RTEMS 5.2
rtc.h
1/*
2 * This file contains the Real-Time Clock definitions.
3 *
4 * COPYRIGHT (c) 1989-1999.
5 * On-Line Applications Research Corporation (OAR).
6 *
7 * The license and distribution terms for this file may be
8 * found in the file LICENSE in this distribution or at
9 * http://www.rtems.org/license/LICENSE.
10 */
11
12#ifndef __LIBCHIP_RTC_h
13#define __LIBCHIP_RTC_h
14
15#include <stdbool.h>
16#include <stdint.h>
17
18#include <rtems.h>
19
20/*
21 * Types for get and set register routines
22 */
23
24typedef uint32_t (*getRegister_f)(uintptr_t port, uint8_t reg);
25typedef void (*setRegister_f)(uintptr_t port, uint8_t reg, uint32_t value);
26
27typedef struct _rtc_fns {
28 void (*deviceInitialize)(int minor);
29 int (*deviceGetTime)(int minor, rtems_time_of_day *time);
30 int (*deviceSetTime)(int minor, const rtems_time_of_day *time);
31} rtc_fns;
32
33typedef enum {
34 RTC_M48T08, /* SGS-Thomsom M48T08 or M48T18 */
35 RTC_ICM7170, /* Harris ICM-7170 */
36 RTC_CUSTOM, /* BSP specific driver */
37 RTC_MC146818A /* Motorola MC146818A */
38} rtc_devs;
39
40/*
41 * Each field is interpreted thus:
42 *
43 * sDeviceName This is the name of the device.
44 *
45 * deviceType This indicates the chip type.
46 *
47 * pDeviceFns This is a pointer to the set of driver routines to use.
48 *
49 * pDeviceParams This contains either device specific data or a pointer to a
50 * device specific information table.
51 *
52 * ulCtrlPort1 This is the primary control port number for the device.
53 *
54 * ulDataPort This is the port number for the data port of the device
55 *
56 * getRegister This is the routine used to read register values.
57 *
58 * setRegister This is the routine used to write register values.
59 */
60
61typedef struct _rtc_tbl {
62 const char *sDeviceName;
63 rtc_devs deviceType;
64 const rtc_fns *pDeviceFns;
65 bool (*deviceProbe)(int minor);
66 void *pDeviceParams;
67 uintptr_t ulCtrlPort1;
68 uintptr_t ulDataPort;
69 getRegister_f getRegister;
70 setRegister_f setRegister;
71} rtc_tbl;
72
73extern rtc_tbl RTC_Table[];
74extern size_t RTC_Count;
75
76
77extern bool rtc_probe( int minor );
78
79#endif
80/* end of include file */
Definition: rtc.h:27
Definition: rtc.h:61
Data structure to manage and manipulate calendar time.
Definition: types.h:141
