RTEMS 5.2
timer.h
1
9/*
10 * Copyright (c) 2014 Taller Technologies.
11 *
12 * @author Boretto Martin (martin.boretto@tallertechnologies.com)
13 * @author Diaz Marcos (marcos.diaz@tallertechnologies.com)
14 * @author Lenarduzzi Federico (federico.lenarduzzi@tallertechnologies.com)
15 * @author Daniel Chicco (daniel.chicco@tallertechnologies.com)
16 *
17 * The license and distribution terms for this file may be
18 * found in the file LICENSE in this distribution or at
19 * http://www.rtems.org/license/LICENSE.
20 */
21
22#ifndef LIBBSP_ARM_LPC176X_TIMER_H
23#define LIBBSP_ARM_LPC176X_TIMER_H
24
25#include <bsp/timer-defs.h>
26
27#ifdef __cplusplus
28extern "C" {
29#endif /* __cplusplus */
30
38
50);
51
59
69 bool *is_started
70);
71
82 lpc176x_microseconds resolution
83);
84
97 lpc176x_match_port match_port,
99 uint32_t match_value
100);
101
111 lpc176x_timer_number tnumber,
112 lpc176x_capture_port capture_port,
114);
115
124 lpc176x_timer_number tnumber,
125 lpc176x_match_port match_port,
127);
128
137 lpc176x_timer_number tnumber,
138 lpc176x_capture_port capnumber
139);
140
148
156 lpc176x_timer_number tnumber,
157 uint32_t lpc176x_timer_value
158);
159
166
176
187 lpc176x_timer_number tnumber,
188 const lpc176x_isr_funct_vector *vector
189);
190
191#ifdef __cplusplus
192}
193#endif /* __cplusplus */
194
195#endif /* LIBBSP_ARM_LPC176X_TIMER_H */
rtems_status_code lpc176x_timer_match_config(lpc176x_timer_number tnumber, lpc176x_match_port match_port, lpc176x_match_function function, uint32_t match_value)
Configures the timer match.
Definition: timer.c:225
rtems_status_code lpc176x_timer_set_mode(lpc176x_timer_number tnumber, lpc176x_timer_mode mode)
Sets mode of the timer (timer, counter rising, counter falling or counter both edges)
Definition: timer.c:152
rtems_status_code lpc176x_timer_start(lpc176x_timer_number tnumber)
Starts the timer counter.
Definition: timer.c:170
void lpc176x_timer_isr(void *lpc176x_timer_number)
Timer generic isroutine.
Definition: timer.c:335
rtems_status_code lpc176x_timer_is_started(lpc176x_timer_number tnumber, bool *is_started)
true if timer is started.
Definition: timer.c:186
rtems_status_code lpc176x_timer_capture_config(lpc176x_timer_number tnumber, lpc176x_capture_port capture_port, lpc176x_capture_function function)
Configures the capture ports.
Definition: timer.c:250
uint32_t lpc176x_timer_get_timer_value(lpc176x_timer_number tnumber)
Gets the timer value.
Definition: timer.c:309
rtems_status_code lpc176x_timer_set_resolution(lpc176x_timer_number tnumber, lpc176x_microseconds resolution)
sets the resolution in microseconds of the timer
Definition: timer.c:205
rtems_status_code lpc176x_timer_set_timer_value(lpc176x_timer_number tnumber, uint32_t lpc176x_timer_value)
Sets the timer value.
Definition: timer.c:317
uint32_t lpc176x_timer_get_capvalue(lpc176x_timer_number tnumber, lpc176x_capture_port capnumber)
Gets the captured value.
Definition: timer.c:298
rtems_status_code lpc176x_timer_external_match_config(lpc176x_timer_number tnumber, lpc176x_match_port match_port, lpc176x_ext_match_function function)
Configures the external match ports.
Definition: timer.c:274
rtems_status_code lpc176x_timer_init_with_interrupt(lpc176x_timer_number tnumber, const lpc176x_isr_funct_vector *vector)
Initializes timer in timer mode and resets counter but without starting it, and without any capture o...
Definition: timer.c:383
rtems_status_code lpc176x_timer_reset(lpc176x_timer_number tnumber)
resets timer counter and stops it.
Definition: timer.c:136
rtems_status_code lpc176x_timer_init(lpc176x_timer_number tnumber)
Definition: timer.c:357
uint32_t lpc176x_microseconds
Microseconds representation.
Definition: common-types.h:37
rtems_status_code
Classic API Status.
Definition: status.h:43
API definitions of the for the timer of the lpc176x bsp.
The possible functions at match, for the external ports.
Definition: timer-defs.h:391
The timer devices in the board.
Definition: timer-defs.h:333
lpc176x_isr_funct const lpc176x_isr_funct_vector[LPC176X_ISR_FUNCTIONS_COUNT]
The vector of functions that attends each possible interrupt source for a timer.
Definition: timer-defs.h:411
lpc176x_match_port
Match ports of a timer.
Definition: timer-defs.h:305
The possible functions at match. This options could be used together.
Definition: timer-defs.h:364
The possible functions at capture. This options could be used together.
Definition: timer-defs.h:378
lpc176x_timer_mode
Timer modes of a timer.
Definition: timer-defs.h:318
Capture ports of a timer.
Definition: timer-defs.h:294
