RTEMS 5.2
bsp.h
1
9/*===============================================================*\
10| Project: RTEMS generic MPC5200 BSP |
11+-----------------------------------------------------------------+
12| Partially based on the code references which are named below. |
13| Adaptions, modifications, enhancements and any recent parts of |
14| the code are: |
15| Copyright (c) 2005 |
16| Embedded Brains GmbH |
17| Obere Lagerstr. 30 |
18| D-82178 Puchheim |
19| Germany |
20| rtems@embedded-brains.de |
21+-----------------------------------------------------------------+
22| The license and distribution terms for this file may be |
23| found in the file LICENSE in this distribution or at |
24| |
25| http://www.rtems.org/license/LICENSE. |
26| |
27+-----------------------------------------------------------------+
28| this file contains board specific definitions |
29\*===============================================================*/
30
31#ifndef LIBBSP_POWERPC_GEN5200_BSP_H
32#define LIBBSP_POWERPC_GEN5200_BSP_H
33
44#include <bspopts.h>
45
47
48/*
49 * Some symbols defined in the linker command file.
50 */
51
52LINKER_SYMBOL(bsp_ram_start);
53LINKER_SYMBOL(bsp_ram_end);
54LINKER_SYMBOL(bsp_ram_size);
55
56LINKER_SYMBOL(bsp_rom_start);
57LINKER_SYMBOL(bsp_rom_end);
58LINKER_SYMBOL(bsp_rom_size);
59
60LINKER_SYMBOL(bsp_dpram_start);
61LINKER_SYMBOL(bsp_dpram_end);
62LINKER_SYMBOL(bsp_dpram_size);
63
64LINKER_SYMBOL(bsp_section_text_start);
65LINKER_SYMBOL(bsp_section_text_end);
66LINKER_SYMBOL(bsp_section_text_size);
67
68LINKER_SYMBOL(bsp_section_data_start);
69LINKER_SYMBOL(bsp_section_data_end);
70LINKER_SYMBOL(bsp_section_data_size);
71
72LINKER_SYMBOL(bsp_section_bss_start);
73LINKER_SYMBOL(bsp_section_bss_end);
74LINKER_SYMBOL(bsp_section_bss_size);
75
76LINKER_SYMBOL(bsp_work_area_start);
77
78LINKER_SYMBOL(MBAR);
79
80/* Provide legacy defines */
81
82#ifdef MPC5200_BOARD_PM520_ZE30
83#define PM520_ZE30
84#endif
85
86#ifdef MPC5200_BOARD_PM520_CR825
87#define PM520_CR825
88#endif
89
90#ifdef MPC5200_BOARD_ICECUBE
91#define icecube
92#endif
93
94#ifdef MPC5200_BOARD_BRS5L
95#define BRS5L
96#endif
97
98/*
99 * distinguish board characteristics
100 */
101/*
102 * for PM520 mdule on a ZE30 carrier
103 */
104#if defined(MPC5200_BOARD_PM520_ZE30)
105#define PM520
106#endif
107/*
108 * for PM520 mdule on a CR825 carrier
109 */
110#if defined(MPC5200_BOARD_PM520_CR825)
111#define PM520
112#endif
113
114#if !defined(HAS_UBOOT)
115 /* we need the low level initialization in start.S*/
116 #define NEED_LOW_LEVEL_INIT
117#endif
118
119#if defined(MPC5200_BOARD_BRS5L)
120/*
121 * IMD Custom Board BRS5L
122 */
123
124#define HAS_NVRAM_93CXX
125
126#elif defined(MPC5200_BOARD_BRS6L)
127 #define MPC5200_BRS6L_FPGA_BEGIN 0x800000
128 #define MPC5200_BRS6L_FPGA_SIZE (64 * 1024)
129 #define MPC5200_BRS6L_FPGA_END \
130 (MPC5200_BRS6L_FPGA_BEGIN + MPC5200_BRS6L_FPGA_SIZE)
131
132 #define MPC5200_BRS6L_MRAM_BEGIN 0xff000000
133 #define MPC5200_BRS6L_MRAM_SIZE (4 * 1024 * 1024)
134 #define MPC5200_BRS6L_MRAM_END \
135 (MPC5200_BRS6L_MRAM_BEGIN + MPC5200_BRS6L_MRAM_SIZE)
136#elif defined (PM520)
137
138/* Nothing special */
139
140#elif defined (MPC5200_BOARD_ICECUBE)
141/*
142 * Codename: IceCube
143 * Compatible Boards:
144 * Freescape MPC5200LITE
145 * Embedded Planet EP5200
146 */
147
148#elif defined (MPC5200_BOARD_DP2)
149
150/* Nothing special */
151
152#else
153#error "board type not defined"
154#endif
155
156#ifndef ASM
157
158#include <rtems.h>
159#include <bsp/i2cdrv.h>
160#include <bsp/irq.h>
161#include <bsp/vectors.h>
162#include <bsp/u-boot.h>
164
165#ifdef __cplusplus
166extern "C" {
167#endif
168
169/*
170 * Network driver configuration
171 */
172struct rtems_bsdnet_ifconfig;
173extern int rtems_mpc5200_fec_driver_attach_detach (struct rtems_bsdnet_ifconfig *config, int attaching);
174#define RTEMS_BSP_NETWORK_DRIVER_NAME "eth1"
175#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_mpc5200_fec_driver_attach_detach
176
177/* miscellaneous stuff assumed to exist */
178
179/*
180 * We need to decide how much memory will be non-cacheable. This
181 * will mainly be memory that will be used in DMA (network and serial
182 * buffers).
