RTEMS 5.2
irq.h
1/*
2 * irq.h
3 *
4 * This include file describe the data structure and the functions implemented
5 * by rtems to write interrupt handlers.
6 *
7 *
8 * MPC5xx port sponsored by Defence Research and Development Canada - Suffield
9 * Copyright (C) 2004, Real-Time Systems Inc. (querbach@realtime.bc.ca)
10 *
11 * Derived from libbsp/powerpc/mbx8xx/irq/irq.h:
12 *
13 * CopyRight (C) 1999 valette@crf.canon.fr
14 *
15 * This code is heavilly inspired by the public specification of STREAM V2
16 * that can be found at :
17 *
18 * <http://www.chorus.com/Documentation/index.html> by following
19 * the STREAM API Specification Document link.
20 *
21 * The license and distribution terms for this file may be
22 * found in the file LICENSE in this distribution or at
23 * http://www.rtems.org/license/LICENSE.
24 */
25
26#ifndef _LIBCPU_IRQ_H
27#define _LIBCPU_IRQ_H
28
29#include <rtems/irq.h>
30
31#define CPU_ASM_IRQ_VECTOR_BASE 0x0
32
33#ifndef ASM
34
35extern volatile unsigned int ppc_cached_irq_mask;
36
37/*
38 * Symblolic IRQ names and related definitions.
39 */
40
41 /*
42 * Base vector for our USIU IRQ handlers.
43 */
44#define CPU_USIU_VECTOR_BASE (CPU_ASM_IRQ_VECTOR_BASE)
45 /*
46 * USIU IRQ handler related definitions
47 */
48#define CPU_USIU_IRQ_COUNT (16) /* 16 reserved but in the future... */
49#define CPU_USIU_IRQ_MIN_OFFSET (0)
50#define CPU_USIU_IRQ_MAX_OFFSET (CPU_USIU_IRQ_MIN_OFFSET + CPU_USIU_IRQ_COUNT - 1)
51 /*
52 * UIMB IRQ handlers related definitions
53 */
54#define CPU_UIMB_IRQ_COUNT (32 - 8) /* first 8 overlap USIU */
55#define CPU_UIMB_IRQ_MIN_OFFSET (CPU_USIU_IRQ_COUNT + CPU_USIU_VECTOR_BASE)
56#define CPU_UIMB_IRQ_MAX_OFFSET (CPU_UIMB_IRQ_MIN_OFFSET + CPU_UIMB_IRQ_COUNT - 1)
57 /*
58 * PowerPc exceptions handled as interrupt where a rtems managed interrupt
59 * handler might be connected
60 */
61#define CPU_PROC_IRQ_COUNT (1)
62#define CPU_PROC_IRQ_MIN_OFFSET (CPU_UIMB_IRQ_MAX_OFFSET + 1)
63#define CPU_PROC_IRQ_MAX_OFFSET (CPU_PROC_IRQ_MIN_OFFSET + CPU_PROC_IRQ_COUNT - 1)
64 /*
65 * Summary
66 */
67#define CPU_IRQ_COUNT (CPU_PROC_IRQ_MAX_OFFSET + 1)
68#define CPU_MIN_OFFSET (CPU_USIU_IRQ_MIN_OFFSET)
69#define CPU_MAX_OFFSET (CPU_PROC_IRQ_MAX_OFFSET)
70 /*
71 * USIU IRQ symbolic name definitions.
