RTEMS 5.2
Data Structures | Macros
at91rm9200_dbgu.h File Reference
Atmel AT91RM9200_DBGU Register definitions. More...
#include "bits.h"
struct  at91rm9200_dbgu_regs_t
#define DBGU_CR   0x00 /* Control Register */
#define DBGU_MR   0x04 /* Mode Register */
#define DBGU_IER   0x08 /* Interrupt Enable Register */
#define DBGU_IDR   0x0C /* Interrupt Disable Register */
#define DBGU_IMR   0x10 /* Interrupt Mask Register */
#define DBGU_SR   0x14 /* Channel Status Register */
#define DBGU_RHR   0x18 /* Receiver Holding Register */
#define DBGU_THR   0x1C /* Transmitter Holding Register */
#define DBGU_BRGR   0x20 /* Baud Rate Generator Register */
#define DBGU_C1R   0x40 /* Chip ID1 Register */
#define DBGU_C2R   0x44 /* Chip ID2 Register */
#define DBGU_FNTR   0x48 /* Force NTRST Register */
#define DBGU_CR_RSTRX   BIT2 /* 1 = Reset and disable receiver */
#define DBGU_CR_RSTTX   BIT3 /* 1 = Reset and disable transmitter */
#define DBGU_CR_RXEN   BIT4 /* 1 = Receiver enable */
#define DBGU_CR_RXDIS   BIT5 /* 1 = Receiver disable */
#define DBGU_CR_TXEN   BIT6 /* 1 = Transmitter enable */
#define DBGU_CR_TXDIS   BIT7 /* 1 = Transmitter disable */
#define DBGU_CR_RSTSTA   BIT8 /* 1 = Reset PARE, FRAME and OVRE in DBGU_SR. */
#define DBGU_MR_PAR_EVEN   (0x0 << 9) /* Even Parity */
#define DBGU_MR_PAR_ODD   (0x1 << 9) /* Odd Parity */
#define DBGU_MR_PAR_SPACE   (0x2 << 9) /* Parity forced to 0 (Space) */
#define DBGU_MR_PAR_MARK   (0x3 << 9) /* Parity forced to 1 (Mark) */
#define DBGU_MR_PAR_NONE   (0x4 << 9) /* No Parity */
#define DBGU_MR_PAR_MDROP   (0x6 << 9) /* Multi-drop mode */
#define DBGU_MR_CHMODE_NORM   (0x0 << 14) /* Normal Mode */
#define DBGU_MR_CHMODE_AUTO   (0x1 << 14) /* Auto Echo: RXD drives TXD */
#define DBGU_MR_CHMODE_LOC   (0x2 << 14) /* Local Loopback: TXD drives RXD */
#define DBGU_MR_CHMODE_REM   (0x3 << 14) /* Remote Loopback: RXD pin connected to TXD pin. */
#define DBGU_INT_RXRDY   BIT0 /* RXRDY Interrupt */
#define DBGU_INT_TXRDY   BIT1 /* TXRDY Interrupt */
#define DBGU_INT_ENDRX   BIT3 /* End of Receive Transfer Interrupt */
#define DBGU_INT_ENDTX   BIT4 /* End of Transmit Interrupt */
#define DBGU_INT_OVRE   BIT5 /* Overrun Interrupt */
#define DBGU_INT_FRAME   BIT6 /* Framing Error Interrupt */
#define DBGU_INT_PARE   BIT7 /* Parity Error Interrupt */
#define DBGU_INT_TXEMPTY   BIT9 /* TXEMPTY Interrupt */
#define DBGU_INT_TXBUFE   BIT11 /* TXBUFE Interrupt */
#define DBGU_INT_RXBUFF   BIT12 /* RXBUFF Interrupt */
#define DBGU_INT_COMM_TX   BIT30 /* COMM_TX Interrupt */
#define DBGU_INT_COMM_RX   BIT31 /* COMM_RX Interrupt */
#define DBGU_INT_ALL   0xC0001AFB /* all assigned bits */
#define DBGU_FNTR_NTRST   BIT0 /* 1 = Force NTRST low in JTAG */
