RTEMS
5.2
bsps
powerpc
include
libcpu
c_clock.h
1
2
* Clock Tick Device Driver
3
4
* This routine utilizes the Decrementer Register common to the PPC family.
5
6
* The tick frequency is directly programmed to the configured number of
7
* microseconds per tick.
8
9
* COPYRIGHT (c) 1989-1997.
10
* On-Line Applications Research Corporation (OAR).
11
12
* The license and distribution terms for this file may in
13
* the file LICENSE in this distribution or at
14
* http://www.rtems.org/license/LICENSE.
15
16
* Modified to support the MPC750.
17
* Modifications Copyright (c) 1999 Eric Valette valette@crf.canon.fr
18
19
20
#ifndef _LIBCPU_C_CLOCK_H
21
#define _LIBCPU_C_CLOCK_H
22
23
rtems.h
24
25
26
* These functions and variables represent the API exported by the
27
* CPU to the BSP.
28
29
30
extern
void
clockOff (
void
* unused);
31
extern
void
clockOn (
void
* unused);
32
extern
void
clockIsr (
void
* unused);
33
/* bookE decrementer is slightly different */
34
extern
void
clockIsrBookE (
void
*unused);
35
extern
int
clockIsOn (
void
* unused);
36
37
38
* These functions and variables represent the assumptions of this
39
* driver on the BSP.
40
41
42
extern
int
BSP_disconnect_clock_handler (
void
43
44
* PCI Bus Frequency
45
46
extern
unsigned
int
BSP_bus_frequency;
47
48
* processor clock frequency
49
50
extern
unsigned
int
BSP_processor_frequency;
51
52
* Time base divisior (how many tick for 1 second).
53
54
extern
unsigned
int
BSP_time_base_divisor;
55
56
#endif
rtems.h
