RTEMS 5.2
Board Support Package for ‘Generic’ Motorola MC68360. More...
#include <bspopts.h>
#include <bsp/default-initial-extension.h>
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "scc1"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_scc1_driver_attach
#define ATLASHSB_ESR   0x20010000L
#define ATLASHSB_USICR   0x20010001L
#define ATLASHSB_DSRR   0x20010002L
#define ATLASHSB_LED4   0x20010004L
#define ATLASHSB_ROM_U6   0xFF080000L /* U6 flash ROM socket */
int rtems_scc1_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching)
void M360ExecuteRISC (uint16_t command)
void * M360AllocateBufferDescriptors (int count)
void * M360AllocateRiscTimers (int count)
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler. More...
void _Init68360 (void)
rtems_isr_entry M68Kvec []
char M360DefaultWatchdogFeeder
int m360_clock_rate
