RTEMS
5.2
bsps
powerpc
include
libcpu
bat.h
1
2
* bat.h
3
4
* This file contains declaration of C function to
5
* Instantiate 60x/7xx ppc Block Address Translation (BAT) registers.
6
* More detailed information can be found on motorola
7
* site and more precisely in the following book :
8
9
* MPC750
10
* Risc Microporcessor User's Manual
11
* Motorola REF : MPC750UM/AD 8/97
12
13
* Copyright (C) 1999 Eric Valette (valette@crf.canon.fr)
14
* Canon Centre Recherche France.
15
16
* The license and distribution terms for this file may be
17
* found in the file LICENSE in this distribution or at
18
* http://www.rtems.org/license/LICENSE.
19
20
21
#ifndef _LIBCPU_BAT_H
22
#define _LIBCPU_BAT_H
23
24
#include <libcpu/mmu.h>
25
#include <libcpu/pgtable.h>
26
27
#define IO_PAGE (_PAGE_NO_CACHE | _PAGE_GUARDED | _PAGE_RW)
28
29
#ifndef ASM
30
/* Take no risks -- the essential parts of this routine run with
31
* interrupts disabled!
32
33
* The routine does basic parameter checks:
34
* - Index must be 0..3 (0..7 on 7455, 7457).
35
* If an index > 3 is requested the 745x is
36
* programmed to enable the higher BATs.
37
* - Size must be a power of two and <= 1<<28
38
* (<=1<<31 on 7455, 7457. Also, on these processors
39
* the special value 0xffffffff is allowed which stands
40
* for 1<<32).
41
* If a size > 1<<28 is requested, the 745x is
42
* programmed to enable the larger block sizes.
43
* - Bat ranges must not overlap.
44
* - Physical & virtual addresses must be aligned
45
* to the size.
46
47
* RETURNS: zero on success, nonzero on failure.
48
49
extern
int
setdbat(
int
bat_index,
unsigned
long
virt,
unsigned
long
phys,
50
unsigned
int
size
int
flags);
51
52
/* Same as setdbat but sets IBAT */
53
extern
int
setibat(
int
bat_index,
unsigned
long
virt,
unsigned
long
phys,
54
unsigned
int
size
int
flags);
55
56
/* read DBAT # 'idx' into *pu / *pl. NULL pointers may be passed.
57
* If pu and pl are NULL, the bat contents are dumped to the console (printk).
58
59
* RETURNS: upper BAT contents or (-1) if index is invalid
60
61
extern
int
getdbat(
int
bat_index,
unsigned
long
*pu,
unsigned
long
*pl);
62
63
/* Same as getdbat but reads IBAT */
64
extern
int
getibat(
int
bat_index,
unsigned
long
*pu,
unsigned
long
*pl);
65
66
/* Do not use the asm-routines; they are obsolete; use setdbat() instead */
67
extern
void
asm_setdbat0(
unsigned
int
uperPart,
unsigned
int
lowerPart);
68
extern
void
asm_setdbat1(
unsigned
int
uperPart,
unsigned
int
lowerPart);
69
extern
void
asm_setdbat2(
unsigned
int
uperPart,
unsigned
int
lowerPart);
70
extern
void
asm_setdbat3(
unsigned
int
uperPart,
unsigned
int
lowerPart);
71
#else
72
73
/* Initialize all bats (upper and lower) to zero. This routine should *only*
74
* be called during early BSP initialization when no C-ABI is available
75
* yet.
76
* This routine clobbers r3 and r4.
77
* NOTE: on 7450 CPUs all 8 dbat/ibat units are cleared. On 601 CPUs only
78
* 4 ibats.
79
80
.globl CPU_clear_bats_early
81
.type CPU_clear_bats_early,@function
82
83
#endif
84
85
#endif
/* _LIBCPU_BAT_H */
size
unsigned size
Definition:
tte.h:1