72 */
73#define CPU_USIU_EXT_IRQ_0 (CPU_USIU_IRQ_MIN_OFFSET + 0)
74#define CPU_USIU_INT_IRQ_0 (CPU_USIU_IRQ_MIN_OFFSET + 1)
75
76#define CPU_USIU_EXT_IRQ_1 (CPU_USIU_IRQ_MIN_OFFSET + 2)
77#define CPU_USIU_INT_IRQ_1 (CPU_USIU_IRQ_MIN_OFFSET + 3)
78
79#define CPU_USIU_EXT_IRQ_2 (CPU_USIU_IRQ_MIN_OFFSET + 4)
80#define CPU_USIU_INT_IRQ_2 (CPU_USIU_IRQ_MIN_OFFSET + 5)
81
82#define CPU_USIU_EXT_IRQ_3 (CPU_USIU_IRQ_MIN_OFFSET + 6)
83#define CPU_USIU_INT_IRQ_3 (CPU_USIU_IRQ_MIN_OFFSET + 7)
84
85#define CPU_USIU_EXT_IRQ_4 (CPU_USIU_IRQ_MIN_OFFSET + 8)
86#define CPU_USIU_INT_IRQ_4 (CPU_USIU_IRQ_MIN_OFFSET + 9)
87
88#define CPU_USIU_EXT_IRQ_5 (CPU_USIU_IRQ_MIN_OFFSET + 10)
89#define CPU_USIU_INT_IRQ_5 (CPU_USIU_IRQ_MIN_OFFSET + 11)
90
91#define CPU_USIU_EXT_IRQ_6 (CPU_USIU_IRQ_MIN_OFFSET + 12)
92#define CPU_USIU_INT_IRQ_6 (CPU_USIU_IRQ_MIN_OFFSET + 13)
93
94#define CPU_USIU_EXT_IRQ_7 (CPU_USIU_IRQ_MIN_OFFSET + 14)
95#define CPU_USIU_INT_IRQ_7 (CPU_USIU_IRQ_MIN_OFFSET + 15)
96
97 /*
98 * Symbolic names for UISU interrupt sources.
99 */
100#define CPU_PERIODIC_TIMER (CPU_USIU_INT_IRQ_6)
101#define CPU_UIMB_INTERRUPT (CPU_USIU_INT_IRQ_7)
102
103 /*
104 * UIMB IRQ symbolic name definitions. The first 8 sources are aliases to
105 * the USIU interrupts of the same number, because they are detected in
106 * the USIU pending register rather than the UIMB pending register.
107 */
108#define CPU_UIMB_IRQ_0 (CPU_USIU_INT_IRQ_0)
109#define CPU_UIMB_IRQ_1 (CPU_USIU_INT_IRQ_1)
110#define CPU_UIMB_IRQ_2 (CPU_USIU_INT_IRQ_2)
111#define CPU_UIMB_IRQ_3 (CPU_USIU_INT_IRQ_3)
112#define CPU_UIMB_IRQ_4 (CPU_USIU_INT_IRQ_4)
113#define CPU_UIMB_IRQ_5 (CPU_USIU_INT_IRQ_5)
114#define CPU_UIMB_IRQ_6 (CPU_USIU_INT_IRQ_6)
115#define CPU_UIMB_IRQ_7 (CPU_USIU_INT_IRQ_7)
116
117#define CPU_UIMB_IRQ_8 (CPU_UIMB_IRQ_MIN_OFFSET+ 0)
118#define CPU_UIMB_IRQ_9 (CPU_UIMB_IRQ_MIN_OFFSET+ 1)
119#define CPU_UIMB_IRQ_10 (CPU_UIMB_IRQ_MIN_OFFSET+ 2)
120#define CPU_UIMB_IRQ_11 (CPU_UIMB_IRQ_MIN_OFFSET+ 3)
121#define CPU_UIMB_IRQ_12 (CPU_UIMB_IRQ_MIN_OFFSET+ 4)
122#define CPU_UIMB_IRQ_13 (CPU_UIMB_IRQ_MIN_OFFSET+ 5)
123#define CPU_UIMB_IRQ_14 (CPU_UIMB_IRQ_MIN_OFFSET+ 6)
124#define CPU_UIMB_IRQ_15 (CPU_UIMB_IRQ_MIN_OFFSET+ 7)
125#define CPU_UIMB_IRQ_16 (CPU_UIMB_IRQ_MIN_OFFSET+ 8)
126#define CPU_UIMB_IRQ_17 (CPU_UIMB_IRQ_MIN_OFFSET+ 9)
127#define CPU_UIMB_IRQ_18 (CPU_UIMB_IRQ_MIN_OFFSET+ 0)
128#define CPU_UIMB_IRQ_19 (CPU_UIMB_IRQ_MIN_OFFSET+11)
