RTEMS 5.2
armv7m.h
1
7/*
8 * Copyright (c) 2011-2014 Sebastian Huber. All rights reserved.
9 *
10 * embedded brains GmbH
11 * Obere Lagerstr. 30
12 * 82178 Puchheim
13 * Germany
14 * <rtems@embedded-brains.de>
15 *
16 * The license and distribution terms for this file may be
17 * found in the file LICENSE in this distribution or at
18 * http://www.rtems.org/license/LICENSE.
19 */
20
21#ifndef RTEMS_SCORE_ARMV7M_H
22#define RTEMS_SCORE_ARMV7M_H
23
24#include <rtems/score/cpu.h>
25
26#ifdef __cplusplus
27extern "C" {
28#endif /* __cplusplus */
29
30#ifdef ARM_MULTILIB_ARCH_V7M
31
32/* Coprocessor Access Control Register, CPACR */
33#define ARMV7M_CPACR 0xe000ed88
34
35#ifndef ASM
36
37typedef struct {
38 uint32_t reserved_0;
39 uint32_t ictr;
40 uint32_t actlr;
41 uint32_t reserved_1;
42} ARMV7M_ICTAC;
43
44typedef void (*ARMV7M_Exception_handler)(void);
45
46typedef struct {
47 uint32_t register_r0;
48 uint32_t register_r1;
49 uint32_t register_r2;
50 uint32_t register_r3;
51 uint32_t register_r12;
52 void *register_lr;
53 void *register_pc;
54 uint32_t register_xpsr;
55#ifdef ARM_MULTILIB_VFP
56 uint32_t register_s0;
57 uint32_t register_s1;
58 uint32_t register_s2;
59 uint32_t register_s3;
60 uint32_t register_s4;
61 uint32_t register_s5;
62 uint32_t register_s6;
63 uint32_t register_s7;
64 uint32_t register_s8;
65 uint32_t register_s9;
66 uint32_t register_s10;
67 uint32_t register_s11;
68 uint32_t register_s12;
69 uint32_t register_s13;
70 uint32_t register_s14;
71 uint32_t register_s15;
72 uint32_t register_fpscr;
73 uint32_t reserved;
74#endif
75} ARMV7M_Exception_frame;
76
77typedef struct {
78 uint32_t comp;
79 uint32_t mask;
80 uint32_t function;
81 uint32_t reserved;
82} ARMV7M_DWT_comparator;
83
84typedef struct {
85#define ARMV7M_DWT_CTRL_NOCYCCNT (1U << 25)
86#define ARMV7M_DWT_CTRL_CYCCNTENA (1U << 0)
87 uint32_t ctrl;
88 uint32_t cyccnt;
89 uint32_t cpicnt;
90 uint32_t exccnt;
91 uint32_t sleepcnt;
92 uint32_t lsucnt;
93 uint32_t foldcnt;
94 uint32_t pcsr;
95 ARMV7M_DWT_comparator comparator[249];
96#define ARMV7M_DWT_LAR_UNLOCK_MAGIC 0xc5acce55U
97 uint32_t lar;
98 uint32_t lsr;
99} ARMV7M_DWT;
100
101typedef struct {
102 uint32_t cpuid;
103
104#define ARMV7M_SCB_ICSR_NMIPENDSET (1U << 31)
105#define ARMV7M_SCB_ICSR_PENDSVSET (1U << 28)