183 */
184/*
185#define NOCACHE_MEM_SIZE 512*1024
186*/
187
188/*
189 * Device Driver Table Entries
190 */
191
192#ifdef HAS_NVRAM_93CXX
193#define NVRAM_DRIVER_TABLE_ENTRY \
194 { nvram_driver_initialize, nvram_driver_open, nvram_driver_close, \
195 nvram_driver_read, nvram_driver_write, NULL }
196#endif
197
198/*
199 * indicate, that BSP has IDE driver
200 */
201#define RTEMS_BSP_HAS_IDE_DRIVER
202
203/* functions */
204
205/* #define SHOW_MORE_INIT_SETTINGS 1 */
206
207/* ata modes */
208/* #undef ATA_USE_INT */
209#define ATA_USE_INT
210
211/* clock settings */
212#if defined(HAS_UBOOT)
213#define IPB_CLOCK (bsp_uboot_board_info.bi_ipbfreq)
214#define XLB_CLOCK (bsp_uboot_board_info.bi_busfreq)
215#define G2_CLOCK (bsp_uboot_board_info.bi_intfreq)
216#elif defined(MPC5200_BOARD_BRS5L) || defined(MPC5200_BOARD_BRS6L)
217#define IPB_CLOCK 66000000 /* 66 MHz */
218#define XLB_CLOCK 132000000 /* 132 MHz */
219#define G2_CLOCK 396000000 /* 396 MHz */
220#else
221#define IPB_CLOCK 33000000 /* 33 MHz */
222#define XLB_CLOCK 66000000 /* 66 MHz */
223#define G2_CLOCK 231000000 /* 231 MHz */
224#endif
225
226#if defined(HAS_UBOOT)
227#define GEN5200_CONSOLE_BAUD (bsp_uboot_board_info.bi_baudrate)
228#else
229#define GEN5200_CONSOLE_BAUD 115200
230#endif
231
232/*
233 * Convert decrement value to tenths of microsecnds (used by
234 * shared timer driver).
235 *
236 * + CPU has a XLB_CLOCK bus,
237 * + There are 4 bus cycles per click
238 * + We return value in 1/10 microsecond units.
239 * Modified following equation to integer equation to remove
240 * floating point math.
241 * (int) ((float)(_value) / ((XLB_CLOCK/1000000 * 0.1) / 4.0))
242 */
243
244#define BSP_Convert_decrementer( _value ) \
245 (int) (((_value) * 4000) / (XLB_CLOCK/10000))
246
247/* slicetimer settings */
248#define USE_SLICETIMER_0 TRUE
249#define USE_SLICETIMER_1 FALSE
250
251void *bsp_idle_thread( uintptr_t ignored );
252#define BSP_IDLE_TASK_BODY bsp_idle_thread
253
254/* BSP specific IRQ Benchmarking support */
255void BSP_IRQ_Benchmarking_Reset(void);
256void BSP_IRQ_Benchmarking_Report(void);
257
258#if defined(HAS_UBOOT)
259 /* Routine to obtain U-Boot environment variables */
260 const char *bsp_uboot_getenv(
261 const char *name
262 );
263#endif
264
265void cpu_init(void);
266
267int mpc5200_eth_mii_read(
268 int phyAddr,
269 void *arg,
270 unsigned regAddr,
271 uint32_t *retVal
272);
273
274#ifdef __cplusplus
275}
276#endif
277
278#endif /* ASM */
279
282#endif /* GEN5200 */
PowerPC Exceptions API.
DEFAULT_INITIAL_EXTENSION Support.
void * bsp_idle_thread(uintptr_t ignored)
Optimized idle task.
Definition: bspidle.c:26
General purpose assembler macros, linker command file support and some inline functions for direct re...
Definition: deflate.c:115
U_BOOT Support.