129#define CPU_UIMB_IRQ_20 (CPU_UIMB_IRQ_MIN_OFFSET+12)
130#define CPU_UIMB_IRQ_21 (CPU_UIMB_IRQ_MIN_OFFSET+13)
131#define CPU_UIMB_IRQ_22 (CPU_UIMB_IRQ_MIN_OFFSET+14)
132#define CPU_UIMB_IRQ_23 (CPU_UIMB_IRQ_MIN_OFFSET+15)
133#define CPU_UIMB_IRQ_24 (CPU_UIMB_IRQ_MIN_OFFSET+16)
134#define CPU_UIMB_IRQ_25 (CPU_UIMB_IRQ_MIN_OFFSET+17)
135#define CPU_UIMB_IRQ_26 (CPU_UIMB_IRQ_MIN_OFFSET+18)
136#define CPU_UIMB_IRQ_27 (CPU_UIMB_IRQ_MIN_OFFSET+19)
137#define CPU_UIMB_IRQ_28 (CPU_UIMB_IRQ_MIN_OFFSET+20)
138#define CPU_UIMB_IRQ_29 (CPU_UIMB_IRQ_MIN_OFFSET+21)
139#define CPU_UIMB_IRQ_30 (CPU_UIMB_IRQ_MIN_OFFSET+22)
140#define CPU_UIMB_IRQ_31 (CPU_UIMB_IRQ_MIN_OFFSET+23)
141
142 /*
143 * Symbolic names for UIMB interrupt sources.
144 */
145#define CPU_IRQ_SCI (CPU_UIMB_IRQ_5)
146
147 /*
148 * Processor exceptions handled as rtems IRQ symbolic name definitions.
149 */
150#define CPU_DECREMENTER (CPU_PROC_IRQ_MIN_OFFSET)
151
152/*
153 * Convert an rtems_irq_number constant to an interrupt level
154 * suitable for programming into an I/O device's interrupt level field.
155 */
156int CPU_irq_level_from_symbolic_name(const rtems_irq_number name);
157
158/*-------------------------------------------------------------------------+
159| Function Prototypes.
160+--------------------------------------------------------------------------*/
161
162extern void CPU_rtems_irq_mng_init(unsigned cpuId);
163
165 uint32_t stacklink; /* Ensure this is a real frame (also reg1 save) */
166 uint32_t calleeLr; /* link register used by callees: SVR4/EABI */
167
168 /* This is what is left out of the primary contexts */
169 uint32_t gpr0;
170 uint32_t gpr2; /* play safe */
171 uint32_t gpr3;
172 uint32_t gpr4;
173 uint32_t gpr5;
174 uint32_t gpr6;
175 uint32_t gpr7;
176 uint32_t gpr8;
177 uint32_t gpr9;
178 uint32_t gpr10;
179 uint32_t gpr11;
180 uint32_t gpr12;
181 uint32_t gpr13; /* Play safe */
182 uint32_t gpr28; /* For internal use by the IRQ handler */
183 uint32_t gpr29; /* For internal use by the IRQ handler */
184 uint32_t gpr30; /* For internal use by the IRQ handler */
185 uint32_t gpr31; /* For internal use by the IRQ handler */
186 uint32_t cr; /* Bits of this are volatile, so no-one may save */
187 uint32_t ctr;
188 uint32_t xer;
189 uint32_t lr;
190 uint32_t pc;
191 uint32_t msr;
192 uint32_t pad[3];
194
195void C_dispatch_irq_handler(MPC5XX_Interrupt_frame *frame, unsigned int excNum);
196
197#endif
198
199#endif
Definition: irq.h:164