106#define ARMV7M_SCB_ICSR_PENDSVCLR (1U << 27)
107#define ARMV7M_SCB_ICSR_PENDSTSET (1U << 26)
108#define ARMV7M_SCB_ICSR_PENDSTCLR (1U << 25)
109#define ARMV7M_SCB_ICSR_ISRPREEMPT (1U << 23)
110#define ARMV7M_SCB_ICSR_ISRPENDING (1U << 22)
111#define ARMV7M_SCB_ICSR_VECTPENDING_GET(reg) (((reg) >> 12) & 0x1ffU)
112#define ARMV7M_SCB_ICSR_RETTOBASE (1U << 11)
113#define ARMV7M_SCB_ICSR_VECTACTIVE_GET(reg) ((reg) & 0x1ffU)
114 uint32_t icsr;
115
116 ARMV7M_Exception_handler *vtor;
117
118#define ARMV7M_SCB_AIRCR_VECTKEY (0x05fa << 16)
119#define ARMV7M_SCB_AIRCR_ENDIANESS (1U << 15)
120#define ARMV7M_SCB_AIRCR_PRIGROUP_SHIFT 8
121#define ARMV7M_SCB_AIRCR_PRIGROUP_MASK \
122 ((0x7U) << ARMV7M_SCB_AIRCR_PRIGROUP_SHIFT)
123#define ARMV7M_SCB_AIRCR_PRIGROUP(val) \
124 (((val) << ARMV7M_SCB_AIRCR_PRIGROUP_SHIFT) & ARMV7M_SCB_AIRCR_PRIGROUP_MASK)
125#define ARMV7M_SCB_AIRCR_PRIGROUP_GET(reg) \
126 (((val) & ARMV7M_SCB_AIRCR_PRIGROUP_MASK) >> ARMV7M_SCB_AIRCR_PRIGROUP_SHIFT)
127#define ARMV7M_SCB_AIRCR_PRIGROUP_SET(reg, val) \
128 (((reg) & ~ARMV7M_SCB_AIRCR_PRIGROUP_MASK) | ARMV7M_SCB_AIRCR_PRIGROUP(val))
129#define ARMV7M_SCB_AIRCR_SYSRESETREQ (1U << 2)
130#define ARMV7M_SCB_AIRCR_VECTCLRACTIVE (1U << 1)
131#define ARMV7M_SCB_AIRCR_VECTRESET (1U << 0)
132 uint32_t aircr;
133
134 uint32_t scr;
135 uint32_t ccr;
136 uint8_t shpr [12];
137
138#define ARMV7M_SCB_SHCSR_USGFAULTENA (1U << 18)
139#define ARMV7M_SCB_SHCSR_BUSFAULTENA (1U << 17)
140#define ARMV7M_SCB_SHCSR_MEMFAULTENA (1U << 16)
141 uint32_t shcsr;
142
143 uint32_t cfsr;
144 uint32_t hfsr;
145 uint32_t dfsr;
146 uint32_t mmfar;
147 uint32_t bfar;
148 uint32_t afsr;
149 uint32_t reserved_e000ed40[18];
150 uint32_t cpacr;
151 uint32_t reserved_e000ed8c[106];
152 uint32_t fpccr;
153 uint32_t fpcar;
154 uint32_t fpdscr;
155 uint32_t mvfr0;
156 uint32_t mvfr1;
157} ARMV7M_SCB;
158
159typedef struct {
160#define ARMV7M_SYSTICK_CSR_COUNTFLAG (1U << 16)
161#define ARMV7M_SYSTICK_CSR_CLKSOURCE (1U << 2)
162#define ARMV7M_SYSTICK_CSR_TICKINT (1U << 1)
163#define ARMV7M_SYSTICK_CSR_ENABLE (1U << 0)
164 uint32_t csr;
165
166 uint32_t rvr;
167 uint32_t cvr;
168
169#define ARMV7M_SYSTICK_CALIB_NOREF (1U << 31)
170#define ARMV7M_SYSTICK_CALIB_SKEW (1U << 30)
171#define ARMV7M_SYSTICK_CALIB_TENMS_GET(reg) ((reg) & 0xffffffU)
172 uint32_t calib;
