RTEMS
5.2
bsps
arm
xilinx-zynq
include
bsp.h
1
7
8
* SPDX-License-Identifier: BSD-2-Clause
9
10
* Copyright (C) 2013, 2014 embedded brains GmbH
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
#ifndef LIBBSP_ARM_XILINX_ZYNQ_BSP_H
35
#define LIBBSP_ARM_XILINX_ZYNQ_BSP_H
36
47
#include <bspopts.h>
48
49
#define BSP_FEATURE_IRQ_EXTENSION
50
51
#ifndef ASM
52
53
rtems.h
54
55
bsp/default-initial-extension.h
56
#include <bsp/start.h>
57
bsp/zynq-uart.h
58
59
#ifdef __cplusplus
60
extern
"C"
61
#endif
/* __cplusplus */
62
63
#define BSP_ARM_A9MPCORE_SCU_BASE 0xf8f00000
64
65
#define BSP_ARM_GIC_CPUIF_BASE 0xf8f00100
66
67
#define BSP_ARM_A9MPCORE_GT_BASE 0xf8f00200
68
69
#define BSP_ARM_A9MPCORE_PT_BASE 0xf8f00600
70
71
#define BSP_ARM_GIC_DIST_BASE 0xf8f01000
72
73
#define BSP_ARM_L2C_310_BASE 0xf8f02000
74
75
#define BSP_ARM_L2C_310_ID 0x410000c8
76
77
extern
zynq_uart_context
zynq_uart_instances[2];
78
87
BSP_START_TEXT_SECTION
void
zynq_setup_mmu_and_cache
void
88
89
uint32_t zynq_clock_cpu_1x(
void
90
91
#ifdef __cplusplus
92
93
#endif
/* __cplusplus */
94
95
#endif
/* ASM */
96
99
#endif
/* LIBBSP_ARM_XILINX_ZYNQ_BSP_H */
DEFAULT_INITIAL_EXTENSION Support.
BSP_START_TEXT_SECTION void zynq_setup_mmu_and_cache(void)
Zynq specific set up of the MMU.
Definition:
bspstartmmu.c:59
rtems.h
zynq_uart_context
Definition:
zynq-uart.h:49
zynq-uart.h
UART support.
