RTEMS 5.2
arm-release-id.h
1
9/*
10 * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
11 *
12 * embedded brains GmbH
13 * Dornierstr. 4
14 * 82178 Puchheim
15 * Germany
16 * <rtems@embedded-brains.de>
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef ARM_RELEASE_ID_H_
24#define ARM_RELEASE_ID_H_
25
26#ifdef __cplusplus
27extern "C" {
28#endif /* __cplusplus */
29
30/* #define the IDs which identify a release. This must be done
31 * prior to #including bsp.h */
32#define ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( release_no, patch_level ) \
33 ( ( ( ( release_no ) & 0xFFFF ) << 16 ) + ( ( patch_level ) & 0xFFFF ) )
34
35typedef enum {
36 ARM_RELEASE_ID_R0_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 0 ),
37 ARM_RELEASE_ID_R0_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 1 ),
38 ARM_RELEASE_ID_R0_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 2 ),
39 ARM_RELEASE_ID_R0_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 3 ),
40 ARM_RELEASE_ID_R0_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 4 ),
41 ARM_RELEASE_ID_R0_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 5 ),
42 ARM_RELEASE_ID_R0_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 6 ),
43 ARM_RELEASE_ID_R0_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 7 ),
44 ARM_RELEASE_ID_R0_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 8 ),
45 ARM_RELEASE_ID_R0_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 9 ),
46 ARM_RELEASE_ID_R0_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 10 ),
47 ARM_RELEASE_ID_R1_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 0 ),
48 ARM_RELEASE_ID_R1_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 1 ),
49 ARM_RELEASE_ID_R1_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 2 ),
50 ARM_RELEASE_ID_R1_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 3 ),
51 ARM_RELEASE_ID_R1_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 4 ),
52 ARM_RELEASE_ID_R1_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 5 ),
53 ARM_RELEASE_ID_R1_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 6 ),
54 ARM_RELEASE_ID_R1_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 7 ),
55 ARM_RELEASE_ID_R1_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 8 ),
56 ARM_RELEASE_ID_R1_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 9 ),
57 ARM_RELEASE_ID_R1_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 10 ),
58 ARM_RELEASE_ID_R2_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 0 ),
59 ARM_RELEASE_ID_R2_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 1 ),
60 ARM_RELEASE_ID_R2_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 2 ),
61 ARM_RELEASE_ID_R2_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 3 ),
62 ARM_RELEASE_ID_R2_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 4 ),
63 ARM_RELEASE_ID_R2_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 5 ),
64 ARM_RELEASE_ID_R2_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 6 ),
65 ARM_RELEASE_ID_R2_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 7 ),
66 ARM_RELEASE_ID_R2_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 8 ),
67 ARM_RELEASE_ID_R2_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 9 ),
68 ARM_RELEASE_ID_R2_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 10 ),
69 ARM_RELEASE_ID_R3_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 0 ),
70 ARM_RELEASE_ID_R3_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 1 ),
71 ARM_RELEASE_ID_R3_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 2 ),
72 ARM_RELEASE_ID_R3_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 3 ),
73 ARM_RELEASE_ID_R3_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 4 ),
74 ARM_RELEASE_ID_R3_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 5 ),
75 ARM_RELEASE_ID_R3_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 6 ),
76 ARM_RELEASE_ID_R3_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 7 ),
77 ARM_RELEASE_ID_R3_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 8 ),
78 ARM_RELEASE_ID_R3_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 9 ),
79 ARM_RELEASE_ID_R3_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 10 ),
80 ARM_RELEASE_ID_R4_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 0 ),
81 ARM_RELEASE_ID_R4_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 1 ),
82 ARM_RELEASE_ID_R4_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 2 ),
83 ARM_RELEASE_ID_R4_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 3 ),
84 ARM_RELEASE_ID_R4_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 4 ),
85 ARM_RELEASE_ID_R4_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 5 ),
86 ARM_RELEASE_ID_R4_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 6 ),
87 ARM_RELEASE_ID_R4_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 7 ),