173} ARMV7M_Systick;
174
175typedef struct {
176 uint32_t iser [8];
177 uint32_t reserved_0 [24];
178 uint32_t icer [8];
179 uint32_t reserved_1 [24];
180 uint32_t ispr [8];
181 uint32_t reserved_2 [24];
182 uint32_t icpr [8];
183 uint32_t reserved_3 [24];
184 uint32_t iabr [8];
185 uint32_t reserved_4 [56];
186 uint8_t ipr [240];
187 uint32_t reserved_5 [644];
188 uint32_t stir;
189} ARMV7M_NVIC;
190
191typedef struct {
192#define ARMV7M_MPU_TYPE_IREGION_GET(reg) (((reg) >> 16) & 0xffU)
193#define ARMV7M_MPU_TYPE_DREGION_GET(reg) (((reg) >> 8) & 0xffU)
194#define ARMV7M_MPU_TYPE_SEPARATE (1U << 0)
195 uint32_t type;
196
197#define ARMV7M_MPU_CTRL_PRIVDEFENA (1U << 2)
198#define ARMV7M_MPU_CTRL_HFNMIENA (1U << 1)
199#define ARMV7M_MPU_CTRL_ENABLE (1U << 0)
200 uint32_t ctrl;
201
202 uint32_t rnr;
203
204#define ARMV7M_MPU_RBAR_ADDR_SHIFT 5
205#define ARMV7M_MPU_RBAR_ADDR_MASK \
206 ((0x7ffffffU) << ARMV7M_MPU_RBAR_ADDR_SHIFT)
207#define ARMV7M_MPU_RBAR_ADDR(val) \
208 (((val) << ARMV7M_MPU_RBAR_ADDR_SHIFT) & ARMV7M_MPU_RBAR_ADDR_MASK)
209#define ARMV7M_MPU_RBAR_ADDR_GET(reg) \
210 (((val) & ARMV7M_MPU_RBAR_ADDR_MASK) >> ARMV7M_MPU_RBAR_ADDR_SHIFT)
211#define ARMV7M_MPU_RBAR_ADDR_SET(reg, val) \
212 (((reg) & ~ARMV7M_MPU_RBAR_ADDR_MASK) | ARMV7M_MPU_RBAR_ADDR(val))
213#define ARMV7M_MPU_RBAR_VALID (1U << 4)
214#define ARMV7M_MPU_RBAR_REGION_SHIFT 0
215#define ARMV7M_MPU_RBAR_REGION_MASK \
216 ((0xfU) << ARMV7M_MPU_RBAR_REGION_SHIFT)
217#define ARMV7M_MPU_RBAR_REGION(val) \
218 (((val) << ARMV7M_MPU_RBAR_REGION_SHIFT) & ARMV7M_MPU_RBAR_REGION_MASK)
219#define ARMV7M_MPU_RBAR_REGION_GET(reg) \
220 (((val) & ARMV7M_MPU_RBAR_REGION_MASK) >> ARMV7M_MPU_RBAR_REGION_SHIFT)
221#define ARMV7M_MPU_RBAR_REGION_SET(reg, val) \
222 (((reg) & ~ARMV7M_MPU_RBAR_REGION_MASK) | ARMV7M_MPU_RBAR_REGION(val))
223 uint32_t rbar;
224
225#define ARMV7M_MPU_RASR_XN (1U << 28)
226#define ARMV7M_MPU_RASR_AP_SHIFT 24
227#define ARMV7M_MPU_RASR_AP_MASK \
228 ((0x7U) << ARMV7M_MPU_RASR_AP_SHIFT)
229#define ARMV7M_MPU_RASR_AP(val) \
230 (((val) << ARMV7M_MPU_RASR_AP_SHIFT) & ARMV7M_MPU_RASR_AP_MASK)
231#define ARMV7M_MPU_RASR_AP_GET(reg) \
232 (((val) & ARMV7M_MPU_RASR_AP_MASK) >> ARMV7M_MPU_RASR_AP_SHIFT)
233#define ARMV7M_MPU_RASR_AP_SET(reg, val) \
234 (((reg) & ~ARMV7M_MPU_RASR_AP_MASK) | ARMV7M_MPU_RASR_AP(val))
