Global BSP definitions.
More...
#include <bspopts.h>
#include <bsp/default-initial-extension.h>
#define | BSP_FEATURE_IRQ_EXTENSION |
#define | BSP_HAS_FRAME_BUFFER 1 |
#define | BSP_MAIN_FREQ 3686400 /* 3.6864 MHz */ |
| What is the input clock freq in hertz.
#define | BSP_SLCK_FREQ 32768 /* 32.768 KHz */ |
#define | BSP_MAX_INT AT91RM9200_MAX_INT |
| What is the last interrupt.
#define | ST_PIMR_PIV 33 /* 33 ticks of the 32.768Khz clock ~= 1msec */ |
#define | outport_byte(port, val) *((unsigned char volatile*)(port)) = (val) |
#define | inport_byte(port, val) (val) = *((unsigned char volatile*)(port)) |
#define | outport_word(port, val) *((unsigned short volatile*)(port)) = (val) |
#define | inport_word(port, val) (val) = *((unsigned short volatile*)(port)) |
#define | BSP_NE2000_NETWORK_DRIVER_NAME "ne1" |
#define | BSP_NE2000_NETWORK_DRIVER_ATTACH rtems_ne_driver_attach |
#define | RTEMS_BSP_NETWORK_DRIVER_NAME BSP_NE2000_NETWORK_DRIVER_NAME |
#define | RTEMS_BSP_NETWORK_DRIVER_ATTACH BSP_NE2000_NETWORK_DRIVER_ATTACH |
console_tbl * | BSP_get_uart_from_minor (int minor) |
int | rtems_ne_driver_attach (struct rtems_bsdnet_ifconfig *, int) |
