RTEMS
5.2
bsps
arm
include
bsp
cadence-spi.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* Copyright (C) 2021 Jan Sommer, German Aerospace Center (DLR)
5
6
7
* modification, are permitted provided that the following conditions
8
* are met:
9
* 1. Redistributions of source code must retain the above copyright
10
* notice, this list of conditions and the following disclaimer.
11
* 2. Redistributions in binary form must reproduce the above copyright
12
* notice, this list of conditions and the following disclaimer in the
13
* documentation and/or other materials provided with the distribution.
14
15
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25
* POSSIBILITY OF SUCH DAMAGE.
26
27
28
#ifndef LIBBSP_ARM_XILINX_ZYNQ_CADENCE_SPI_H
29
#define LIBBSP_ARM_XILINX_ZYNQ_CADENCE_SPI_H
30
31
rtems.h
32
33
#ifdef __cplusplus
34
extern
"C"
35
#endif
/* __cplusplus */
36
52
int
spi_bus_register_cadence(
53
const
char
*bus_path,
54
uintptr_t register_base,
55
uint32_t input_clock,
56
rtems_vector_number
irq
57
58
59
#ifdef __cplusplus
60
61
#endif
/* __cplusplus */
62
63
#endif
/* LIBBSP_ARM_XILINX_ZYNQ_CADENCE_SPI_H */
rtems_vector_number
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition:
intr.h:47
rtems.h
