RTEMS 5.2
uart.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef UART_H
31#define UART_H
32
33
34//------------------------------------------------------------------------------
35// Global functions
36//------------------------------------------------------------------------------
37
38void UART_Configure(Uart *uart, uint32_t mode, uint32_t baudrate,
39 uint32_t masterClock);
40
41void UART_SetTransmitterEnabled(Uart *uart, uint8_t enabled);
42
43void UART_SetReceiverEnabled(Uart *uart, uint8_t enabled);
44
45void UART_PutChar(Uart *uart, uint8_t c);
46
47uint32_t UART_IsRxReady(Uart *uart);
48
49uint8_t UART_GetChar(Uart *uart);
50
51uint32_t UART_GetStatus(Uart *uart);
52
53void UART_EnableIt(Uart *uart, uint32_t mode);
54
55void UART_DisableIt(Uart *uart, uint32_t mode);
56
57uint32_t UART_GetItMask(Uart *uart);
58
59void UART_SendBuffer(Uart *uart, uint8_t *pBuffer, uint32_t BuffLen);
60
61void UART_ReceiveBuffer(Uart *uart, uint8_t *pBuffer, uint32_t BuffLen);
62
63void UART_CompareConfig(Uart *uart, uint8_t Val1, uint8_t Val2);
64
65uint32_t UART_IsTxReady(Uart *uart);
66
67#endif //#ifndef UART_H
68
Return 1 if a character can be read in UART.
Definition: uart.c:113
Disable interrupt.
Definition: uart.c:194
Return interrupt mask.
Definition: uart.c:203
Sends one packet of data through the specified UART peripheral. This function operates synchronously,...
Definition: uart.c:158
Enables or disables the transmitter of an UART peripheral.
Definition: uart.c:86
Reads and returns a character from the UART.
Definition: uart.c:125
Return 1 if a character can be send to UART.
Definition: uart.c:136
Enable interrupt.
Definition: uart.c:184
Enables or disables the receiver of an UART peripheral.
Definition: uart.c:101
void UART_Configure(Uart *uart, uint32_t mode, uint32_t baudrate, uint32_t masterClock)
Configures an UART peripheral with the specified parameters.
Definition: uart.c:58
Get present status.
Definition: uart.c:174
Uart hardware registers.
Definition: component_uart.h:41