235#define ARMV7M_MPU_RASR_TEX_SHIFT 19
236#define ARMV7M_MPU_RASR_TEX_MASK \
237 ((0x7U) << ARMV7M_MPU_RASR_TEX_SHIFT)
238#define ARMV7M_MPU_RASR_TEX(val) \
239 (((val) << ARMV7M_MPU_RASR_TEX_SHIFT) & ARMV7M_MPU_RASR_TEX_MASK)
240#define ARMV7M_MPU_RASR_TEX_GET(reg) \
241 (((val) & ARMV7M_MPU_RASR_TEX_MASK) >> ARMV7M_MPU_RASR_TEX_SHIFT)
242#define ARMV7M_MPU_RASR_TEX_SET(reg, val) \
243 (((reg) & ~ARMV7M_MPU_RASR_TEX_MASK) | ARMV7M_MPU_RASR_TEX(val))
244#define ARMV7M_MPU_RASR_S (1U << 18)
245#define ARMV7M_MPU_RASR_C (1U << 17)
246#define ARMV7M_MPU_RASR_B (1U << 16)
247#define ARMV7M_MPU_RASR_SRD_SHIFT 8
248#define ARMV7M_MPU_RASR_SRD_MASK \
249 ((0xffU) << ARMV7M_MPU_RASR_SRD_SHIFT)
250#define ARMV7M_MPU_RASR_SRD(val) \
251 (((val) << ARMV7M_MPU_RASR_SRD_SHIFT) & ARMV7M_MPU_RASR_SRD_MASK)
252#define ARMV7M_MPU_RASR_SRD_GET(reg) \
253 (((val) & ARMV7M_MPU_RASR_SRD_MASK) >> ARMV7M_MPU_RASR_SRD_SHIFT)
254#define ARMV7M_MPU_RASR_SRD_SET(reg, val) \
255 (((reg) & ~ARMV7M_MPU_RASR_SRD_MASK) | ARMV7M_MPU_RASR_SRD(val))
256#define ARMV7M_MPU_RASR_SIZE_SHIFT 1
257#define ARMV7M_MPU_RASR_SIZE_MASK \
258 ((0x1fU) << ARMV7M_MPU_RASR_SIZE_SHIFT)
259#define ARMV7M_MPU_RASR_SIZE(val) \
260 (((val) << ARMV7M_MPU_RASR_SIZE_SHIFT) & ARMV7M_MPU_RASR_SIZE_MASK)
261#define ARMV7M_MPU_RASR_SIZE_GET(reg) \
262 (((val) & ARMV7M_MPU_RASR_SIZE_MASK) >> ARMV7M_MPU_RASR_SIZE_SHIFT)
263#define ARMV7M_MPU_RASR_SIZE_SET(reg, val) \
264 (((reg) & ~ARMV7M_MPU_RASR_SIZE_MASK) | ARMV7M_MPU_RASR_SIZE(val))
265#define ARMV7M_MPU_RASR_ENABLE (1U << 0)
266 uint32_t rasr;
267
268 uint32_t rbar_a1;
269 uint32_t rasr_a1;
270 uint32_t rbar_a2;
271 uint32_t rasr_a2;
272 uint32_t rbar_a3;
273 uint32_t rasr_a3;
274} ARMV7M_MPU;
275
276typedef enum {
277 ARMV7M_MPU_AP_PRIV_NO_USER_NO,
278 ARMV7M_MPU_AP_PRIV_RW_USER_NO,
279 ARMV7M_MPU_AP_PRIV_RW_USER_RO,
280 ARMV7M_MPU_AP_PRIV_RW_USER_RW,
281 ARMV7M_MPU_AP_PRIV_RO_USER_NO = 0x5,
282 ARMV7M_MPU_AP_PRIV_RO_USER_RO,
283} ARMV7M_MPU_Access_permissions;
284
285typedef enum {
286 ARMV7M_MPU_ATTR_R = ARMV7M_MPU_RASR_AP(ARMV7M_MPU_AP_PRIV_RO_USER_NO)
287 | ARMV7M_MPU_RASR_C | ARMV7M_MPU_RASR_XN,
288 ARMV7M_MPU_ATTR_RW = ARMV7M_MPU_RASR_AP(ARMV7M_MPU_AP_PRIV_RW_USER_NO)
289 | ARMV7M_MPU_RASR_C | ARMV7M_MPU_RASR_XN | ARMV7M_MPU_RASR_B,
