 5.2
cfg_read.h
1/* PCI Read Configuration Library. Read current config that bootloader/BIOS
2 * has setup.
3 *
4 * COPYRIGHT (c) 2010 Cobham Gaisler AB.
5 *
6 * The license and distribution terms for this file may be
7 * found in the file LICENSE in this distribution or at
8 * http://www.rtems.org/license/LICENSE.
9 */
10
11
12#ifndef __PCI_CFG_READ_H__
13#define __PCI_CFG_READ_H__
14
15/* Build PCI device tree in "struct pci_bus pci_hb" according to current setup
16 * in hardware. Devices/buses are created by reading the resource assignments
17 * that the BIOS/bootloader has already setup for us.
18 */
19extern int pci_config_read(void);
20
21#endif
