RTEMS 5.2
Common CAN baud-rate routines for OCCAN/GRCAN/GRCANFD controllers. More...
#include <grlib/canbtrs.h>Functions | |
| int | grlib_canbtrs_calc_timing (unsigned int baud, unsigned int core_hz, unsigned int sampl_pt, struct grlib_canbtrs_ranges *br, struct grlib_canbtrs_timing *timing) |
Implements common routines for calculating CAN baud-rate parameters from a user provided baud-rate speed.