290 ARMV7M_MPU_ATTR_RWX = ARMV7M_MPU_RASR_AP(ARMV7M_MPU_AP_PRIV_RW_USER_NO)
291 | ARMV7M_MPU_RASR_C | ARMV7M_MPU_RASR_B,
292 ARMV7M_MPU_ATTR_X = ARMV7M_MPU_RASR_AP(ARMV7M_MPU_AP_PRIV_NO_USER_NO)
293 | ARMV7M_MPU_RASR_C,
294 ARMV7M_MPU_ATTR_RX = ARMV7M_MPU_RASR_AP(ARMV7M_MPU_AP_PRIV_RO_USER_NO)
295 | ARMV7M_MPU_RASR_C,
296 ARMV7M_MPU_ATTR_IO = ARMV7M_MPU_RASR_AP(ARMV7M_MPU_AP_PRIV_RW_USER_NO)
297 | ARMV7M_MPU_RASR_XN,
298} ARMV7M_MPU_Attributes;
299
300typedef enum {
301 ARMV7M_MPU_SIZE_32_B = 0x4,
302 ARMV7M_MPU_SIZE_64_B,
303 ARMV7M_MPU_SIZE_128_B,
304 ARMV7M_MPU_SIZE_256_B,
305 ARMV7M_MPU_SIZE_512_B,
306 ARMV7M_MPU_SIZE_1_KB,
307 ARMV7M_MPU_SIZE_2_KB,
308 ARMV7M_MPU_SIZE_4_KB,
309 ARMV7M_MPU_SIZE_8_KB,
310 ARMV7M_MPU_SIZE_16_KB,
311 ARMV7M_MPU_SIZE_32_KB,
312 ARMV7M_MPU_SIZE_64_KB,
313 ARMV7M_MPU_SIZE_128_KB,
314 ARMV7M_MPU_SIZE_256_KB,
315 ARMV7M_MPU_SIZE_512_KB,
316 ARMV7M_MPU_SIZE_1_MB,
317 ARMV7M_MPU_SIZE_2_MB,
318 ARMV7M_MPU_SIZE_4_MB,
319 ARMV7M_MPU_SIZE_8_MB,
320 ARMV7M_MPU_SIZE_16_MB,
321 ARMV7M_MPU_SIZE_32_MB,
322 ARMV7M_MPU_SIZE_64_MB,
323 ARMV7M_MPU_SIZE_128_MB,
324 ARMV7M_MPU_SIZE_256_MB,
325 ARMV7M_MPU_SIZE_512_MB,
326 ARMV7M_MPU_SIZE_1_GB,
327 ARMV7M_MPU_SIZE_2_GB,
328 ARMV7M_MPU_SIZE_4_GB
329} ARMV7M_MPU_Size;
330
331typedef struct {
332 uint32_t rbar;
333 uint32_t rasr;
334} ARMV7M_MPU_Region;
335
336#define ARMV7M_MPU_REGION_INITIALIZER(idx, addr, size, attr) \
337 { \
338 ((addr) & ARMV7M_MPU_RBAR_ADDR_MASK) \
339 | ARMV7M_MPU_RBAR_VALID \
340 | ARMV7M_MPU_RBAR_REGION(idx), \
341 ARMV7M_MPU_RASR_SIZE(size) | (attr) | ARMV7M_MPU_RASR_ENABLE \
342 }
343
344#define ARMV7M_MPU_REGION_DISABLED_INITIALIZER(idx) \
345 { \
346 ARMV7M_MPU_RBAR_VALID | ARMV7M_MPU_RBAR_REGION(idx), \
347 0 \
348 }
349
350typedef struct {
351 uint32_t dhcsr;
352 uint32_t dcrsr;
353 uint32_t dcrdr;
354#define ARMV7M_DEBUG_DEMCR_VC_CORERESET (1U << 0)
355#define ARMV7M_DEBUG_DEMCR_VC_MMERR (1U << 4)
356#define ARMV7M_DEBUG_DEMCR_VC_NOCPERR (1U << 5)
357#define ARMV7M_DEBUG_DEMCR_VC_CHKERR (1U << 6)
358#define ARMV7M_DEBUG_DEMCR_VC_STATERR (1U << 7)
359#define ARMV7M_DEBUG_DEMCR_VC_BUSERR (1U << 8)
360#define ARMV7M_DEBUG_DEMCR_VC_INTERR (1U << 9)
361#define ARMV7M_DEBUG_DEMCR_VC_HARDERR (1U << 10)
362#define ARMV7M_DEBUG_DEMCR_MON_EN (1U << 16)
363#define ARMV7M_DEBUG_DEMCR_MON_PEND (1U << 17)
