RTEMS 5.2
io.h
1
9/*
10 * Copyright (c) 2014 Taller Technologies.
11 *
12 * @author Boretto Martin (martin.boretto@tallertechnologies.com)
13 * @author Diaz Marcos (marcos.diaz@tallertechnologies.com)
14 * @author Lenarduzzi Federico (federico.lenarduzzi@tallertechnologies.com)
15 * @author Daniel Chicco (daniel.chicco@tallertechnologies.com)
16 *
17 * The license and distribution terms for this file may be
18 * found in the file LICENSE in this distribution or at
19 * http://www.rtems.org/license/LICENSE.
20 */
21
22#ifndef LIBBSP_ARM_LPC176X_IO_H
23#define LIBBSP_ARM_LPC176X_IO_H
24
25#include <assert.h>
26#include <rtems.h>
27#include <bsp/io-defs.h>
28
29#ifdef __cplusplus
30extern "C" {
31#endif /* __cplusplus */
32
40 uint32_t pin,
42);
43
51 const uint32_t pin,
52 const lpc176x_pin_mode mode
53);
54
63 lpc176x_module module,
65);
66
74
83
84#ifdef __cplusplus
85}
86#endif /* __cplusplus */
87
88#endif /* LIBBSP_ARM_LPC176X_IO_H */
Information for the Assert Handler.
rtems_status_code lpc176x_module_enable(lpc176x_module module, lpc176x_module_clock clock)
Enables the module power and clock.
Definition: io.c:317
bool lpc176x_module_is_enabled(lpc176x_module module)
Checks if the current module is enabled or not.
Definition: io.c:332
void lpc176x_pin_select(uint32_t pin, lpc176x_pin_function function)
Sets pin to the selected function.
Definition: io.c:60
void lpc176x_pin_set_mode(const uint32_t pin, const lpc176x_pin_mode mode)
Sets pin to the selected mode.
Definition: io.c:74
rtems_status_code lpc176x_module_disable(lpc176x_module module)
Checks if the current module is turned off and disables a module.
Definition: io.c:325
lpc176x_module
lpc176x module representation.
Definition: common-types.h:44
Defines all the clock modules.
Definition: common-types.h:78
rtems_status_code
Classic API Status.
Definition: status.h:43
Input/output module definitions.
Defines the functions according to the pin.
Definition: io-defs.h:68
lpc176x_pin_mode
Defines the pin modes.
Definition: io-defs.h:81
