RTEMS
5.2
bsps
arm
atsam
contrib
libraries
libboard
include
board_memories.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
37
#ifndef BOARD_MEMORIES_H
38
#define BOARD_MEMORIES_H
39
40
41
* Exported functions
42
43
44
#ifndef __rtems__
45
extern
void
BOARD_ConfigureSdram
void
46
#else
/* __rtems__ */
47
extern
void
void
) ATSAM_START_SRAM_SECTION;
48
#endif
/* __rtems__ */
49
extern
uint32_t BOARD_SdramValidation(uint32_t baseAddr, uint32_t
size
50
51
#endif
/* #ifndef BOARD_MEMORIES_H */
52
void BOARD_ConfigureSdram(void)
Configures the EBI for SDRAM (IS42S16100E-7B) access.
Definition:
board_memories.c:152
size
unsigned size
Definition:
tte.h:1