364#define ARMV7M_DEBUG_DEMCR_MON_STEP (1U << 18)
365#define ARMV7M_DEBUG_DEMCR_MON_REQ (1U << 19)
366#define ARMV7M_DEBUG_DEMCR_TRCENA (1U << 24)
367 uint32_t demcr;
368} ARMV7M_DEBUG;
369
370#define ARMV7M_DWT_BASE 0xe0001000
371#define ARMV7M_SCS_BASE 0xe000e000
372#define ARMV7M_ICTAC_BASE (ARMV7M_SCS_BASE + 0x0)
373#define ARMV7M_SYSTICK_BASE (ARMV7M_SCS_BASE + 0x10)
374#define ARMV7M_NVIC_BASE (ARMV7M_SCS_BASE + 0x100)
375#define ARMV7M_SCB_BASE (ARMV7M_SCS_BASE + 0xd00)
376#define ARMV7M_MPU_BASE (ARMV7M_SCS_BASE + 0xd90)
377#define ARMV7M_DEBUG_BASE (ARMV7M_SCS_BASE + 0xdf0)
378
379#define _ARMV7M_DWT \
380 ((volatile ARMV7M_DWT *) ARMV7M_DWT_BASE)
381#define _ARMV7M_ICTAC \
382 ((volatile ARMV7M_ICTAC *) ARMV7M_ICTAC_BASE)
383#define _ARMV7M_SCB \
384 ((volatile ARMV7M_SCB *) ARMV7M_SCB_BASE)
385#define _ARMV7M_Systick \
386 ((volatile ARMV7M_Systick *) ARMV7M_SYSTICK_BASE)
387#define _ARMV7M_NVIC \
388 ((volatile ARMV7M_NVIC *) ARMV7M_NVIC_BASE)
389#define _ARMV7M_MPU \
390 ((volatile ARMV7M_MPU *) ARMV7M_MPU_BASE)
391#define _ARMV7M_DEBUG \
392 ((volatile ARMV7M_DEBUG *) ARMV7M_DEBUG_BASE)
393
394#define ARMV7M_VECTOR_MSP 0
395#define ARMV7M_VECTOR_RESET 1
396#define ARMV7M_VECTOR_NMI 2
397#define ARMV7M_VECTOR_HARD_FAULT 3
398#define ARMV7M_VECTOR_MEM_MANAGE 4
399#define ARMV7M_VECTOR_BUS_FAULT 5
400#define ARMV7M_VECTOR_USAGE_FAULT 6
401#define ARMV7M_VECTOR_SVC 11
402#define ARMV7M_VECTOR_DEBUG_MONITOR 12
403#define ARMV7M_VECTOR_PENDSV 14
404#define ARMV7M_VECTOR_SYSTICK 15
405#define ARMV7M_VECTOR_IRQ(n) ((n) + 16)
406#define ARMV7M_IRQ_OF_VECTOR(n) ((n) - 16)
407
408#define ARMV7M_EXCEPTION_PRIORITY_LOWEST 255
409
410static inline bool _ARMV7M_Is_vector_an_irq( int vector )
411{
412 /* External (i.e. non-system) IRQs start after the SysTick vector. */
413 return vector > ARMV7M_VECTOR_SYSTICK;
414}
415
416static inline uint32_t _ARMV7M_Get_basepri(void)
417{
418 uint32_t val;
419 __asm__ volatile ("mrs %[val], basepri\n" : [val] "=&r" (val));
420 return val;
421}
422
423static inline void _ARMV7M_Set_basepri(uint32_t val)
424{
425 __asm__ volatile ("msr basepri, %[val]\n" : : [val] "r" (val));
426}
427
428static inline uint32_t _ARMV7M_Get_primask(void)
429{
430 uint32_t val;
431 __asm__ volatile ("mrs %[val], primask\n" : [val] "=&r" (val));
