RTEMS 5.2
Global BSP definitions. More...
#include <bspopts.h>
#include <libcpu/powerpc-utility.h>
#include <bsp/tictac.h>
#include <bsp/linker-symbols.h>
#include <bsp/default-initial-extension.h>
#define | BSP_FEATURE_IRQ_EXTENSION |
#define | MPC55XX_PERIPHERAL_CLOCK (MPC55XX_SYSTEM_CLOCK / MPC55XX_SYSTEM_CLOCK_DIVIDER) |
#define | BSP_Convert_decrementer(_value) (((unsigned long long) (_value)) / ((unsigned long long)bsp_clicks_per_usec)) |
Convert Decrementer ticks to microseconds. | |
#define | RTEMS_BSP_NETWORK_DRIVER_ATTACH smsc9218i_attach_detach |
#define | RTEMS_BSP_NETWORK_DRIVER_NAME "eth0" |
#define | BSP_IDLE_TASK_BODY bsp_idle_thread |
#define | BSP_DSRAM_SECTION __attribute__((section(".bsp_dsram"))) |
#define | BSP_SYSRAM_SECTION __attribute__((section(".bsp_sysram"))) |
rtems_status_code | mpc55xx_sd_card_init (bool mount) |
int | smsc9218i_attach_detach (struct rtems_bsdnet_ifconfig *config, int attaching) |
rtems_status_code | bsp_register_i2c (void) |
void | bsp_restart (void *addr) |
void * | bsp_idle_thread (uintptr_t arg) |
Optimized idle task. More... | |
unsigned int | bsp_clock_speed |
System clock frequency. | |
uint32_t | bsp_clicks_per_usec |
Time base clicks per micro second. | |
