RTEMS 5.2
cfg_auto.h
1/* PCI Auto Configuration Library
2 *
3 * COPYRIGHT (c) 2010 Cobham Gaisler AB.
4 *
5 * The license and distribution terms for this file may be
6 * found in the file LICENSE in this distribution or at
7 * http://www.rtems.org/license/LICENSE.
8 */
9
10#ifndef __PCI_CFG_AUTO_H__
11#define __PCI_CFG_AUTO_H__
12
13#define CFGOPT_NOSETUP_IRQ 0x1 /* Skip IRQ setup */
14
15/* PCI Memory Layout setup, used by the auto-config library in order to
16 * determine the addresses of PCI BARs and Buses.
17 *
18 * All addresses are in PCI address space, the actual address the CPU access
19 * may be different, and taken care of elsewhere.
20 */
22 int options;
23
24 /* PCI prefetchable Memory space (OPTIONAL) */
25 uint32_t mem_start;
26 uint32_t mem_size; /* 0 = Use MEMIO space for prefetchable mem BARs */
27
28 /* PCI non-prefetchable Memory */
29 uint32_t memio_start;
30 uint32_t memio_size;
31
32 /* PCI I/O space (OPTIONAL) */
33 uint32_t io_start;
34 uint32_t io_size; /* 0 = No I/O space */
35
36 /* Get System IRQ connected to a PCI line of a PCI device on bus0.
37 * The return IRQ value zero equals no IRQ (IRQ disabled).
38 */
39 uint8_t (*irq_map)(pci_dev_t dev, int irq_pin);
40
41 /* IRQ Bridge routing. Returns the interrupt pin (0..3 = A..D) that
42 * a device is connected to on parent bus.
43 */
44 int (*irq_route)(pci_dev_t dev, int irq_pin);
45};
46
47/* Do PCI initialization: Enumrate buses, scan buses for devices, assign
48 * I/O MEM and MEMIO resources, assign IRQ and so on.
49 */
50extern int pci_config_auto(void);
51
52/* Register a configuration for the auto library (struct pci_auto_setup *) */
53extern void pci_config_auto_register(void *config);
54
55/* PCI memory map */
56extern struct pci_auto_setup pci_auto_cfg;
57
58#endif
Definition: deflate.c:115
Definition: cfg_auto.h:21