432 return val;
433}
434
435static inline void _ARMV7M_Set_primask(uint32_t val)
436{
437 __asm__ volatile ("msr primask, %[val]\n" : : [val] "r" (val));
438}
439
440static inline uint32_t _ARMV7M_Get_faultmask(void)
441{
442 uint32_t val;
443 __asm__ volatile ("mrs %[val], faultmask\n" : [val] "=&r" (val));
444 return val;
445}
446
447static inline void _ARMV7M_Set_faultmask(uint32_t val)
448{
449 __asm__ volatile ("msr faultmask, %[val]\n" : : [val] "r" (val));
450}
451
452static inline uint32_t _ARMV7M_Get_control(void)
453{
454 uint32_t val;
455 __asm__ volatile ("mrs %[val], control\n" : [val] "=&r" (val));
456 return val;
457}
458
459static inline void _ARMV7M_Set_control(uint32_t val)
460{
461 __asm__ volatile ("msr control, %[val]\n" : : [val] "r" (val));
462}
463
464static inline uint32_t _ARMV7M_Get_MSP(void)
465{
466 uint32_t val;
467 __asm__ volatile ("mrs %[val], msp\n" : [val] "=&r" (val));
468 return val;
469}
470
471static inline void _ARMV7M_Set_MSP(uint32_t val)
472{
473 __asm__ volatile ("msr msp, %[val]\n" : : [val] "r" (val));
474}
475
476static inline uint32_t _ARMV7M_Get_PSP(void)
477{
478 uint32_t val;
479 __asm__ volatile ("mrs %[val], psp\n" : [val] "=&r" (val));
480 return val;
481}
482
483static inline void _ARMV7M_Set_PSP(uint32_t val)
484{
485 __asm__ volatile ("msr psp, %[val]\n" : : [val] "r" (val));
486}
487
488static inline uint32_t _ARMV7M_Get_XPSR(void)
489{
490 uint32_t val;
491 __asm__ volatile ("mrs %[val], xpsr\n" : [val] "=&r" (val));
492 return val;
493}
494
495static inline bool _ARMV7M_NVIC_Is_enabled( int irq )
496{
497 int index = irq >> 5;
498 uint32_t bit = 1U << (irq & 0x1f);
499
500 return (_ARMV7M_NVIC->iser [index] & bit) != 0;
501}
502
503static inline void _ARMV7M_NVIC_Set_enable( int irq )
504{
505 int index = irq >> 5;
506 uint32_t bit = 1U << (irq & 0x1f);
507
508 _ARMV7M_NVIC->iser [index] = bit;
509}
510
511static inline void _ARMV7M_NVIC_Clear_enable( int irq )
512{
513 int index = irq >> 5;
514 uint32_t bit = 1U << (irq & 0x1f);
515
516 _ARMV7M_NVIC->icer [index] = bit;
517}
518
519static inline bool _ARMV7M_NVIC_Is_pending( int irq )
520{
521 int index = irq >> 5;
522 uint32_t bit = 1U << (irq & 0x1f);
523
524 return (_ARMV7M_NVIC->ispr [index] & bit) != 0;
525}
526