88 ARM_RELEASE_ID_R4_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 8 ),
89 ARM_RELEASE_ID_R4_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 9 ),
90 ARM_RELEASE_ID_R4_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 10 ),
91 ARM_RELEASE_ID_R5_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 0 ),
92 ARM_RELEASE_ID_R5_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 1 ),
93 ARM_RELEASE_ID_R5_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 2 ),
94 ARM_RELEASE_ID_R5_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 3 ),
95 ARM_RELEASE_ID_R5_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 4 ),
96 ARM_RELEASE_ID_R5_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 5 ),
97 ARM_RELEASE_ID_R5_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 6 ),
98 ARM_RELEASE_ID_R5_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 7 ),
99 ARM_RELEASE_ID_R5_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 8 ),
100 ARM_RELEASE_ID_R5_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 9 ),
101 ARM_RELEASE_ID_R5_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 10 ),
102 ARM_RELEASE_ID_R6_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 0 ),
103 ARM_RELEASE_ID_R6_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 1 ),
104 ARM_RELEASE_ID_R6_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 2 ),
105 ARM_RELEASE_ID_R6_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 3 ),
106 ARM_RELEASE_ID_R6_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 4 ),
107 ARM_RELEASE_ID_R6_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 5 ),
108 ARM_RELEASE_ID_R6_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 6 ),
109 ARM_RELEASE_ID_R6_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 7 ),
110 ARM_RELEASE_ID_R6_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 8 ),
111 ARM_RELEASE_ID_R6_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 9 ),
112 ARM_RELEASE_ID_R6_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 10 ),
113 ARM_RELEASE_ID_R7_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 0 ),
114 ARM_RELEASE_ID_R7_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 1 ),
115 ARM_RELEASE_ID_R7_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 2 ),
116 ARM_RELEASE_ID_R7_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 3 ),
117 ARM_RELEASE_ID_R7_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 4 ),
118 ARM_RELEASE_ID_R7_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 5 ),
119 ARM_RELEASE_ID_R7_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 6 ),
120 ARM_RELEASE_ID_R7_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 7 ),
121 ARM_RELEASE_ID_R7_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 8 ),
122 ARM_RELEASE_ID_R7_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 9 ),
123 ARM_RELEASE_ID_R7_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 10 ),
124 ARM_RELEASE_ID_R8_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 0 ),
125 ARM_RELEASE_ID_R8_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 1 ),
126 ARM_RELEASE_ID_R8_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 2 ),
127 ARM_RELEASE_ID_R8_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 3 ),
128 ARM_RELEASE_ID_R8_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 4 ),
129 ARM_RELEASE_ID_R8_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 5 ),
130 ARM_RELEASE_ID_R8_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 6 ),
131 ARM_RELEASE_ID_R8_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 7 ),
132 ARM_RELEASE_ID_R8_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 8 ),
133 ARM_RELEASE_ID_R8_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 9 ),
134 ARM_RELEASE_ID_R8_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 10 ),
135 ARM_RELEASE_ID_R9_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 0 ),
136 ARM_RELEASE_ID_R9_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 1 ),
137 ARM_RELEASE_ID_R9_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 2 ),
138 ARM_RELEASE_ID_R9_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 3 ),
139 ARM_RELEASE_ID_R9_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 4 ),
140 ARM_RELEASE_ID_R9_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 5 ),
141 ARM_RELEASE_ID_R9_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 6 ),
142 ARM_RELEASE_ID_R9_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 7 ),
143 ARM_RELEASE_ID_R9_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 8 ),
144 ARM_RELEASE_ID_R9_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 9 ),
145 ARM_RELEASE_ID_R9_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 10 )
146} arm_release_id;
147
148#ifdef __cplusplus
149}
150#endif /* __cplusplus */
151
152#endif /* ARM_RELEASE_ID_H_ */
