RTEMS 5.2
bsp.h
1
9/* bsp.h
10 *
11 * This include file contains all board IO definitions.
12 *
13 * The license and distribution terms for this file may be
14 * found in the file LICENSE in this distribution or at
15 * http://www.rtems.org/license/LICENSE.
16 *
17 * COPYRIGHT (c) 2011 Sebastien Bourdeauducq
18 */
19
20#ifndef LIBBSP_LM32_MILKYMIST_BSP_H
21#define LIBBSP_LM32_MILKYMIST_BSP_H
22
23#include <stdint.h>
24#include <bspopts.h>
26
27#include <rtems.h>
28
39#ifdef __cplusplus
40extern "C" {
41#endif
42
43#define BSP_HAS_FRAME_BUFFER 1
44
45/*
46 * lm32 requires certain aligment of mbuf because unaligned uint32_t
47 * accesses are not handled properly.
48 */
49
50#define CPU_U32_FIX
51
52#if defined(RTEMS_NETWORKING)
53struct rtems_bsdnet_ifconfig;
54extern int rtems_minimac_driver_attach (struct rtems_bsdnet_ifconfig *config,
55 int attaching);
56#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_minimac_driver_attach
57#define RTEMS_BSP_NETWORK_DRIVER_NAME "minimac0"
58#endif
59
60#ifdef __cplusplus
61}
62#endif
63
66#endif
DEFAULT_INITIAL_EXTENSION Support.
Definition: deflate.c:115
