RTEMS 5.2
Macros | Functions
at91rm9200_pmc.h File Reference
AT91RM9200 Power Management and Clock definitions. More...
#include <bits.h>
#define PMC_SCER   0x00 /* System Clock Enable Register */
#define PMC_SCDR   0x04 /* System Clock Disable Register */
#define PMC_SCSR   0x08 /* System Clock Status Register */
#define PMC_PCER   0x10 /* Peripheral Clock Enable Register */
#define PMC_PCDR   0x14 /* Peripheral Clock Disable Register */
#define PMC_PCSR   0x18 /* Peripheral Clock Status Register */
#define PMC_MOR   0x20 /* Main Oscillator Register */
#define PMC_MCFR   0x24 /* Main Clock Frequency Register */
#define PMC_PLLAR   0x28 /* PLL A Register */
#define PMC_PLLBR   0x2C /* PLL B Register */
#define PMC_MCKR   0x30 /* Master Clock Register */
#define PMC_PCKR0   0x40 /* Programmable Clock Register 0 */
#define PMC_PCKR1   0x44 /* Programmable Clock Register 1 */
#define PMC_PCKR2   0x48 /* Programmable Clock Register 2 */
#define PMC_PCKR3   0x4C /* Programmable Clock Register 3 */
#define PMC_PCKR4   0x50 /* Programmable Clock Register 4 */
#define PMC_PCKR5   0x54 /* Programmable Clock Register 5 */
#define PMC_PCKR6   0x58 /* Programmable Clock Register 6 */
#define PMC_PCKR7   0x5C /* Programmable Clock Register 7 */
#define PMC_IER   0x60 /* Interrupt Enable Register */
#define PMC_IDR   0x64 /* Interrupt Disable Register */
#define PMC_SR   0x68 /* Status Register */
#define PMC_IMR   0x6C /* Interrupt Mask Register */
#define PMC_SCR_PCK7   BIT15
#define PMC_SCR_PCK6   BIT14
#define PMC_SCR_PCK5   BIT13
#define PMC_SCR_PCK4   BIT12
#define PMC_SCR_PCK3   BIT11
#define PMC_SCR_PCK2   BIT10
#define PMC_SCR_PCK1   BIT9
#define PMC_SCR_PCK0   BIT8
#define PMC_SCR_UHP   BIT4
#define PMC_SCR_MCKUDP   BIT2
#define PMC_SCR_UDP   BIT1
#define PMC_SCR_PCK   BIT0
#define PMC_PCR_PID_EMAC   BIT24 /* Ethernet Peripheral Clock */
#define PMC_PCR_PID_UHP   BIT23 /* USB Host Ports Peripheral Clock */
#define PMC_PCR_PID_TC5   BIT22 /* Timer/Counter 5 Peripheral Clock */
#define PMC_PCR_PID_TC4   BIT21 /* Timer/Counter 4 Peripheral Clock */
#define PMC_PCR_PID_TC3   BIT20 /* Timer/Counter 3 Peripheral Clock */
#define PMC_PCR_PID_TC2   BIT19 /* Timer/Counter 2 Peripheral Clock */
#define PMC_PCR_PID_TC1   BIT18 /* Timer/Counter 1 Peripheral Clock */
#define PMC_PCR_PID_TC0   BIT17 /* Timer/Counter 0 Peripheral Clock */
#define PMC_PCR_PID_SSC2   BIT16 /* Synchronous Serial 2 Peripheral Clock */
#define PMC_PCR_PID_SSC1   BIT15 /* Synchronous Serial 1 Peripheral Clock */
#define PMC_PCR_PID_SSC0   BIT14 /* Synchronous Serial 0 Peripheral Clock */
#define PMC_PCR_PID_SPI   BIT13 /* Serial Peripheral Interface Peripheral Clock */
#define PMC_PCR_PID_TWI   BIT12 /* Two-Wire Interface Peripheral Clock */
#define PMC_PCR_PID_UDP   BIT11 /* USB Device Port Peripheral Clock */
#define PMC_PCR_PID_MCI   BIT10 /* MMC/SD Card Peripheral Clock */
#define PMC_PCR_PID_US3   BIT9 /* USART 3 Peripheral Clock */
#define PMC_PCR_PID_US2   BIT8 /* USART 2 Peripheral Clock */
#define PMC_PCR_PID_US1   BIT7 /* USART 1 Peripheral Clock */
#define PMC_PCR_PID_US0   BIT6 /* USART 0 Peripheral Clock */
#define PMC_PCR_PID_PIOD   BIT5 /* Parallel I/O D Peripheral Clock */
#define PMC_PCR_PID_PIOC   BIT4 /* Parallel I/O C Peripheral Clock */
#define PMC_PCR_PID_PIOB   BIT3 /* Parallel I/O B Peripheral Clock */
#define PMC_PCR_PID_PIOA   BIT2 /* Parallel I/O A Peripheral Clock */