527static inline void _ARMV7M_NVIC_Set_pending( int irq )
528{
529 int index = irq >> 5;
530 uint32_t bit = 1U << (irq & 0x1f);
531
532 _ARMV7M_NVIC->ispr [index] = bit;
533}
534
535static inline void _ARMV7M_NVIC_Clear_pending( int irq )
536{
537 int index = irq >> 5;
538 uint32_t bit = 1U << (irq & 0x1f);
539
540 _ARMV7M_NVIC->icpr [index] = bit;
541}
542
543static inline bool _ARMV7M_NVIC_Is_active( int irq )
544{
545 int index = irq >> 5;
546 uint32_t bit = 1U << (irq & 0x1f);
547
548 return (_ARMV7M_NVIC->iabr [index] & bit) != 0;
549}
550
551static inline void _ARMV7M_NVIC_Set_priority( int irq, int priority )
552{
553 _ARMV7M_NVIC->ipr [irq] = (uint8_t) priority;
554}
555
556static inline int _ARMV7M_NVIC_Get_priority( int irq )
557{
558 return _ARMV7M_NVIC->ipr [irq];
559}
560
561static inline bool _ARMV7M_DWT_Enable_CYCCNT( void )
562{
563 uint32_t demcr;
564 uint32_t dwt_ctrl;
565
566 demcr = _ARMV7M_DEBUG->demcr;
567 _ARMV7M_DEBUG->demcr = demcr | ARMV7M_DEBUG_DEMCR_TRCENA;
568 _ARM_Data_synchronization_barrier();
569
570 dwt_ctrl = _ARMV7M_DWT->ctrl;
571 if ((dwt_ctrl & ARMV7M_DWT_CTRL_NOCYCCNT) == 0) {
572 _ARMV7M_DWT->lar = ARMV7M_DWT_LAR_UNLOCK_MAGIC;
573 _ARM_Data_synchronization_barrier();
574 _ARMV7M_DWT->ctrl = dwt_ctrl | ARMV7M_DWT_CTRL_CYCCNTENA;
575 return true;
576 } else {
577 _ARMV7M_DEBUG->demcr = demcr;
578 return false;
579 }
580}
581
582int _ARMV7M_Get_exception_priority( int vector );
583
584void _ARMV7M_Set_exception_priority( int vector, int priority );
585
586ARMV7M_Exception_handler _ARMV7M_Get_exception_handler( int index );
587
588void _ARMV7M_Set_exception_handler(
589 int index,
590 ARMV7M_Exception_handler handler
591);
592
596void _ARMV7M_Set_exception_priority_and_handler(
597 int index,
598 int priority,
599 ARMV7M_Exception_handler handler
600);
601
602void _ARMV7M_Exception_default( void );
603
604void _ARMV7M_Interrupt_service_enter( void );
605
606void _ARMV7M_Interrupt_service_leave( void );
607
608void _ARMV7M_Pendable_service_call( void );
609
610void _ARMV7M_Supervisor_call( void );
611
612void _ARMV7M_Clock_handler( void );
613
614#endif /* ASM */
615
616#endif /* ARM_MULTILIB_ARCH_V7M */
617
618#ifdef __cplusplus
619}
620#endif /* __cplusplus */
621
622#endif /* RTEMS_SCORE_ARMV7M_H */
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
