RTEMS 5.2
riscv.h
1/*
2 * Copyright (c) 2018 embedded brains GmbH
3 *
4 * Redistribution and use in source and binary forms, with or without
5 * modification, are permitted provided that the following conditions
6 * are met:
7 * 1. Redistributions of source code must retain the above copyright
8 * notice, this list of conditions and the following disclaimer.
9 * 2. Redistributions in binary form must reproduce the above copyright
10 * notice, this list of conditions and the following disclaimer in the
11 * documentation and/or other materials provided with the distribution.
12 *
13 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
14 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
15 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
16 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
17 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
18 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
19 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
20 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
21 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
22 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
23 * SUCH DAMAGE.
24 */
25
26#ifndef BSP_RISCV_H
27#define BSP_RISCV_H
28
29#include <bsp.h>
30
31#include <rtems/score/cpuimpl.h>
32
33#ifdef __cplusplus
34extern "C" {
35#endif
36
37extern volatile RISCV_CLINT_regs *riscv_clint;
38
39void *riscv_fdt_get_address(const void *fdt, int node);
40
41uint32_t riscv_get_core_frequency(void);
42
43#ifdef RTEMS_SMP
44extern uint32_t riscv_hart_count;
45#else
46#define riscv_hart_count 1
47#endif
48
49uint32_t riscv_get_hart_index_by_phandle(uint32_t phandle);
50
51#if RISCV_ENABLE_HTIF_SUPPORT != 0
52void htif_poweroff(void);
53#endif
54
55#ifdef __cplusplus
56}
57#endif
58
59#endif /* BSP_RISCV_H */
Definition: cpuimpl.h:306
