RTEMS
5.2
bsps
arm
xen
include
bsp.h
1
9
10
* SPDX-License-Identifier: BSD-2-Clause
11
12
* Copyright (C) 2019 DornerWorks
13
* Written by Jeff Kubascik <jeff.kubascik@dornerworks.com>
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef LIBBSP_ARM_XEN_BSP_H
38
#define LIBBSP_ARM_XEN_BSP_H
39
46
#include <bspopts.h>
47
48
#define BSP_FEATURE_IRQ_EXTENSION
49
50
#ifndef ASM
51
52
bsp/default-initial-extension.h
53
#include <bsp/start.h>
54
55
rtems.h
56
57
#ifdef __cplusplus
58
extern
"C"
59
#endif
/* __cplusplus */
60
61
#define BSP_ARM_GIC_CPUIF_BASE 0x03002000
62
#define BSP_ARM_GIC_CPUIF_LENGTH 0x1000
63
64
#define BSP_ARM_GIC_DIST_BASE 0x03001000
65
#define BSP_ARM_GIC_DIST_LENGTH 0x1000
66
67
#define BSP_ARM_A9MPCORE_SCU_BASE 0
68
69
#define BSP_ARM_A9MPCORE_GT_BASE 0
70
71
#define BSP_XEN_VPL011_BASE 0x22000000
72
#define BSP_XEN_VPL011_LENGTH 0x1000
73
74
void
arm_generic_timer_get_config(uint32_t *frequency, uint32_t *irq);
75
76
BSP_START_TEXT_SECTION
void
bsp_xen_setup_mmu_and_cache(
void
77
78
#ifdef __cplusplus
79
80
#endif
/* __cplusplus */
81
82
#endif
/* ASM */
83
86
#endif
/* LIBBSP_ARM_XEN_BSP_H */
DEFAULT_INITIAL_EXTENSION Support.
rtems.h