#define PMC_MOR_MOSCEN   BIT0
#define PMC_MCFR_MAINRDY   BIT16
#define PMC_PLLAR_MUST_SET   BIT29 /* This bit must be set according to the docs */
#define PMC_PLLAR_MUL(_x_)   ((_x_ & 0x7ff) << 16) /* Multiplier */
#define PMC_PLLAR_MUL_MASK   (0x7ff << 16) /* Multiplier mask */
#define PMC_PLLAR_OUT_80_160   (0 << 14) /* select when PLL frequency is 80-160 Mhz */
#define PMC_PLLAR_OUT_150_240   (2 << 14) /* select when PLL frequency is 150-240 Mhz */
#define PMC_PLLAR_DIV(_x_)   ((_x_ & 0xff) << 0) /* Divider */
#define PMC_PLLAR_DIV_MASK   (0xff) /* Divider mask */
#define PMC_PLLBR_USB_96M   BIT28 /* Set when PLL is 96Mhz to divide it by 2 for USB */
#define PMC_PLLBR_MUL(_x_)   ((_x_ & 0x7ff) << 16) /* Multiplier */
#define PMC_PLLBR_MUL_MASK   (0x7ff << 16) /* Multiplier mask */
#define PMC_PLLBR_OUT_80_160   (0 << 14) /* select when PLL frequency is 80-160 Mhz */
#define PMC_PLLBR_OUT_150_240   (2 << 14) /* select when PLL frequency is 150-240 Mhz */
#define PMC_PLLBR_DIV(_x_)   ((_x_ & 0xff) << 0) /* Divider */
#define PMC_PLLBR_DIV_MASK   (0xff) /* Divider mask */
#define PMC_MCKR_MDIV_MASK   (3 << 8) /* for masking out the MDIV field */
#define PMC_MCKR_MDIV_1   (0 << 8) /* MCK = Core/1 */
#define PMC_MCKR_MDIV_2   (1 << 8) /* MCK = Core/2 */
#define PMC_MCKR_MDIV_3   (2 << 8) /* MCK = Core/3 */
#define PMC_MCKR_MDIV_4   (3 << 8) /* MCK = Core/4 */
#define PMC_MCKR_PRES_MASK   (7 << 2) /* for masking out the PRES field */
#define PMC_MCKR_PRES_1   (0 << 2) /* Core = CSS/1 */
#define PMC_MCKR_PRES_2   (1 << 2) /* Core = CSS/2 */
#define PMC_MCKR_PRES_4   (2 << 2) /* Core = CSS/4 */
#define PMC_MCKR_PRES_8   (3 << 2) /* Core = CSS/8 */
#define PMC_MCKR_PRES_16   (4 << 2) /* Core = CSS/16 */
#define PMC_MCKR_PRES_32   (5 << 2) /* Core = CSS/32 */
#define PMC_MCKR_PRES_64   (6 << 2) /* Core = CSS/64 */
#define PMC_MCKR_CSS_MASK   (3 << 0) /* for masking out the CSS field */
#define PMC_MCKR_CSS_SLOW   (0 << 0) /* Core Source = Slow Clock */
#define PMC_MCKR_CSS_MAIN   (1 << 0) /* Core Source = Main Oscillator */
#define PMC_MCKR_CSS_PLLA   (2 << 0) /* Core Source = PLL A */
#define PMC_MCKR_CSS_PLLB   (3 << 0) /* Core Source = PLL B */
#define PMC_PCKR_PRES_1   (0 << 2) /* Peripheral Clock = CSS/1 */
#define PMC_PCKR_PRES_2   (1 << 2) /* Peripheral Clock = CSS/2 */
#define PMC_PCKR_PRES_4   (2 << 2) /* Peripheral Clock = CSS/4 */
#define PMC_PCKR_PRES_8   (3 << 2) /* Peripheral Clock = CSS/8 */
#define PMC_PCKR_PRES_16   (4 << 2) /* Peripheral Clock = CSS/16 */
#define PMC_PCKR_PRES_32   (5 << 2) /* Peripheral Clock = CSS/32 */
#define PMC_PCKR_PRES_64   (6 << 2) /* Peripheral Clock = CSS/64 */
#define PMC_PCKR_CSS_SLOW   (0 << 0) /* Peripheral Clock Source = Slow Clock */
#define PMC_PCKR_CSS_MAIN   (1 << 0) /* Peripheral Clock Source = Main Oscillator */
#define PMC_PCKR_CSS_PLLA   (2 << 0) /* Peripheral Clock Source = PLL A */
#define PMC_PCKR_CSS_PLLB   (3 << 0) /* Peripheral Clock Source = PLL B */
#define PMC_INT_PCK7_RDY   BIT15
#define PMC_INT_PCK6_RDY   BIT14
#define PMC_INT_PCK5_RDY   BIT13
#define PMC_INT_PCK4_RDY   BIT12
#define PMC_INT_PCK3_RDY   BIT11
#define PMC_INT_PCK2_RDY   BIT10
#define PMC_INT_PCK1_RDY   BIT9
#define PMC_INT_PCK0_RDY   BIT8
#define PMC_INT_MCK_RDY   BIT3
#define PMC_INT_LOCKB   BIT2
#define PMC_INT_LCKA   BIT1
#define PMC_INT_MOSCS   BIT0
int at91rm9200_get_mainclk (void)
int at91rm9200_get_slck (void)
int at91rm9200_get_mck (void)
